BusBerd Samba Member
Joined: November 19, 2005 Posts: 834 Location: Minneapolis, MN
Posted: Sun Jul 15, 2012 12:09 pm Post subject: Castellated nut removal needed? |
Do I need to remove the castellated nut to replace the rear wheel cylinder on my '77 bus?
I have the drum off and it looks to the naked eye like it would be nice to have the extra space there with the rear wheel hub gone, but it is a royal PAIN to get the castellated nut off and I would have to go invest in some more specific tools to get it off.
(I think the rear wheel hub and brake drum are one piece on earlier bays) _________________ "The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission |
Daverham Samba Member
Posted: Sun Jul 15, 2012 1:23 pm Post subject: |
No you do not.
Remove those two silly little bolts that you see inbetween the wheel studs and the drum will pull right off OVER the big nut.
Keep in mind that it may need a little coaxing, banging etc. And, of course, make sure your parking brake is off. |
Posted: Sun Jul 15, 2012 1:35 pm Post subject: |
Oh sorry. I see you already have the drum off - different question.
Well then... Still, the answer is NO. I've changed wheel cylinders on my 78 without removing the hubs. No problem. Carry on! |
Posted: Sun Jul 15, 2012 1:59 pm Post subject: |
Daverham wrote: |
good. I've just been trying all afternoon to get this nut to turn and i'm getting nothing. _________________ "The large print giveth and the small print taketh away."
Posted: Sun Jul 15, 2012 3:34 pm Post subject: |
Skip it. Just do your wheel cylinder with the hub in place!
Remove the shoes/springs/cable. One steel brake line. One bolt from the back. Pops right out.
Posted: Sun Jul 15, 2012 6:00 pm Post subject: |
Daverham wrote: |
Thanks for the pic!! that is very helpful!
I wish mine looked as clean as that. It has been leaking brake fluid for a while, which has collected lots of gunk, so it is hard to see what I am working with. _________________ "The large print giveth and the small print taketh away."
Vince Waldon Samba Member
Joined: November 07, 2010 Posts: 451 Location: Edmonton, Alberta
Posted: Sun Jul 15, 2012 6:20 pm Post subject: |
Should you not be aware, older brake shoes (and clutches for that matter) were made using asbestos... so always a good idea to resist the urge to hit things with compressed air when cleaning up the gunk... never know how old the shoes are. |
Posted: Sun Jul 15, 2012 8:37 pm Post subject: |
Vince Waldon wrote: |
good to know! thanks. I don't think these shoes are that old, although I may replace them if I can afford it as long as I have the drum off. _________________ "The large print giveth and the small print taketh away."
Desertbusman Samba Member
Posted: Sun Jul 15, 2012 8:49 pm Post subject: |
If they are brake fluid soaked you need to replace them anyway. _________________ 71 Superbug
71 Westy |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sun Jul 15, 2012 10:44 pm Post subject: |
Daverham wrote: |
And, of course, make sure your parking brake is off and your front wheels are blocked off.
Fixed it for you
I just redid my CV joints and almost rolled out of the garage. Nobody should have to learn from that experience. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Mon Jul 16, 2012 3:41 am Post subject: |
There are several advantages to removing the castellated nut and the hub. For one it is just easier to get at all the brake stuff and get everything clean. Two you can replace the rear wheel seal, a part that needs occasional replacement.
For about $10 you can buy a slug wrench from you local VW shop that will make removal of the nut fairly easy.
Looks just like this one, but it is 46mm.
http://www.busdepot.com/5748
Here is what you want, but no picture.
http://www.busdepot.com/5747 |
Posted: Fri Jul 20, 2012 7:40 am Post subject: |
Desertbusman wrote: |
If they are brake fluid soaked you need to replace them anyway. |
Why?? Can't I just clean them off really good with brake cleaner or something?? There is plenty of wear left on the shoes. _________________ "The large print giveth and the small print taketh away."
Posted: Fri Jul 20, 2012 7:58 am Post subject: |
Raw brake fluid is water soluble so should clean off fine, not so sure about well burnt brake fluid. My old early '70s Land Cruiser was pretty notorious for leaking fluid and I can't ever remember changing out the shoes because of that. Oil and grease are a different matter, they can really change the friction characteristics of the linings, even then some people would just throw them in the fire pit and give them a good heating to clean them. Can't say I have ever tried that one though. |
Posted: Fri Jul 20, 2012 9:53 am Post subject: |
BusBerd wrote: |
Evidently it soaks in, that's what I heard.
Last week I replaced the rear shoes on my bug even thought they had hardly any wear. The reason was a lining came unbonded from it's steel shoe. And the wheel cylinder had been leaking and the shoes were damp. Did the adhesive fail because of brake fluid? Who knows. We do know that brake fluid is compatable with very very few materials. _________________ 71 Superbug
71 Westy |
Posted: Fri Jul 20, 2012 3:03 pm Post subject: |
Last week I replaced the rear shoes on my bug even thought they had hardly any wear. |
Sure seem to be seeing more frequent lining failure for both brakes and clutches. I don't seem to be able to get full life out of either any more. Can anyone spell cheap foreign crap? |
Posted: Fri Jul 20, 2012 3:36 pm Post subject: |
I ordered a new set of brake shoes just in case. what the hell.
FYI, I DID finally get the castellated nut off. I cleaned up the area as much as I could. sandblasted and painted the backing plate and hardware.
the other side should be much quicker now that I know what I'm doing. _________________ "The large print giveth and the small print taketh away."
Posted: Fri Jul 20, 2012 7:32 pm Post subject: |
BusBerd wrote: |
the other side should be much quicker now that I know what I'm doing. |
Sounds like you're doing great.
Wildthings wrote: |
True that! It's gotten too common. However the new shoes I got clearly said Made In China. And I very carefully gave them an intense visual inspection for everything I could think of. Outstanding packaging, accuracy of pad bonding location, chamfer on leading ends of the friction material, consistancy of everything, etc. Actually They by far are the besting looking shoes I've seen in decades. Scarry, huh? _________________ 71 Superbug
71 Westy |
atmellovw Samba Member
Joined: September 05, 2006 Posts: 1652 Location: Minnesota
Posted: Fri Jul 20, 2012 9:06 pm Post subject: |
BusBerd wrote: |
Note that if you removed the backing plate you are supposed to apply a bead of non-hardening sealant where the backing plate meets the bearing housing. _________________ 1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex |
Posted: Fri Jul 20, 2012 11:35 pm Post subject: |
atmellovw wrote: |
BusBerd wrote: |
Note that if you removed the backing plate you are supposed to apply a bead of non-hardening sealant where the backing plate meets the bearing housing. |
Thank you! I did not know that.
Time to re-read the bentley... _________________ "The large print giveth and the small print taketh away."
