dabble Samba Member
Joined: April 21, 2004 Posts: 271 Location: Olympia, Wa
1vwdog Samba Member
Joined: March 16, 2004 Posts: 285 Location: Poulsbo WA
Posted: Mon Jul 09, 2012 8:41 pm Post subject: |
Northwest Connecting Rod. Reputable , quality work and knowledgeable staff. _________________ 71 Chianti Westy |
Daverham Samba Member
bummerbus Samba Member
Joined: April 12, 2009 Posts: 64 Location: Portland, OR
Posted: Mon Jul 09, 2012 9:34 pm Post subject: |
I am not sure how much actual work jerrry does at northwest connecting rod, I believe it's mostly a machine shop and engine builder. I got some heads worked on by him and was very happy with the price and are so far doing great.
Bowwow or autovice is the most known and a friend swears by them (Doug)for his vanagons and beetle.
There is also Buterra out in Juanita. They were super helpful and honest when I was chasing some gremlins. Basically he drove my bus around the block told me what he thought was wrong and sent me on free of charge. Though I am pretty sure try mostly do watercooleds and type 1s _________________ ‘75 FI-1800cc. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Jul 09, 2012 11:06 pm Post subject: Re: Best Seattle repair shop(s)? |
dabble wrote: |
I can't seem to figure out my poorly running engine so I am going to take my 2.0FI to a shop. Any in Seattle come highly recommended? |
buddy...gimme a call and i will try to swing by sometime first...i like diagnosing errors...
206 841 7324
Stuart _________________ Stuart Zickefoose
206-841-7324
[email protected] |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Tue Jul 10, 2012 8:02 am Post subject: |
Franklins VW has my vote -- I picked up my bus (almost sight unseen) near bellingham and by the time I was past the airport in seattle I was losing a quart of oil every 10 miles from a pair of leaking valve covers.
It was sunday around 11am, and everything else was closed, . Bowwow, a few no-name places I'd found on my phone, etc. I needed valve cover gaskets for sure, and maybe a valve cover. Obviously for a t4 these are not easy to find in a strange city on sunday on a whim. I drove past Franklins, having heard some good things from the t3 seattle people.
MAN was I blown away!
Franklin was alone in the shop that day, but when we rolled in he gave me a new valve cover and fresh gasket for free, despite insisting to pay him for it. he toured my dad and I around the shop and showed us his projects and loaned me a jack and some room in the drive bay to swap out the gaskets and valve cover.
TLDR: Franklin is a 100% awesome guy, great shop. take your business to a guy who eats sleeps and breathes vw's and obviously has an upstanding ethic. _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Tue Jul 10, 2012 8:05 am Post subject: |
Whats TLDR?
JSMskater wrote: |
TLDR: Franklin is a 100% awesome guy, great shop. take your business to a guy who eats sleeps and breathes vw's and obviously has an upstanding ethic. |
206-841-7324
[email protected] |
Krautski Samba Member
Posted: Tue Jul 10, 2012 11:30 am Post subject: |
The first time I took my bus to Wolfsburg was also the last.
I know a lot of the shop owners in the area. I'd recommend Fine Tuning although its been a while and I forget how much aircooled they do. _________________ BUS FOR SALE
Quote: |
I stopped reading after volksaru and busaru |
timo78 Samba Member
Joined: July 03, 2009 Posts: 931 Location: Overcast and Loving it
Posted: Tue Jul 10, 2012 12:07 pm Post subject: |
The Wagonshop in Kirkland. Calvin and Greg are good aircooled veterans. _________________ > 78Grµn Westfalia `Donkey`
It may be bigger than you and it may be bigger than me, but it’s not bigger than you AND me; can you dig it? |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Tue Jul 10, 2012 12:49 pm Post subject: |
JSMskater wrote: |
True this. I went in for oil cooler doughnuts, simular respoce from him. Good guy. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Wed Jul 11, 2012 12:30 am Post subject: |
he isnt as samba addicted as i am...so ill spill the news first.
we took off his new plug wires from autozone, and replace two which were shocking me repeatedly when i touched the dizzy, using the best two old ones he had, because two of the old wouldnt work (one had no resistance (open short) and the other was to short for that side of the engine)
next we checked the advance and found it to not be working properly. so i tore out the dizzy, threw it in a vice, tore it down to nothing real quick, lube the SHIZZ outta the shaft (and the advance plate), which was stiffer then a rock, and then put it back together and inserted it back into the hole (in the engine)
did anyone else re read that? L>O>L>>>>
set the timing at 28* with no hoses at full advance, took it for a test drive and he said it felt MUCH better...so i told him to re lube it ever few times he drives it and we will check it again and see how it works out. if it doesnt free up enough, then i suggested a used distributor from ken. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Jul 11, 2012 12:34 am Post subject: |
I lied...he is addicted also....
from the Ljet help area...
dabble wrote: |
Big thanks to Stuart!!
