Robw_z Samba Member
Posted: Wed Jul 25, 2012 1:16 pm Post subject: Replace radiator fan without draining coolant? |
Hello,
my radiator fan has been making very unhealthy noises for a long time, got a good used replacement. I really don't want to drain the coolant for this job... It is recently new and has been flushed. it looks like if one were bold and careful enough, you could disconnect the plastic fan from the motor, remove the fan through the shroud while still in the van, and then have enough room to remove the motor as well. Install new as reverse of removal. Anybody done it this way or something similar? The most difficult part would be removing and reattaching the fan circlip blind while laying on your back under the van.
My van is a 1990 without A/C, and has the 3 blade fan.
-Rob |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9935 Location: Orbiting San Diego
Posted: Wed Jul 25, 2012 1:32 pm Post subject: Re: Replace radiator fan without draining coolant? |
This is why the front radiator hoses are so long. They let you lower the radiator without unhooking it from the cooling system. It is very heavy when full and need s to be lowered by a jack so it can be raised back up with the jack.
Mark
Robw_z wrote: |
Hello,
-Rob |
Robw_z Samba Member
Posted: Wed Jul 25, 2012 8:07 pm Post subject: |
Thanks got the job done. |
rotaecho Samba Member
Joined: October 14, 2012 Posts: 513 Location: Nomadic Vanlifer
Posted: Thu Feb 12, 2015 11:01 pm Post subject: Re: Replace radiator fan without draining coolant? |
Would there be enough room to replace the shroud as well (got the wrong AC and have a non-AC coming in) or that's a little larger requiring the draining?
Thanks!
crazyvwvanman wrote: |
Mark
Robw_z wrote: |
Hello,
-Rob |
_________________ -Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com |
insyncro Banned
Posted: Fri Feb 13, 2015 4:58 am Post subject: |
I have not seen that many early vans but if you remove the retainers holding the pipes to the chassis, just above the steering rack, you gain a few precious extra bits of room to lower the entire rad asembly which allows for the six self tappers to be pulled and shroud removed.
The long hoses will be bent to get the top ones.
Support the assembly well, it is heavy well filled with coolant.
Your shroud will ship Monday AM. |
