veedubfreak59 Samba Member
Joined: February 22, 2010 Posts: 228 Location: Denver, CO
Posted: Tue Aug 14, 2012 6:22 pm Post subject: Replacing rear bumper mounts |
I've searched the forums, but haven't found what I'm looking for. What is involved in replacing the rear bumper mounts? The part that is attached to the rear wheelwell. All 4 of my bolts got snapped off during disassembly, and the previous owner was kind enough to weld 1 of the brackets to the car.
Also, while I'm asking questions, how do I get the inside part of the shock mount off of the front shock bolt. Do I just need to get some heat on it with a set of vice grips? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Thu Aug 30, 2012 6:47 pm Post subject: |
Did you replace the whole quarter or did you drill out the replacement also. Both sides of mine are rusted out, I drilled out the driver's side tonight, but I need a better drill bit to finish up the passenger side. Anyone know if it's possible to buy replacement pieces? |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Thu Aug 30, 2012 8:30 pm Post subject: |
You can, or you can try to find metal from other vws and weld in replacements with old metal. Wolfsburg sells most of these parts, and they rarely get faulted for quality. That said, the old metal is almost always thicker, heavier duty stuff in my experience. Depending on the year of your car and the style bumper mount, it may be easy to drill out the old spot welds, clean the area and weld in any rusted out spots, and then weld an og mount using plug welds. I did this by driling 3/8 inch holes in my mount wherever there had originally been a spot weld, and plug welding them in the same spots to the metal. If you do a nice job, it looks a lot like the original spot welds, and you end up with the same gauge steel as original.
I can't believe po's would actually weld brackets to the mounts. What a bad idea.
What year is your car? _________________ Plate of shrimp |
Posted: Thu Aug 30, 2012 9:44 pm Post subject: |
veedubfreak59 wrote: |
Did you replace the whole quarter or did you drill out the replacement? |
I only replaced the actual bumper mount. My car was a '66 and the mount is unique to 1966/67 only, so no reproductions available. I had to find a donor piece. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Thu Aug 30, 2012 9:47 pm Post subject: |
What year do you have? If you're searching for 1961-65 bumper mounts, you're in luck. Lots of venders carry replacement mounts. Part #111809635A for the Left side. Part # 111809636A for the Right side. Replacements run about $20/ea
I suggest www.wolfsburgwest.com _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Glenn A Samba Member
Posted: Thu Aug 30, 2012 9:58 pm Post subject: |
Mine was just slightly kinked with one bolt snaped off in it. The inner metal also had a rust hole in it behind the bumper mount. The after market panel is not that bad it just needs a little tweek along the bottom edge to make it look good.
finished product. Aftermarket metal. you'll need to seperate the apron if you do it this way.
mannys66 wrote: |
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it. |
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R |
Posted: Fri Aug 31, 2012 9:15 am Post subject: |
Car is a 58, initially bought it thinking it was a 59, thus the name. I actually was able to grind off the bumper bracket last night. Then went about dulling 5 or 6 drill bits to remove the bumper mount.
This is the driver's side. The passenger side is going to require a lot of metalwork as there is tons of rot behind the bumper bracket. |
Posted: Fri Aug 31, 2012 1:12 pm Post subject: |
Depending on how accurate you are focusing on your car's repair, Pre '60 bumper mounts are double the price. If you settle on the 1961-65 style, they will fit & work correctly, just NOT look correct.
Here's some 1953-60 mounts-
http://www.thesamba.com/vw/classifieds/detail.php?id=1223880 _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Fri Aug 31, 2012 2:35 pm Post subject: |
An extra 40 bucks isn't that big of a deal really. Rather spend the money now and do it right than have to do it later when I actually go for a proper resto. |
Dauz Samba Member
Posted: Sun Apr 07, 2013 6:14 pm Post subject: |
Apologies for the ignorance, but how exactly do you get these off? From what I'm getting from the thread, grind the face down until you see the spot welds and then drill them out?
Thanks |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2006 Location: Texas
Posted: Mon Apr 08, 2013 4:36 pm Post subject: |
Yeah, you need to sand down the perimiter of the mount until you can see where the spot welds are, then use a spot weld removing bit on the spot welds. I'm getting ready to do this myself. The PO cut mine up and bent both upward when he/she broke some bolts off in them.
_________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Mon Apr 08, 2013 9:05 pm Post subject: |
You have the idea; sand or grind until you see the factory spot welds. I used a 1/8" titanium bit in the center of each weld, followed by a 3/8" titanium bit to drill out each spot weld. You'll see and feel the bracket pop loose as you free each weld with the larger bit. Match your replacement part to the holes you made, clamp, and the plug weld each old spot weld point.
As mentioned, there is a tool for removing spot welds that would do the trick without changing bits. _________________ Plate of shrimp |
Dauz Samba Member
Posted: Mon Apr 08, 2013 9:51 pm Post subject: |
This is what I'm dealing with. I'm going to have to repair the sheet metal behind the mount as well. 20 gauge?
Posted: Tue Apr 09, 2013 1:18 am Post subject: |
I think 20 for the body panel, bracket metal, perhaps 18. _________________ Plate of shrimp |
Dauz Samba Member
jvulich Samba Member
Posted: Mon Dec 15, 2014 11:56 am Post subject: |
I'm getting ready to travel down this road myself on my 65. |
rusty60 Samba Member
Joined: September 15, 2013 Posts: 126 Location: camano island
Posted: Mon Dec 15, 2014 12:13 pm Post subject: |
If you just have a nut that broke free try this,
If bracket is not too damaged or rusty, cut out piece of angle, weld nut on and replace. worked great |
Posted: Mon Dec 15, 2014 12:43 pm Post subject: |
I have one thats bent from a collision thats been poorly repaired and welded on and the other has rust holes on the top of it. for some stupid reason I can't upload pics from my iphone anymore. |
Cabo9302 Samba Member
Joined: September 14, 2014 Posts: 39 Location: DeepInTheHeart
Posted: Mon Dec 15, 2014 2:09 pm Post subject: |
jvulich wrote: |
You have to upload them to the gallery, then copy the picture's "forum URL" and paste it here. |
