AlteWagen Troll
Posted: Tue Jul 10, 2012 6:08 pm Post subject: Fresh air delete/181 shroud clone done the right way |
Cant afford the $300+ price tag of a 1973 only thing shroud? I know I cant so I made a better than 181 shroud.
Im tired of hacks just cutting off the ducts, welding up the holes and selling a "cal look" or home made thing shroud. If the internal directional veins are not removed the air flow inside the shroud can cause problems with turbulence resulting in inefficient cooling. Using the plugs on the ducts also causes the same problem. The Raby trick of leaving the veins but drilling a large hole to simulate the "bleed off" the stock heater boxes is one way to do it, but I would rather show the correct way of doing the modification.
I used an early FI shroud with the velocity ring and large negative slot but the same will work on any of the DH shrouds that you can get for $20 at the swap meet.
In these pics I circled the spot welds that need to be drilled out in order to remove the two internal veins that direct air to the heater system.
this is the tricky one
After the welds are drilled out the easiest way to remove the ducts is to give them a squeeze with some channel lock pliers.
Once the top one is out the bottom one will just slide out
Once all the veins are removed, dolly the remaining metal and make your patch panel and weld it up.
Here is a pic of all the parts that need to be removed for best results
It took me a few hours from start to finish just to do the removal and welding, add a few more for bodywork and paint.
I use rustoleum semi gloss engine enamel, its close to stock and holds up to gas and oil spills well.
Happy chopping!!! |
swervyjoe Samba Member
Joined: February 07, 2004 Posts: 968 Location: denver, co
Posted: Tue Jul 10, 2012 7:50 pm Post subject: |
Very nice. I'm fixing to do this. I had a basic idea of how to do it, but its nice to see the pics ahead of time. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Wed Jul 11, 2012 11:46 pm Post subject: Re: Fresh air delete/181 shroud clone done the right way |
Before you install the shroud, you should bend the curved arm on your cooling flaps back up closer to the flap it's riveted to. _________________
AlteWagen Troll
Posted: Wed Jul 11, 2012 11:56 pm Post subject: |
I have a perfect set of flaps with linkage and tstat that will be used for this shroud. The ones on the shroud in the pics were $1 bin specials I used for mock up. |
rrcade Samba Member
Joined: May 29, 2010 Posts: 735 Location: WI 1962 Bug 2276
Posted: Thu Jul 12, 2012 11:11 pm Post subject: |
I have a Doghouse shroud now with the round caps on the heat ducts, so is this procedure the same for any doghouse shroud? How much additional cooling will the heads/cylinders really see? |
rrcade Samba Member
Posted: Fri Jul 13, 2012 12:28 am Post subject: |
Also, I've read about cutting off the ducts, patching the holes and then directly behind the ducts you patched you're supposed to cut a inch and a half hole in the backside of the shroud? How is that any different than just not capping your ducts on the front? You're still wasting air that could be used for cooling right? |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Fri Jul 13, 2012 5:29 am Post subject: |
rrcade wrote: |
The purpose of this is not to capture the air, it's to keep the internal pressure where it should be to avoid turbulence and the like. The whole system was very carefully designed and difficult to improve on significantly.
It does work for any doghouse shroud. I wouldn't bank on a huge change in temperatures, but don't have any numbers on the modification.
Nice to see a write up on this. I did a similar modification to my shroud a while back. On the driver's side (US) of the engine, I reworked the bottom of the fresh air fin out to gently direct the air back into the stream. On the other side, I bent the top of the fin against the side wall. This seemed like the most logical way to keep the airflow smooth.
I am interested to see the rest of this, keep posting. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2387 Location: Seekonk,Massachusetts USA
Posted: Sun Feb 05, 2017 8:23 am Post subject: |
AlteWagen wrote: |
How is the shroud working with the upgrades done? _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
AlteWagen Troll
Posted: Sun Feb 05, 2017 9:35 pm Post subject: Re: Fresh air delete/181 shroud clone done the right way |
Im still using the short puma/brazilia non fresh air shrouds with venturi ring as they seem to work best for my applications. They do not have any diverter veins like the thing shroud which is why I removed them in the 181 clone mod. I would rather use all the cooling air directed to the heads than to drill a huge hole to "normalize" or reduce turbulence in the shroud. _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
Posted: Thu Feb 09, 2017 9:19 am Post subject: Re: Fresh air delete/181 shroud clone done the right way |
AlteWagen wrote: |
Im still using the short puma/brazilia non fresh air shrouds with venturi ring as they seem to work best for my applications. They do not have any diverter veins like the thing shroud which is why I removed them in the 181 clone mod. I would rather use all the cooling air directed to the heads than to drill a huge hole to "normalize" or reduce turbulence in the shroud. |
There is a lot of confusion on what should be done, to a type 1 shroud to make it look and work like a 1973 181 shroud. I wish someone would set the record straight.
I see no differences between the way 181 shroud cools to a type 1 cools with the ducts block off.
BTW, I have been using a 1974 type 1 shroud with the ducts blocks off on the same engine for years.
