Major Problem?
rickb67
rickb67 is offline
PostPosted: Tue Jul 17, 2012 8:25 pm    Post subject: Major Problem? Reply with quote
I have been searching the forum high and low for a similar problem. I have a rebuilt engine. It was line bored and everything was balanced. I installed it into the vehicle and hooked up everything. The car sat without an engine for about 5 years.
I cranked it by hand first. It doesn't seem hard to crank except once in a while it seems like there is a dragging feeling and a light noise. It almost feels like two gears rubbing each other. I tried to note at what degree on the crank oulley it occurs, but it isnever the same.
Could this be a starter bushing issue? It's a 67 beetle.
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Jul 17, 2012 9:27 pm    Post subject: Reply with quote
Did you install a different/new cam shaft??
In Stereo, Where Available!
jzjames
jzjames is offline
PostPosted: Tue Jul 17, 2012 10:35 pm    Post subject: Reply with quote
It might not rotate uniformly smooth through the revolutions.
Get the starter in with a new bushing and crank it over.
rickb67
rickb67 is offline
PostPosted: Wed Jul 18, 2012 6:04 am    Post subject: Reply with quote
Yes it has a new cam. Engle 110
Joey
Joey is offline
PostPosted: Wed Jul 18, 2012 6:17 am    Post subject: Reply with quote
Did you check the backlash of the new cam gear?
Did the gear 'walk out' of the case half when turning the crank CCW during assembly?
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
drscope
drscope is offline
PostPosted: Wed Jul 18, 2012 7:49 am    Post subject: Reply with quote
Did the engine also sit for 5 years or is it fresh?
rickb67
rickb67 is offline
PostPosted: Fri Jul 20, 2012 6:21 pm    Post subject: Reply with quote
The engine is a fresh rebuild.
Alte Blechdose
Alte Blechdose is offline
PostPosted: Fri Jul 20, 2012 6:51 pm    Post subject: Reply with quote
Gear timing or camshaft might be off time , I would tear it back down myself and check for rubbing . It can be anything . I bought some rods recently to go with a new piston set , The bushing for the rod link pin on one was a little snug . It didn't seem to bind until the jugs had been installed .
Took some 600 grit paper and cleaned the bushing lightly ( On smooth flat surface ) , No binding afterwards . Had a similar problem with double thrust cam bearings recently and had to clean up the thrust to get end play right . The little details kill ( Don't ask how I know ) .
Alte Blechdose
estolze
estolze is offline
PostPosted: Fri Jul 20, 2012 9:51 pm    Post subject: Reply with quote
cam gear bolts rubbing on oil pump??
Cousin of a Porsche
Cousin of a Porsche is offline
PostPosted: Sat Jul 21, 2012 7:53 pm    Post subject: Reply with quote
Did the engine turn freely out of the car? If it did what size fly wheel and transmission are you using? I have a 67 and when I got my new transmission I had to clearance it for the 12 volt fly wheel. The transmission was clearanced but it still hit slightly when I turned it over. I would check that before you tear an engine down, maybe you'll get lucky. Good luck.
67 Bug w/2110
1980 911sc looks faster than it is!
I can't help it I am what I am.
Alte Schule Vintage and Performance VW club
BKC #022 (Well at least that is what the jacket says)
