vwfye Samba Member
Posted: Sat Aug 11, 2012 9:52 am Post subject: |
Tram is human! Actually.... I saw the problem when I started reading this post.
He went into the house and sipped on a soda. WTH man? Since when did you start working sober _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sat Aug 11, 2012 10:45 am Post subject: |
Tram wrote: |
If it has fasteners, that's even better. |
Speaking of fasteners... did some years use one of the screws as a grounding point? I vagely remember seeing one with a tab for a ground wire, but I can't find it now. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Aug 11, 2012 11:49 am Post subject: |
KTPhil wrote: |
Tram wrote: |
Yes, it was the grounding point for the low/ hi beam system. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Aug 11, 2012 11:50 am Post subject: |
vwfye wrote: |
He went into the house and sipped on a soda. WTH man? Since when did you start working sober |
Yesh. Thash mush be it. I'm the Dean Martin of VWs. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Aug 11, 2012 11:57 am Post subject: |
This '67 fuse block that Ning is bringing you this PM does have a grounding lug on one mount.
P.S. Cars have been known to teach you humility! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Aug 11, 2012 12:07 pm Post subject: |
Mike Fisher wrote: |
P.S. Cars have been known to teach you humility! |
And... that's a cost billable directly to the customer! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Sat Aug 11, 2012 1:27 pm Post subject: |
Tram wrote: |
And... that's a cost billable directly to the customer! |
Tram, call me or PM me your phone #. New phone, no numbers transferred and I need to find out something from you! _________________ 64 No'back Speedster "Pearl"
Posted: Mon Sep 10, 2012 8:36 am Post subject: |
Tram wrote: |
Woreign wrote: |
Mike's always saying how "Tram fixed this" or "Tram fixed that" or "Tram always does it this way"... Maybe you're being too nice to him? |
Mike's OK. His car, I want to light on fire. |
Eat your heart out Woreign that you don't live 20 miles from Tram! _________________ https://imgur.com/user/FisherSquareback/posts
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Mon Sep 10, 2012 12:43 pm Post subject: |
Tram wrote: |
Woreign wrote: |
P.S. Eat your heart out Woreign that you don't live 20 miles away from these guys! |
I have half a mind to make Oregon my next assignment and bother you guys, but unfortunately, there aren't any active duty DoD bases there. What's up with that?
I searched USAJobs and the only computer position is in Portland with a NOAA weather station. Not my area, so you're safe for now! |
Posted: Tue Sep 18, 2012 11:38 am Post subject: |
I got my car back with fresh generator/Temp Sensor/NOS fuel injection harness/spark plug insert/'72 beam/front brake pads/windshield/rubber etc. I guess they had to lower it 2 splines to get it to sit correct. It is running good and steers like a go kart again!
Tram futzed with the kickdown switch, but I had to pull the fuse again to actually get it to shift right as Borg-Warner intended. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Tue Sep 18, 2012 12:52 pm Post subject: |
Tram futzed with the kickdown switch, but I had to pull the fuse again to actually get it to shift right as Borg-Warner intended. |
Tram did not futz with the kickdown switch, my very good friend! In fact, that's one of the few things I didn't have to futz with! Something's up. Didn't do that on a road test for me. You also got a rear wheel cylinder in the deal and your good fusebox installed. Glad it's running well, but would like to check out that kickdown deal before you go to Cali. You might need it in the passes. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Sep 18, 2012 4:40 pm Post subject: |
My generator light came on while I was downtown, so I hurried out to Tram's! He massaged the brushes and commutator and the light went out. He loaned me his NOS generator for my trip to Redding, CA tomorrow just in case.
It turns out he had one kickdown switch wire on the WRONG terminal. It does seem to be working real well now hooked up copasetic! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Tue Sep 18, 2012 6:12 pm Post subject: |
It turns out he had one kickdown switch wire on the WRONG terminal. It does seem to be working real well now hooked up copasetic! |
I don't think I did it, but when you're on painkillers...
The hell of it is with your gen. is that the commutator got dirty again so fast. At least you'll have the "loaner" if you need it. Lucky for you the project it was earmarked for is getting an alternator instead. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
FergU Samba Member
Joined: August 07, 2011 Posts: 267 Location: Huntsville, AL
Posted: Tue Sep 18, 2012 6:37 pm Post subject: |
Oh to be in an area of the country where Type 3 parts are there for the taking... must be nice! _________________ 1962 Type 1
1963 Type 14 - Karmann Ghia "Sadie" (Restoration progress - http://vwsexysadie.wordpress.com)
1972 Type 3 - Squareback "Joseph" (Restoration Progress - http://jpdproject.wordpress.com/) |
Posted: Mon Sep 24, 2012 8:09 am Post subject: |
We had to drive the last 200 miles down with the generator light on, but made it to Redding. Bought new brushes at Wolfgang International, but they didn't help! My buddy gave me a portable jump starter/compressor unit when I stopped at his Car Lot with the generator light on. I installed Tram's generator the next morning and sweet success! A good high school reunion/visit to Redding. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Sep 24, 2012 11:41 am Post subject: |
We had to drive the last 200 miles down with the generator light on, but made it to Redding. Bought new brushes at Wolfgang International, but they didn't help! My buddy gave me a portable jump starter/compressor unit when I stopped at his Car Lot with the generator light on. I installed Tram's generator the next morning and sweet success! A good high school reunion/visit to Redding. |
Wonder WTF is up with that other generator? Electrical stuff is usually either good or it's bad... but a generator that charges sometimes??? What a pain in the ass! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
bugginmiami Samba Member
Posted: Mon Sep 24, 2012 1:43 pm Post subject: |
Sounds like its time for an alternator! _________________ * ---www.volksblast.com--- *
* -- South Miami - Feb 12th 2017 *
johnnypan wrote: |
Never mess with a cat who smiles for his mug shot..he gives way less of a fuck than you do.. |
Posted: Mon Sep 24, 2012 2:45 pm Post subject: |
Tram wrote: |
Wonder WTF is up with that other generator? Electrical stuff is usually either good or it's bad... but a generator that charges sometimes??? What a pain in the ass! |
You have to remember who it belongs to. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Sep 24, 2012 2:51 pm Post subject: |
Bobnotch wrote: |
Tram wrote: |
You have to remember who it belongs to. |
This was one of my good used ones with new brushes... the one that spun right off when I polarised it. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
