secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
Posted: Mon Oct 22, 2012 11:27 am Post subject: |
Hey Kirk- Just wanted to throw a couple of these around for colors. Idk what the OG color codes were, but these colors are what I like to see on nice stripes.
I much prefer this look. Especially the earlier hubs. Will thosee earlier caps just fit on to a late bay wheel I wonder?
THOSE COLORS!!
And now that I see them side by side... The top stripe on the first pic looks like the same shade as the middle stripe on the second pic....interesting.
Kirk, if you have any info on stripes, PLEASE PM ME! _________________ -Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Mon Oct 22, 2012 7:05 pm Post subject: |
Kirk wrote: |
She moves under her own power ish. Hard to wake her from hibernation. I need the "gaskets" under the intake runners now. One was non existant and the other is dust. |
Phenolic blocks. Can you find them local or is a bus depot kind of order? _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Tue Oct 23, 2012 6:39 am Post subject: |
I think its a bus depot order. Imma call around today. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
thisguyfel Samba Member
Joined: June 03, 2011 Posts: 70 Location: Seattle, WA
Posted: Wed Oct 24, 2012 11:57 am Post subject: |
tagged you in one of my instagram shots of a '78 bay, in the same colorway that my family had. i would love to get a hold of it again, and attempt a resto. my dad had donated it when someone looked at the engine and suggested it was going to be too much to repair?! ... this was '95 or so.
but if i was to get a 78, i would much rather a camper. _________________ '91 Tornado Red NAHT'd Carat |
Kirk Samba Member
Posted: Thu Dec 06, 2012 9:23 pm Post subject: |
No real updates yet.
Camped off a towbar weekend before last (peer pressures a bitch) and got super motivated to drive this by the weekend.
Was given a roll of brown upholstery for the seat redo:
Thats all for later. I got a super nifty box o parts:
and my vacuum line kit from German Supply. This is what a $100 kit gets you.
So I pulled the intake runners off tonight so I could replace the pheowhatever blocks. Both were worn, clearly thinner than the replacements, but not as bad as they appeared at first. I have them, so I replaced them. I kept the better of the two old ones for a "spare". Got the vaccum line kit installed. I had several that were cracked pretty bad. I got hung up on the passenger side intake runner. Several things. First, the stud that holds the injector ring in unscrewed from the #1 side. Then #2 the stud is completely stripped. IT spins and wont unscrew to release the clip to release the injector. I assume this is bad, and I worry that the injectors wont seat right if you cant snug that down. I have a spare intake runner that I can use, but they arent side specific are they? Also, look here:
One has a seal and the other doesnt? I thought I remember that the seal should be in the intake runner, not on top as pictured on the right. Thoughts?
Recap:
Intake Runners - side specific?
Stripped studs = replace, correct?
Vacuum Kit = Deal or no deal
Thanks in advance. And big thanks to James (jmitsu76) for answering texts with random garbled messages from me while deep in the bowels of a bus. 'Preciate that.
One day ill wise up and quit messing with FI buses. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Thu Dec 06, 2012 9:27 pm Post subject: |
Love the tires!! |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Thu Dec 06, 2012 9:38 pm Post subject: |
Yes, intake runners are side specific.
Replace the studs, or put a thick washer or spacer over the stud (covering the damaged threads), and then tighten the nut on top of the spacer where the threads are still good. These are not hardened, so 5 ftlbs max.
Vacuum kit? Made my own with OE materials for about the same money, and that covered everything possible. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Posted: Thu Dec 06, 2012 9:56 pm Post subject: |
Westfabulous wrote: |
Vacuum kit? Made my own with OE materials for about the same money, and that covered everything possible. |
Thanks for nothing. I told him the runners weren't side specific. Oh well. I also learn new stuff here everyday.
