DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Tue Jul 03, 2012 4:54 pm Post subject: Is Cluster Foil a possibility? |
I've been thinking a lot about my fuel tank drop. Now I'm wondering if the foil going to the right hand side of my cluster 1) temp gauge on top 2) clock 3) fuel gauge on bottom, may have something wrong with it as none of them work. I have a separate temp gauge with numbers.
Perhaps the fuel gauge doesn't work because of the foil (analogue clock doesn't work either). Is there any way I can test this thought out??????? _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
randywebb Samba Member
Posted: Tue Jul 03, 2012 5:36 pm Post subject: |
I usually figure the Cluster Foil is a possibility for any electrical or engine problem... _________________ 1986 2.1L Westy 2wd Auto Trans. |
DAIZEE Samba Member
Posted: Tue Jul 03, 2012 5:41 pm Post subject: |
ok, hypothetically say it is, what do I do about it? oh first how do you ascertain that it is the problem or contributing to the problem? _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
Posted: Tue Jul 03, 2012 5:44 pm Post subject: |
if you pull the cluster, be careful with the foil - it is delicate & so is that $%^*() connector
on the wiring diagram for your vehicle, what links all those devices you mentioned? _________________ 1986 2.1L Westy 2wd Auto Trans. |
DAIZEE Samba Member
Posted: Tue Jul 03, 2012 5:49 pm Post subject: |
I'll look at the Bentley tomorrow and see if I can make sense of it. Bentley in van. There have been several different clusters in Scooby, no history on any of them. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Tue Jul 03, 2012 5:57 pm Post subject: |
DAIZEE wrote: |
I'll look at the Bentley tomorrow and see if I can make sense of it. Bentley in van. |
Hey sunshine
I used an inexpensive pointy tip electrical tester to evaluate if the connector was getting power, from there it's elementary to determine if it's foil caused or otherwise.
As stated, be VERY careful around the connector or the foil. Delicate stuff.
If you have power at connector - check continuity of ground before deciding on foil. Ever done your grounds? That was my issue - one clean wire and I was good to go.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
DAIZEE Samba Member
Posted: Tue Jul 03, 2012 7:31 pm Post subject: |
Yep redid my two ground stars when I had the dash out. I have a continuity light so will poke gentley around with that. Have to take the top off to rewire in the tachometer anyway and I'm real good at getting the switches out now. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
SteelB12 Samba Member
Joined: December 21, 2010 Posts: 591 Location: Central Virginia
Posted: Tue Jul 03, 2012 10:09 pm Post subject: |
Is there anything that can be used to repair damaged foil?? _________________ 1987 Westy |
morymob Samba Member
Posted: Wed Jul 04, 2012 4:51 am Post subject: |
I've had only minor luck repairing foils, if only one problem, with a jumper wire. Plug area as stated is very touchey.As yours has been changes more than once u will have to determine if still orig or a later one is now there. Look in'Old Volks Home' web site, easy to follow directions how to switch wires in plug to use either one, NOT interchangeable without the wiring switch, this makes the part hunt some easier. I'm wanting to,this winter, take an old clister and try to replace foil with wires, one circuit at a time??, seems possible. |
boulderdrop Samba Member
Joined: February 06, 2008 Posts: 481 Location: Seattle, WA
Posted: Tue Jan 28, 2014 11:33 am Post subject: |
GoWesty just released "Cluster Harness Kit", which replaces the FOIL. I've been waiting for this product since their announcement in Aug/Sept 2013. Nice option for cracked and damaged instrument-cluster-foil...
Cluster Harness Kit [Vanagon]
http://www.gowesty.com/ec_view_details.php?id=23926&category_id=&category_parent_id=
Also, I saw people were posting pics of their cluster-gauge-icons. Here's one for a LLSD and MIL. _________________ == My Rides ==
1984 Westy, Bostig, 3rd:1.14, Locker-LSD, Newly Painted
1980 24' J-Boat
1979 Sears Freespirit Moped
1996 Chev S10 4x4 ZR2
2012 Toyota Camry Hybrid (Wife's)
== How I Pay the Bills ==
Windows FTP Server at http://www.bpftpserver.com (PM for a FREE one) |