He came over tonight and figured out the majority of the problem. My mechanical and vacuum advance on my dizzy was not working at all. Also had two spark plug wires (new from auto zone...) that were not sending consistent spark.
Stuart pulled the dizzy, took it apart, lubed everything up, and it runs much better now!
It still has a backfire when I let off the accelerator so I need to figure that out, but it is in a much better place now than before. I think I will check the decal valve and go from there.
Thanks again, Stuart! And thanks Samba! |
206-841-7324
[email protected] |
dabble Samba Member
Posted: Wed Jul 11, 2012 8:13 am Post subject: |
Stuartzickefoose wrote: |
dabble wrote: |
I'm quite addicted... Stuart rocks! _________________ 1973 Westy with a 78 FI 2000cc
[url=http://www.vw-mplate.com/mplate2-9157.png]Click to view image[/URL] |
Posted: Wed Jul 11, 2012 11:02 am Post subject: |
OK. I'll fess up. Me too. But I've read a LOT of great reviews about them, so I kept quiet about this. Maybe it was just a fluke but....
Truth is, the one time I went there (I had only owned by bus for a month) they could not figure out my problem, and the things they did to try and figure it out blew me away with how lame and just plain DUMB they were (the techniques, not necessarily the people). So $250 and 4 full weeks later, I limped my bus home and fixed it myself. That was 3 years ago. I haven't been back since - and why would I?
Details:
http://www.thesamba.com/vw/forum/viewtopic.php?t=378770 |
chrisd1891 Samba Member
Joined: April 30, 2009 Posts: 252 Location: Seattle, WA
Posted: Wed Jul 11, 2012 7:57 pm Post subject: |
I got my engine built at NW Connecting rod. Someone messed up the oil galley plugs, so I got it back and it leaked oil everywhere. I'm still trying to get it sorted. It's been a long ordeal, but Jerry seems willing enough to come fix it. Allegedly it should be sorted out this weekend.
Take that for what you will. I heard good things about NW Connecting Rod, but my experience has been poor. No doubt they're knowledgeable, but this little mistake really screwed things up. Lots of money and time wasted. It is what it is, I guess. Next engine that goes, I'm rebuilding it myself. _________________ 74 Bay + 93 Corrado SLC + 2015 TDI Wagon
Admin at Aircooled Rescue. Register to help out your fellow VW folks. |
Malokin Martin Samba Member
Posted: Wed Jul 11, 2012 9:22 pm Post subject: |
NW connecting works on engines... but from my understanding this doesn't include an engine that’s installed in a bus... You bring them an engine out.... they are THE go-to engine people in WA. (just don't let him talk you into bead blasting your case...)
I use roadhaus to find shops in my area… (anecdotally Wolfsburg Motorwerks has gotten numerous bad reviews there…)
http://roadhaus.com/shops_search_map.php?state_id=47
I’ve had a reasonably positive experience with Mike at Wagenschmitt in the U-district
(206) 545-3500
http://wagenschmitt.com
Posted: Wed Jul 11, 2012 9:38 pm Post subject: |
I also keep hearing about these guys, at least in regard to suspension:
http://www.group2inc.com/auto-projects.html
Supposedly they do a lot of VW bus stuff. Not really sure what, exactly. |
1vwdog Samba Member
Posted: Wed Jul 11, 2012 9:43 pm Post subject: |
I found Jerry to be a standup guy. I do think it is a hard industry to stay afloat. My hat is off to the local guys who stick with VWs. The broad reach VW once had has shrunk over time. I might raise some hackles with that comment. I only mean to say that the VW days of seeing them everywhere has changed and to keep a business going solely focused on VWs has to be tough. _________________ 71 Chianti Westy |
Malokin Martin wrote: |
(206) 545-3500
mike is one hell of a guy. if you want to meet him personally, come to a kascade Kombis meeting first tuesday of every month at spiros pizza on 175th in shoreline off hwy 99....lots of people to know are in this crowd, and the beers free the first meeting you come too!
Mike really knows his stuff...give him a call if nothing else works for sure! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Jul 11, 2012 9:53 pm Post subject: |
1vwdog wrote: |
I found Jerry to be a standup guy. I do think it is a hard industry to stay afloat. My hat is off to the local guys who stick with VWs. The broad reach VW once had has shrunk over time. I might raise some hackles with that comment. I only mean to say that the VW days of seeing them everywhere has changed and to keep a business going solely focused on VWs has to be tough. |
I work in the industry that builds the machinery shops like NWCN use, and its a very tough industry for being focused on VW alone.
A good friend of mine has had good experiences with Wagenschmitt. _________________ BUS FOR SALE