02/76 Beetle sedan
Last edited by APPLEGREENVW on Thu Feb 09, 2017 11:20 am; edited 1 time in total |
Motor60 Samba Member
Posted: Thu Feb 09, 2017 9:56 am Post subject: Re: Fresh air delete/181 shroud clone done the right way |
Anyone?? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Thu Feb 09, 2017 8:28 pm Post subject: Re: Fresh air delete/181 shroud clone done the right way |
The engine won't overheat if you just delete the arms; it's just a good idea to give the air somewhere to go, to reduce turbulence issues. We run some f'd-up shrouds without major issues. Doesn't make it right, just saying we can get away with a lot. I hole saw out a 1 1/2" hole on the frontside too, but recently saw a guy just pull out the channels instead of making the hole. Was way cleaner. I think that's how Thing shrouds are internally; they are without the heater channel. There's just a few spot welds that hold them in place. Drill, and they can be pulled out.
Here's an engine that I just sent on it's way: O.E. doghouse shroud, modded to look like a Thing shroud. It has 1 1/2" holes in the front side. I used matching .030" sheet metal, got it spot-welded in, and used a thin layer of fiberglass resin to mask any imperfections. I got the rounded corners just right.
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Thu Feb 09, 2017 9:08 pm Post subject: Re: Fresh air delete/181 shroud clone done the right way |
Hell, if you are getting rid of the fresh air outlets, why even keep the "hips" ?
They just get in the way of nice things like injectors, so I removed them completely, including some of the internal vanes. Engine runs nice and cool
_________________ modok wrote:
Posted: Thu Feb 09, 2017 9:11 pm Post subject: Re: Fresh air delete/181 shroud clone done the right way |
For nostalgia, duuuuuh.... lol! |
AlteWagen Troll
Posted: Fri Feb 10, 2017 1:10 am Post subject: Re: Fresh air delete/181 shroud clone done the right way |
I added this info on the upright shroud thread and thought it was an interesting read
http://www.volksbolts.com/faq/cooling.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=492074
For me the fact that the early non fresh air large shroud was described as "Modified shape increased cooling air throughput" in Progressive Refinements using the same fan as before leads me to believe the shape of the shroud is important. When the heater system went fresh air the heater boxes had to have constant air to control heat even when not in use which dumped the cooling air via the bleeder valve on the top of the box. This bleeder valve is the reason for the 1.5 in hole mod Raby suggested when leaving the veins in place
Im wondering that even though the hole in the heater box measures the 1.5 in does the flap and flap housing cover cause a restriction allowing pressure build up to keep the majority of cooling air directed to the heads and cooler? To me it seems that a 1.5 in hole in the front of the shroud is just bleeding off too much air for my liking.
For the record every 181 shroud Ive seen with the exception of 1 had the heater diverter veins in place. That 1 shroud also had the positive cooler scoop while the others were mixed pos and neg. I still am unable to pin down every application of the 181 shroud. Im guessing that export/domestic/mexican varied through out the years.
Of all the testing Ive done (Factory DH with neg and pos slot, EMPI 36hp large pos slot, Puma neg slot, Brazilia working FA heat) the ring, flaps and 356 pulley gave the best results. All tests were performed on the same engine in my daily driver bus with factory finger, sled and industrial tins in place (when not using heater boxes) and german head tins with spark plug cooling veins.
-Factory DH and Brazilia with working heat ran the highest CHT (40* above no heater system)
-Positive slot lowered OT 10* compared to negative slot (did not monitor #1 CHT to see if cooling was compromised as mentioned by Raby)
-Venturi ring lowered CHT 30* and oil temp 10*
-Flaps to puma shroud (no t stat just spring keeping flaps open) hastened CHT cooling when not under load.
-356 alt pulley lowered CHT 30* and OT 10
The next test before I take the engine down for another inspection/rebuild (now at 160K miles) will be a late FI shroud rear section with internals with a non FA 40hp cover. It will have small slot which I have not tried before so I can see how OT and CHT temps are affected and to compare to the EMPI 36hp shroud.
These are the only pics I have but the shroud has been cleaned, welded and painted and ready to go in as soon as the baby gives me enough time to do it.
I may also test a positive scoop on the peanut slot and a half positive scoop on the large negative shroud as I now have 4 CHT gauges to help collect cooling data. I would love to test the Type 4 cooler mod with the 3 different slot types. Im thinking the positive slot is needed to take advantage of the greater area of the cooler vs the peanut slot which reduced air to the oil cooler to give more cooling to the heads. _________________ Grapes of Wrath $200 Engine Rebuild
dsrtfox Samba Member
Posted: Fri Feb 10, 2017 8:58 am Post subject: Re: Fresh air delete/181 shroud clone done the right way |
On your custom shroud are you using the later, wider fan? |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Feb 10, 2017 5:17 pm Post subject: |
rrcade wrote: |
I have a 1975 doghouse FI shroud with the heat ducts capped. I found that it cools slightly better this way, than with stock heater boxes. (I also tried using the "dime-sized" holes in the caps, that someone had suggested, but it just negated the cooling improvement that the caps provided.)
I now use this capped doghouse shroud on my 10:1 CR 2332 cc and it cools perfectly with no external cooler required _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
