05gh Samba Member
Joined: September 01, 2011 Posts: 157 Location: The Netherlands
Posted: Sat Aug 11, 2012 3:27 pm Post subject: ignition switch |
The headlights do not work, I discovered that this is due to a faulty ingnition switch. (I removed the connector from the ignition switch and have the red and black/yellow wire shorted and then I could operate the headlights). Is there an easy way to replace the switch? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 11, 2012 4:16 pm Post subject: |
What year is your bus? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat Aug 11, 2012 4:43 pm Post subject: |
busdaddy wrote: |
What year is your bus? |
'79 from earlier posts... _________________ '71 Westy |
05gh Samba Member
Posted: Sun Aug 12, 2012 2:49 am Post subject: |
busdaddy wrote: |
california 79 |
hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Sun Aug 12, 2012 4:21 am Post subject: |
There a breeze to do. Do it on a early bay ! _________________ Karl Bower |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Aug 12, 2012 1:49 pm Post subject: ign switch |
If you don't have the Bentley repair manual then go
here. www.ratwell.com and scroll down to #78 [STEERING COLUMN]
in the tech section.
With a bus as old as yours it's likely the Shear bolt for the column
has already been replaced with an allen type .and is is an easy job
on a 79.Make sure when you are done to check the steering wheel
to housing gap and adjust accordingly. _________________ V.W.owner since 1967 |
05gh Samba Member
Posted: Sat Aug 18, 2012 2:27 pm Post subject: Re: ign switch |
old DKP driver wrote: |
to housing gap and adjust accordingly. |
thanks, indeed the the Shear bolt for the column
was already been replaced |
