Tdog71 Samba Member
Posted: Sun Jul 15, 2012 7:19 am Post subject: How to prep door for painting |
I have doors off car with panels off (67). I have an air sander that I plan on using to grind off the old paint and rust. Should I remove the glass ? How do you remove the chrome trim on the doors window frame ? |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Sun Jul 15, 2012 7:25 am Post subject: |
Personally I would remove everything that you can unbolt. If it were a simple scuff and shoot then I would just tape it off but if you are stripping off old paint and rust you might as well take the extra time and do it right. It will be a much cleaner job in the end. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
Hugo Stiglitz Samba Member
Joined: August 07, 2009 Posts: 782 Location: Southern California
Posted: Sun Jul 15, 2012 9:18 am Post subject: |
Check out "brighteyefilms" on youtube. He's got a ton of how-to videos a few specifically on tearing down and rebuilding doors.
I would suggest taking everything out trim and all, prep & paint, then re-assemble with new components.
Wolfsburg West sells a great rebuild kit for the doors; comes with all the seals, scrapers and clips you'll need. _________________ '63 slow n low build thread...
Jay Leno's Garage
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] |
