VIN Samba Member
Posted: Fri Mar 15, 2013 7:48 pm Post subject: |
this is not unusual for a fresh engine. Things should stabilize as it gets more miles on it. Just remember to periodically re-set idle mixture screws and check the timing and valve lash until things stop changing. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Mar 16, 2013 7:20 am Post subject: |
[email protected] wrote: |
this is not unusual for a fresh engine. Things should stabilize as it gets more miles on it. Just remember to periodically re-set idle mixture screws and check the timing and valve lash until things stop changing. |
for sure! i plan on doing some work with a LM-1 at some point too. i will either rent yours or see about borrowing a friends. i want to get her all dialed in the best i can _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Thu May 23, 2013 5:17 am Post subject: |
Hey skills, are you going to have that mill dialled in by Litchfield? Looking forward to seeing it and swapping lies.
See you there.
Marshall _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3331 Location: 802 The Pointless Forrest
Posted: Sat Dec 08, 2018 3:56 pm Post subject: Re: My attempt at a 1904 |
OK so is thing still running?
Still using that 010 distributor? _________________ "Albatross"! |
Danwvw Samba Member
Posted: Sat Dec 08, 2018 5:19 pm Post subject: Re: My attempt at a 1904 |
Some oil filters drain back and this can make quite a bit of difference on a dip stick readings. I had to try several brands etc to find one that worked well.
The Hastings LF493F seemed to work well to stop it. As did the Wix-51342 These filters do have a higher bypass valve pressure of 16 PSI Whereas the usual VW Type 1 Engine and type 4's use a 6 or 7 psi bypass pressure. Perhaps this is why they solve the problem.
I have noticed that the 74mm Crank does pick up the oil and blow it out of the engine If I drive above 75 MPH for a long time. Perhaps yours was just too full of oil so it was smoking.
My engine didn't really settle in and have Zero valve adjust needed until It had about 15,000 on it and I switched from Castrol 5W30 to Mobel 1 0W40 and quit adding the ZDDP.
Took it out on the Interstate for a 100miles at 75mph or more. It was like 95' degrees out that day too. It went through a 1/2" quart of oil doing that but it broke it in. Valve adjustments are stable now and no smoke at all and it's not using any oil if it stay below 70mph.
I don't really have a proper breather setup on mine.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