Kirk. Keep the FI faith brother. Or buy a set of sweet Dell's for the bear. _________________ James
Posted: Thu Dec 06, 2012 10:12 pm Post subject: |
jmstu76 wrote: |
Kirk. Keep the FI faith brother. Or buy a set of sweet Dell's for the bear. |
Sorry James. They will mount on either side, but the plenum is an odd shape, so the runners have a long tube and a short tube to mate properly with the plenum ports. I'm sure you could mount them on either side, but there is a natural fit and not so natural fit. _________________ *****************
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Thu Dec 06, 2012 10:44 pm Post subject: |
Collie wrote: |
Love the tires!! |
X2, give us all the specs on them. That style tire just makes a stock height or lifted bus look like its getting ready for some serious business. I love it. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Kirk Samba Member
Posted: Fri Dec 07, 2012 9:11 am Post subject: |
BF Goodrich All Terrain 195/75/14. Since I bought these, a couple other people on here liked them enough to buy them. (notchboy, skid, couple others) I love them. Heavier than my Vanco2s, but super sturdy and do well on trails.
Bear
Coble
Super
Oppenheim |
Kirk Samba Member
Posted: Fri Dec 07, 2012 9:12 am Post subject: |
jmstu76 wrote: |
Sorry James. They will mount on either side, but the plenum is an odd shape, so the runners have a long tube and a short tube to mate properly with the plenum ports. I'm sure you could mount them on either side, but there is a natural fit and not so natural fit. |
This may explain why they arent seating well at the plenum. Since I have both off to paint, Ill find my spare and see which of these kids is doing the wrong thing. Wonder if I can get injector seals at the FLAPS. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Dec 07, 2012 10:06 am Post subject: |
Kirk wrote: |
Those are BAD.ASS!!!
How's the road noise? MPG? _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
MRshotglass Samba Member
Posted: Fri Dec 07, 2012 12:12 pm Post subject: |
Lookin' good Kirk! I've got a few extra FI parts. If you need anything, let me know. _________________ -Wes
71 Super Beetle - "Squirt" |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Fri Dec 07, 2012 11:57 pm Post subject: |
kirk, are you recovering that blue seat cushion???? i know someone who will buy that off you! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Sat Dec 08, 2012 8:20 am Post subject: |
Kirk wrote: |
jmstu76 wrote: |
This may explain why they arent seating well at the plenum. Since I have both off to paint, Ill find my spare and see which of these kids is doing the wrong thing. Wonder if I can get injector seals at the FLAPS. |
There is a diesel shop that rebuilds injectors of all types. They have the correct seals on hand. This is in Okc though. Makes some calls around your area to FLAPS and diesel injector shops. _________________ James
busboyjake Samba Member
Joined: September 22, 2002 Posts: 393 Location: Colorado
Posted: Sun Dec 09, 2012 8:23 am Post subject: |
jmstu76 wrote: |
Kirk wrote: |
jmstu76 wrote: |
There is a diesel shop that rebuilds injectors of all types. They have the correct seals on hand. This is in Okc though. Makes some calls around your area to FLAPS and diesel injector shops. |
There's one in the Tulsa area too. Thompson diesel. It's around $12 per injector to run them thru the Bosch machine. _________________ 1965 Pearl White Caravelle Camper
1978 Dakota Beige Westy
1969 Montana Red Westy (for sale soon) |
germansupplyscott Samba Member
Posted: Sun Dec 09, 2012 9:34 am Post subject: |
your bus looks great jason. a few years ago i had an opportunity to buy a '78 champagne just like that one and it didn't work out, still wish it had. there's something about that exact model that i really appreciate. _________________ SL |
Posted: Sun Dec 09, 2012 2:04 pm Post subject: |
germansupplyscott wrote: |
your bus looks great jason. a few years ago i had an opportunity to buy a '78 champagne just like that one and it didn't work out, still wish it had. there's something about that exact model that i really appreciate. |
Kirk? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Dec 10, 2012 8:15 am Post subject: |
Stuartzickefoose wrote: |
your bus looks great jason... |
Kirk? |
maybe i got that wrong. _________________ SL |
