cmayna Samba Member
Joined: August 18, 2014 Posts: 1147 Location: SF Bay area, CA
Posted: Tue Apr 13, 2021 7:53 pm Post subject: Re: Westfalia curtains |
When the hatch is opened, with the curtain closed, will there be too much stress on the magnets, causing the curtains to pull away and fall down? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
kamzcab86 Samba Moderator
Posted: Tue Apr 13, 2021 9:00 pm Post subject: Re: Westfalia curtains |
cmayna wrote: |
When the hatch is opened, with the curtain closed, will there be too much stress on the magnets, causing the curtains to pull away and fall down? |
Not if using neodymium magnets.🍺 _________________ ~Kamz
2016 Golf GTI S
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Tue Apr 13, 2021 9:15 pm Post subject: Re: Westfalia curtains |
My tiny neodymium magnets don't hold very hard with cloth between them and the steel, but they easily hold the curtains up with the hatch up.
Not sure what problem that would cause if the curtains fell.
Most of the time they's be bunched up and snapped anyway.
I'm about halfway done sewing magnets into the hems.
I really doubt you could wear out the fabric.
Maybe on the slider door, if the magnets were really strong... when you open the door they slide on the painted steel.
But the tiny magnets I'm using would never wear out the fabric even in daily use.
Pretty easy to use washer-type magnets, you just sew a little dot in the hole.
could do it easily by hand, all it takes is just a couple pokes thru then tie a knot.
All it needs to do is keep the magnets in their place, otherwise they would slide and then stick together in a clump.
But I've been using the sewing machine (lazy ass).
Looking forward to removing the spring-things.
I think I can leave the one that holds the storage bin covers open. _________________
....KTMs, GasGas, SPOT mtb |
jimf909 Samba Member
Posted: Tue Apr 13, 2021 9:29 pm Post subject: Re: Westfalia curtains |
Sodo wrote: |
I think I can leave the one that holds the storage bin covers open. |
Think magnets. Or gas springs. I've seen a few posts showing gas springs holding the storage bin covers open.
You're welcome, the to-do list looked a bit short. _________________ - Jim
Abscate wrote: |
Sodo Samba Member
Posted: Tue Apr 13, 2021 10:05 pm Post subject: Re: Westfalia curtains |
To-do list is horrendous.......
Wonder if magnets on the bin doors can attach to the curtain magnets. _________________
Posted: Tue Apr 13, 2021 10:11 pm Post subject: Re: Westfalia curtains |
Sodo wrote: |
Wonder if magnets on the bin doors can attach to the curtain magnets. |
Glued in or sewn in? _________________ - Jim
Abscate wrote: |
danfromsyr Samba Member
Posted: Thu May 06, 2021 2:03 pm Post subject: Re: Westfalia curtains |
weekender curtain dimensions from this thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=661256
h00drat wrote: |
I did some searching and I don't think this exists yet, so I figured I'd share in case it helps someone else out in the future.
have this 1987 Wolfsburg Weekender that didn't come with with the factory curtains. Most of the snaps are there, and all of the rotating clips are there.
So, I'm going to make some.
My wife's grandma is a great seamstress, so she'll be doing the sewing. I'll be placing the snaps and grommets after they're made to make sure everything lines up and is tight.
Attached is my first go at the templates. I'm debating between running the front curtain all the way to the floor in the walkway, or just going straight across. Straight across is a simple design and probably won't let too much light through.
We were leaning towards a grommet of some kind on the bottom as I don't know what was originally there. Any input on that?
Also, any input on fabric? I'm leaning towards a dark blue, but not sure of the weight or material I should be after.
And lastly, any input on the templates in general is appreciated.
Abscate wrote: |
onefred Samba Member
Joined: January 06, 2012 Posts: 245 Location: Thaïland - Geneva
Posted: Mon Aug 29, 2022 10:36 pm Post subject: |
Zeitgeist 13 wrote: |
Years ago I ignorantly bought this set of camper curtains thinking that I'd use them as templates for reproduction as a grey set for my Bluestar. Unfortunately when the box arrived, I just verified that everything in the ebay ad was there and then promptly placed the whole pile on a shelf for the next half decade. Now I'd like to sell them to a camper person, but have no idea whether these are factory or some kind of aftermarket thing. For whatever reason, there are two of the large front window curtains, and they're a slightly lighter shade of brown and made of a thinner fabric than the others.
The general dimensions are a little different than those listed here and also, there's only one curtain with the drapery strip at the top, so I'm really confused about what I have...l'il help?
Here are the pieces in the set:
1 each) 28" x 21" w/drapery strip and velcro strip on side (1)
2 each) 32" x 21" w/tube fold and velcro strip on side (1)
5 each) 28" x 21" w/tube fold and velcro strip on side (1)
2 each) 28" x 23" w/tube fold, snaps and velcro strip on side (2)
2 each) 132" x 28" w/elastic sewn into the top along with snaps (4) and snaps along each side (1)
These are the two very large front curtains.
Here you can sorta see the color/fabric difference between the front curtain and the rest.
Apparently these curtains are designed to be hung via these long elastic cords, but I'm not sure if that's factory Westfalia or not.
Hello, possible to have pictures ?
Thanks. |
