mxracer Samba Member
Posted: Wed Jul 25, 2012 8:01 am Post subject: Cam choice for 1300 build... |
I recently picked up a numbers matching 66 bug. The old 1300 is pretty tired and I'm going to rebuild it. Not interested in bumping it to a 15 or 1600, I want to keep it a 1300.
On the flip side, sort of, I'd like to do a "fluff and buff" on the heads and maybe put a cam in it to get just a little more out of it. The end goal is to create a "period correct" type performance engine. It's more for nostalgic reasons than anything else.
So, would maybe a CB cheater work nice for that or something else or should I just stick with the stock cam?
BTW I'm also kicking the idea around of putting a Judson on it, again more for the period/nostalgic type idea. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Wed Jul 25, 2012 8:33 am Post subject: |
The 2280 is a very good choice, - along with a compression raise to at least 8, preferably 8,3 to 8,5 - 1 dependant on your choice of fuel.
I rebuilt a couple of 1300 sgl. ports about 1½ years ago. Installed a 35,5 mm inlet valve though, along with cleaned up heads better valve job etc. They pull 52ish hp and 100ish NM torque. They keep up with stock stock 1500 engines without a problem.
T
PS. I forgot to write, that I also ligthened the flywheel 1 Kg and of course balanced the rotating assembly. I also used a quality stock exhaust (Ernst)
The lighter flywheel makes the engine much more "fresh" in lack of a better word. It takes a lot of the lazyness away and it does only barely affect idle take off. |
Posted: Thu Jul 26, 2012 11:52 am Post subject: |
Thanks Alstrup.... seems there is not many people who like the small engines. |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Thu Jul 26, 2012 11:57 am Post subject: |
mxracer wrote: |
I love em _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Jul 26, 2012 6:31 pm Post subject: |
X2 on the Cheater cam.....with a set of CB's Lightweight Racing Lifters. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
