scottssoccer Samba Member
Posted: Sun Jul 22, 2012 7:56 pm Post subject: turn signal wiring |
wiring my 66 bug,I have a total of 5 wires coming out of the turn signal .brown/white,brown,black /white/green,black/white and black/green.can someone help with where the brown/white and brown wires go?these wires come out turn signal located inside car. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Jul 22, 2012 8:41 pm Post subject: |
In the tech/witing/type 1 section in the top menu above, you will find:
Posted: Sun Jul 22, 2012 9:02 pm Post subject: |
There is no solid brown wire in this diagram.that seems to be the same no matter where i look. |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Sun Jul 22, 2012 9:17 pm Post subject: |
I see a solid brown wire...
The headlight dimmer switch ground... it grounds the switch on one of the speedo mount screws. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
EVfun Samba Member
Posted: Sun Jul 22, 2012 10:28 pm Post subject: |
scottssoccer wrote: |
In a VW brown is ground. Any terminal on a brown wire should show a good connection (0 ohms) between that terminal and the body or frame. _________________
Wildthings wrote: |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Mon Jul 23, 2012 4:52 am Post subject: |
Its the short wire on the turn signal switch - look carefully. Its a ground and its for the headlight dimmer. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Jul 23, 2012 7:14 pm Post subject: |
Right on!Located it ,it was on the speedo screw!Thank You . |
