William Crowell Samba Member
Joined: February 15, 2011 Posts: 71 Location: Placerville, CA
Posted: Tue Aug 14, 2012 5:28 am Post subject: Need a recommendation of a 356 resto book |
The next job on the resto of my '60 T5 is to pull a new wiring harness into the tunnel. Since I had a hard time getting the old harness out, I'm sure that putting the new one in won't be easy unless I have really good instructions. I already have the reprint of the FSM and several other 356 books, but none of them describes in detail how to install a harness. Can anybody recommend a 356 resto book that does so? Thanks a lot. |
356JAEGER Samba Member
Joined: May 19, 2007 Posts: 444 Location: Norte California
Posted: Tue Aug 14, 2012 6:39 am Post subject: |
William
Your new wiring harness should come with a detailed set of instructions for installation. If you don't have one, contact Y&Z's or one of the other manufacturers of wiring harnesses and they should have what your need. _________________ Regards,
Joel Jensen
When in doubt, think about it..
The outcome of a project is directly proportional to its preparation. |
bbspdstr Samba Member
Posted: Tue Aug 14, 2012 4:32 pm Post subject: |
I am using the Ron Roland book more and more. The Kellogg books are fine and together with the WSM, there is about all you could need other than to ask here for details or specifics.
Try Block's Books for sourcing.
IF you made notes during disassembly, the wiring is only difficult in tight passages, like the tunnel's upper right corner longitudinal passage, where often a wire lube can be used, but a new harness is less kinked and more supple. Two people work best, one pulls a lead wire and then the harness itself and the other guides and makes sure no snags are encountered.
If the welded strips on the undersides of things are intact, they guide you pretty much where loom splits go. As posted, the instructions that come with a new harness will show what ends up where, so it's not all that bad or time-consuming. _________________ Bruce Baker
www.356restoration.com
Posted: Wed Aug 15, 2012 5:32 am Post subject: |
Thanks, guys! |
