Spark Plugs not firing, coil getting extremely hot.
Twest451
Twest451 is offline
PostPosted: Mon Jul 23, 2012 7:05 pm    Post subject: Spark Plugs not firing, coil getting extremely hot. Reply with quote
I have a 1963 beetle baja. The engine was running but had a severe popping issue. I notice a bad air leak in the carb so I took it off and sealed the gasket that was leaking. After doing this, the car wouldn't start. It would crank but it wouldn't start. At first I assumed it was the carb since the problem happened right after I messed with the carb. However after inspection, I realized the carb is sucking air and getting gas so it cant be the carb. I realized the spark plugs weren't firing so I began to diagnose the ignition system. I had a 6 volt coil in before hooked up to a 12 volt battery. I bought another 6 volt coil and installed it and it didn't work. Then I bought a 12 volt coil and installed it and it still wont start. I heard it may be my condenser and points so I checked and they dont appear to be fried or anything. I just cranked the engine with the distributor cap off and the coil became so hot I couldn't touch it for more than a second without being burned. I am wondering what the problem could possibly be. The spark plugs still aren't firing. The negative wire from the coil isnt hooked up to anything, however my condenser doesn't have a spot for it and the car started just fine before and the negative wire wasn't hooked up to anything. Please help Very Happy
Culito
11010101
Culito is offline
PostPosted: Mon Jul 23, 2012 8:32 pm    Post subject: Reply with quote
Sounds like you need a basic reference manual of some sort.
The negative side of the coil hooks to the condenser. The positive side to the ignition switch.
Copyright CJ Industries, Inc.
'64 standard
'62 bug
johnnypan wrote:
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Mon Jul 23, 2012 10:09 pm    Post subject: Reply with quote
As above- Me thinks you are having an issue with your condenser. It may look fine but... The condenser wire is supposed to go to the negative side of your coil.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
61SNRF
61SNRF is online now
PostPosted: Mon Jul 23, 2012 11:15 pm    Post subject: Reply with quote
Not sure what you mean or what you may have done, so just start with the basics.
If the coil is getting too hot with the key on while cranking, it's probably because it is grounded all the time and current is constantly flowing through it. That is not supposed to happen during normal operation/running.
It's the points job to ground the coil on and off much like a switch at regular intervals (with some dwell time) when the engine/distributor rotates. If it's grounded all the time, a coil will get very hot, and run your battery down pretty quick too.
If you can see that the points are opening and closing and they were working before, then you may have wired something wrong. As in the diagram above, the black wire to coil terminal #15 should have 12v power only when the key is on or while cranking. The green "negative" wire from the coil terminal #1 does not go to ground, it goes to the points only. It should not touch the distributor body or any other ground.
The condenser is not shown in this simplified drawing, but it's main function is to suppress the arcing of the points. It's lead wire is connected to the points/coil "negative" terminal #1 in parallel only, and it does not connect to the distributor body or any other ground except at it's mounting base.
Hope this helps, and please post a picture of your coil/distributor/wiring if you have any other questions.
-Bruce
An ounce of prevention is worth a pound of cure.
Greg!
Greg! is offline
PostPosted: Tue Jul 24, 2012 5:46 am    Post subject: Reply with quote
I would also start with replacing the points and condensor.
drscope
drscope is offline
PostPosted: Tue Jul 24, 2012 7:35 am    Post subject: Re: Spark Plugs not firing, coil getting extremely hot. Reply with quote
It CAN'T run without the wire from the negative side of the coil to the condensor/points.
Greg!
Greg! is offline
PostPosted: Tue Jul 24, 2012 7:57 am    Post subject: Re: Spark Plugs not firing, coil getting extremely hot. Reply with quote
I didn't catch that part.
Yeah what gives...it has to be connected.
