wyomingresident Samba Member
Joined: April 22, 2007 Posts: 246 Location: Jackson Hole
Posted: Mon Aug 13, 2012 9:04 am Post subject: Zoinks Scooby! Tell me about my new sorta fast oil leak... |
My 1984 Westy couldn't be running better. As Mr. Cash would put it, "...it's running just like a song...".
I took some major road trips last Autumn 2011 (Seattle & Phoenix) and a major Wyoming to Cape Hatteras trip with the kids this past Spring. Heavy loads.
I've had the 1.9L Van since 2001. It had ~184K when I bought it. Now @ 235K. Maybe new heads along the way before I got it. Hard to say. Seems to be coming from the front left area.
After getting it up to temp and parking it, there us a 4-5 inch oil spot showing up pretty quick- eventually stopping when the engine cools down.
Thanks in advance! _________________ Don't tell fish stories where the people know you; but particularly, don't tell them where they know the fish.
Mark Twain |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Aug 13, 2012 9:31 am Post subject: |
Several possibilities but one that is easy to check and cheap to fix -- I had a similar leak diagnosed as a main seal but upon inspection I found a split in the underside of the hose from the breather tower to the S-boot.
With the '84 having no restriction in that hose (unlike later engines) a fair amount oil oil could collect there and drip thru the slit.
Another 'cheap & easy' suspect is, of course, the valve cover gaskets -- which do fail from time to time.
Good luck, hope yours is something equally trivial. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Aug 13, 2012 12:10 pm Post subject: |
Ummm...LEFT side...as in DRIVER's side? Where EXACTLY are the drips? Pics?
It's not the pressure sender between the pushrods? (might need to move the tin)
Not the oil filter...or the drain plug...???
(Easy questions first) _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
