headlinerbows and more
hobbybob517
hobbybob517 is offline
PostPosted: Tue Aug 14, 2012 1:36 am    Post subject: headlinerbows and more Reply with quote
Hi guys, got a challenge on my hands here,
doing the headlinder on my 73 super
got a nice headliner cut, and now i was wondering if the bows actualy snap into any slots?
or do i just guess where they go?
also anybody got any good how to's?
THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote:
3 million rpm? Well there's your problem! No wonder it blew up!
mtdorajohn
mtdorajohn is offline
PostPosted: Tue Aug 14, 2012 3:13 am    Post subject: Reply with quote
the bow's float in the groves... that way you can adjust them as you pull the headliner into place.
pull everything tight as you work from one end to the other, working the bows to make sure the headliner looks tight and pretty.
johnnypan
johnnypan is offline
PostPosted: Tue Aug 14, 2012 5:24 am    Post subject: Reply with quote
Last time I checked they go inside the car..
get a hundred of these,they come in handy for fitting around windows and removing wrinkles..
hobbybob517
PostPosted: Tue Aug 14, 2012 9:13 am    Post subject: Reply with quote
O yeah, i got like a hundred of these, and also some smaller ones
19-VW-74
19-VW-74 is offline
PostPosted: Tue Aug 14, 2012 9:23 am    Post subject: Reply with quote
Get the Jbugs DVD. I watched it like 10 times, now I know it like the back of my hand. I installed my headliner in 3 hours without any helpers.
-Austin
My 1974 Standard Beetle Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=492617
hobbybob517
PostPosted: Tue Aug 14, 2012 9:24 am    Post subject: Reply with quote
not bad,
but i live in the netherlands, i looked around for the DVD's like bug me, and j bugs instruction DVD , but i can't find it
hobbybob517
PostPosted: Tue Aug 14, 2012 9:28 am    Post subject: Reply with quote
what is the carboard trick btw?
Eric 73
Eric 73 is offline
PostPosted: Tue Aug 14, 2012 10:26 am    Post subject: Reply with quote
The cardboard (which really should be called chipboard - like the stuff shoeboxes are made from) is used above the door, where the liner tucks in. Glue 1" strips of chipboard to the metal (not covering the opening). This way you can glue the liner to the chipboard and tuck in the overage later.
Silence is golden...unless the dumb question you should have asked lands you in the emergency room.
19-VW-74
19-VW-74 is offline
PostPosted: Tue Aug 14, 2012 10:28 am    Post subject: Reply with quote
Right above the doors, there are "grippers" that the headliner folds over and into. The headliner needs to be pulled straight out, glued down, then cut to length and folded into the crevice under the grippers, and then the grippers need to be hammered down, all basically in one step. All the while maintaining a taught surface with no wrinkles. To make it a helluva lot easier, glue a 1"x18?" piece of thin carboard along the grippers and let the glue set. Then cover the cardboard with contact cement. Then paint the vinyl that will be touching the cardboard with contact cement. Let the contact cement set up for maybe 5 minutes. Then pull on the vinyl to get rid of the wrinkles and then press it against the cardboard. Make sure it sticks REALLY good. Then cut the vinyl so about a 3-4cm flap overhangs over the grippers. Take a plastic putty knife or spatula and use it to press the flap into the little crevice under the grippers. To finish, take a rubber mallet (wrapped in a cloth to prevent scuffing) and hammer the grippers shut. And you're just about done.
-Austin
hobbybob517
Any pics of this technique?
jwold
jwold is offline
PostPosted: Tue Aug 14, 2012 11:15 am    Post subject: Reply with quote
Google yielded this:
http://www.vwtrendsweb.com/tech/0409vwt_headliner_install/
Lots of info on the Samba too...
jbugs video is worth it, use the paint-on adnesive rather than the spray on stuff...
shakers73
shakers73 is offline
PostPosted: Tue Aug 14, 2012 6:28 pm    Post subject: Reply with quote
hobbybob517 wrote:
not bad,
I've got an extra jbugs interior video. If you're interested pm me.
shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish.
