hedgedjsf Samba Member
Joined: February 02, 2012 Posts: 3 Location: Blythe, Ca
Posted: Fri Jul 06, 2012 3:38 pm Post subject: Rolling Body Cart Plans and build for my '66 Bug |
So I have seen a few posts about building a rolling cart for a pan off restoration. I decided to go ahead and build one on my own out of two by fours. I took pictures along the way and made a plan diagram with a cut list and materials list. I figured this will help others looking to build something similiar.
With these plans I went with wood as it is cheaper and strong enough for this application. If you wish to use metal, these plans would work just as well. With this design you have enough clearance to roll your pan underneath for storage with the stick shift on (You may need to may adjustments as neccesary if your tires are larger or your garage/storage area is lower). This is for a stock 66 Bug setup.
The Plans, Material List, and Cut List
Raw Materials
Main Portions Cut
Started Assembly (I pre drilled each hole to prevent splitting of the wood)
Small supports in place squaring it up before screwing to bottom plate
Screwed to bottom plates
Measured in each side 1" and placed in between lines (Centered)
Both sides completed
Longer side supports in place
All supports in place
Each wheel screwed to each corner. I also used four small nail plates on the inside of each long support for added support.
Bug Body on Cart
In Garage and Pan rolling Underneath
Completed and stowed in the garage. I can simply roll the pan out or the body to work on each.
This car works well and will serve it's purpose. You can modify it as neccesary. Maybe bigger tires for different terrain or added support for durability. I hope this helps others with their projects.
This is my first Bug Restoration so I am new to all of this. |
russ c Samba Member
Posted: Fri Jul 06, 2012 3:53 pm Post subject: |
nice job1 |
Roadtripper Samba Member
Posted: Mon Jun 24, 2013 9:41 am Post subject: |
Awesome! Thanks for posting this. I am just about to remove the body and will follow your design. Perfect for my situation. |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Mon Jun 24, 2013 10:34 am Post subject: |
Good one!.. and economical too. |
grandpa pete Samba Member
texas58rag Samba Member
Posted: Mon Jun 24, 2013 2:38 pm Post subject: |
very nice I built a low profile one , just to scoot my body around the shop , but maybe next time Im stuck in a 2 car garage I will build me one like this.
I don't know what Im talking about I said Id never do another body of restore again, lol _________________ Jason Wallace
www.smgpsinstall.com
1958 ragtop - building for show
1957 hardtop - Sinister 57 is BACK!!
2013 Jetta - Company car
See my build
http://www.thesamba.com/vw/forum/viewtopic.php?t=558932 |
9pin Samba Member
Joined: August 07, 2012 Posts: 126 Location: Minneapolis
Posted: Sun Jul 20, 2014 3:30 pm Post subject: |
I'm building one just like this. Thanks so much for posting the blue prints.
