Transmission Cooler flow
Page: Previous  1, 2
James 93SLC
James 93SLC is offline
PostPosted: Sat Feb 09, 2013 7:02 pm    Post subject: Reply with quote
The answer is in the post above yours. It comes out the bottom and back in at the top.
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka"
Azul Tortuga
Azul Tortuga is offline
PostPosted: Sat Feb 09, 2013 10:36 pm    Post subject: Reply with quote
I too turned the engine over with the lines disconnected and fluid came out of the bottom hose. I hooked up my mocal tstat and external cooler a year ago and have had it work flawlessly for several thousand miles that would include hard driving conditions. Temp gauge on the pan is usually reads around 165 but will climb to 180 on 100 degree days while sustaining freeway speeds. Very happy all in all.
Nick
1991 Westfalia Weekender, auto,power, ac. GW lift springs
Red Beard
Red Beard is offline
PostPosted: Sun Feb 10, 2013 11:23 am    Post subject: Reply with quote
Excellent, thank you guys.
Mods: possible to delete the above posts that contain conflicting information, for posterity?
Energy Concepts
Energy Concepts is offline
PostPosted: Sat Jun 30, 2018 5:29 am    Post subject: Reply with quote
So, Wink Which port, ( top or bottom )
would be best to have a Oil Filter Located ?
I have an external cartridge oil filter.
I'm (guessing ;o) just before it re-enters the Transmission?
Also, I'm having trouble getting the fan to come on!
I have the:
Electric Fan Control, On 180 Degrees, Off 165 Degrees, Kit
DER-16730 from Summit.
My Question is; where should it be located
& does it matter?
I have it away from the trans next to the Fan,
and I'm wondering if the fan control
Isn't getting Hot Enough to activate the fan?
So, I'm thinking perhaps it should be next
to the Outlet (bottom ) of the Transmission ?
Location,,, Location Exclamation Idea Shocked Laughing
Thanks!
John C...
Page: Previous  1, 2
Page 2 of 2
