Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Mon Jul 23, 2012 1:46 pm Post subject: Pressure Relief Valve Spring Length |
I've been searching a good bit and can't seem to find a good answer on this. I'm looking for the unloaded length of both the pressure relief and pressure control. Any help is appreciated. |
mark tucker Samba Member
Posted: Mon Jul 23, 2012 1:50 pm Post subject: |
I just get new ones.but some are weaker than the oe ones, and then there is the boster springs,I like the booster on the pressure relief,but not a real stiff spring on the oil cooler valve spring,but a little stiffer than the oe cooler spring. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4916 Location: Southern AB
Posted: Mon Jul 23, 2012 2:51 pm Post subject: |
Springs are a funny thing.......
the unsprung length is not so much a factor as the gauge of the wire, how many coils, and the pressure it takes to compress them to a given height.
There was a thread a while back about the spring pressures of the stock springs VS aftermarket replacements. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
jhoefer Samba Member
Posted: Mon Jul 23, 2012 3:58 pm Post subject: |
Oil control spring specs for type 1 - 3
Code: |
pressure relief
Year Loaded Length Load @ Length
68-69 1-11/16 in (43.20 mm) 5.5 - 9.2 lb
70-79 1-3/4 in (44.10 mm) 12.3 - 16.0 lb
oil control
70 13/16 in (20.20 mm) 6.3 - 7.9 lb
71-79 13/16 in (20.20 mm) 6.8 - 8.4 lb |
These are supposed to give you 42 psi using 30W oil at 158*F at 2500 rpm. Wear limit is 28 psi. |