I. Have a few questions... How tall does your body sit from the floor to the top of the body roof? And how much room does the cart clear the top of the fan shroud? Thanks _________________ Yet another person with a '66 project: http://www.thesamba.com/vw/forum/viewtopic.php?t=526418 |
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Sun Jul 20, 2014 3:45 pm Post subject: |
9pin wrote: |
I. Have a few questions... How tall does your body sit from the floor to the top of the body roof? And how much room does the cart clear the top of the fan shroud? Thanks |
You might want to send him a pm, this thread is two years old, OP only has 3 posts and hasn't been on the Samba since February! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
mukluk Samba Member
Posted: Sun Jul 20, 2014 4:24 pm Post subject: |
9pin wrote: |
Going off the specs he has listed in the drawings -- 24.5" vertical post, plus the thickness of the top and bottom rails (2x4s are actually about 1.5" thick), plus the height of the casters which appears to be about 4 inches gives us about 31.5" high for the body cart... add on roughly 48" or so for the body height gives us around 79.5" overall or just under 6 feet 8 inches. As for clearance for the fan shroud, the cart should be right about 30" from the floor to the bottom of the top rail (depends on how tall your casters are). _________________ 1960 Ragtop w/Semaphores "Inga" |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
9pin Samba Member
Posted: Mon Jul 21, 2014 9:19 am Post subject: |
mukluk wrote: |
Going off the specs he has listed in the drawings -- 24.5" vertical post, plus the thickness of the top and bottom rails (2x4s are actually about 1.5" thick), plus the height of the casters which appears to be about 4 inches gives us about 31.5" high for the body cart... add on roughly 48" or so for the body height gives us around 79.5" overall or just under 6 feet 8 inches. As for clearance for the fan shroud, the cart should be right about 30" from the floor to the bottom of the top rail (depends on how tall your casters are). |
Sweet, thanks. Those measurements were close to what I was coming up with by measuring it out roughly. My garage door opening is about 77" in height. I can probably make this work if I back the engine in first and don't completely cover the body over it. _________________ Yet another person with a '66 project: http://www.thesamba.com/vw/forum/viewtopic.php?t=526418 |
AZ66Bug Samba Member
Joined: February 17, 2014 Posts: 311 Location: Chandler, AZ
Posted: Fri Jul 25, 2014 7:32 pm Post subject: |
Very nice job - just what we were looking for. Body coming back from painters in a few weeks and the chassis/engine is not done. Need to be able to "store" the body above the chassis as we work. Thanks for the detailed plans! _________________ 66 Beetle Sedan, restored 2014
66 Mustang: Original Owner, restored 2008
66 Ford F250: 4th Owner, restored 2013 |
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
Posted: Sat Jul 26, 2014 6:25 am Post subject: |
This is great .. mainly because non-pressure treated 2x4's are so cheap. I would hate to spend money on pressure treated 4x4's or 6x6's or 2x2 steel tubing for something that when I was done with it was just going to get cut up for scrap.
I'm going to make a modified version of this for my Ghia when the time comes to pull the body off. I've got a couple of the $9.99 HF furniture dollies I could borrow the caster wheels off of. _________________ Chris
1968 Karmann Ghia coupe - build log here: Chris' 68 Ghia Build Log - From the Woods back to the Street
Metamatic Samba Member
Joined: June 19, 2014 Posts: 54 Location: Limhamn, Sweden
Posted: Thu Aug 07, 2014 5:14 am Post subject: |
Just what I was searching for when I googled. I am currently making a restoration on a 1303 convertible and this is perfect! |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Aug 07, 2014 5:39 am Post subject: |
Mines a little beefier.. used 4X4's and big pneumatic tire casters for uneven grounds.
I prefered keeping it off the heater channels so if any work needed to be done to those.. the body cart wasnt in the way.
Plus it high enough to roll a full chassis out with the engine still attached.
Will fit in an average garage.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
SpideyDad Samba Member
Posted: Thu Aug 28, 2014 8:27 pm Post subject: |
Volkswagnut.... That looks great too! Any measurements for yours? |
LOTYP3 Samba Member
Joined: February 13, 2007 Posts: 128 Location: Australia
Posted: Tue Jan 05, 2016 5:18 am Post subject: Re: Rolling Body Cart Plans and build for my '66 Bug |
Just wanted to say thank you for putting this plan up, I built this dolly following your instructions and it came up a treat!
I originally had the car up with the fenders and everything still on the body. It handled the weight OK, but I could see it was stressing the frame, so I took them off.
Thanks again, the only small change I would make it to replace the small supports with longer ones to make the whole thing more rigid.
Cheers,
Vinny |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Tue Jan 05, 2016 6:51 am Post subject: Re: Rolling Body Cart Plans and build for my '66 Bug |
I'll be copying this too, except I'll have the pneumatic castors too for my gravel driveway, Thanks. _________________ 1963 Ragtop Bug |
Posted: Wed Mar 09, 2016 5:32 pm Post subject: Re: Rolling Body Cart Plans and build for my '66 Bug |
Made a copy of the OP's cart with 2 pieces going across and 8" tires.
