rickpereira Samba Member
Joined: May 25, 2010 Posts: 330 Location: Sydney, AUstralia
Posted: Thu Aug 16, 2012 4:09 am Post subject: Twin 40 idf, stock 1600tp, running rich |
Ok so I bolted up the carbs and took the car around the block,
It idled well at cold and revved well through all the gears, however it was blowing a fair bit of black smoke. It was running fairly rich. You could smell petrol in the exhaust.
And now my oil is also contaminated, and smells of petrol.
I followed the best lean procedure and it was still running rich. Pulling the plugs confirmed it as they were extremely sooty from being cleaned just before the best lean procedure.
The carburettor is set up like this:
Idle jets 52
Venturies 28mm
115 main jets
I am thinking dropping my idle jets to a 50 would help lean the mixture, any ideas that will help get me in the ball park for a stock 1600dp? |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Thu Aug 16, 2012 5:29 am Post subject: |
48-50 on idles
115-120 mains
Check fuel pressure and float levels. You should be close to spot on, unless someone has reamed the jets. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Thu Aug 16, 2012 8:07 am Post subject: |
What are you running for airs? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
74 Thing Samba Member
Posted: Thu Aug 16, 2012 8:39 am Post subject: |
Verify fuel pressure and float settings as suggested above. |
Posted: Thu Aug 16, 2012 8:26 pm Post subject: |
ok pulled the carbs out and will be going through the float settings,
i am running a standard fuel pump without a regulator and was getting almost 7psi reading on the gauge,
i know these carbs like 3.5 fuel pressure max. managed to get the fuel pressure down to 3.5 using extra gaskets (just until i can figure out the rich issue)
my air correction jets are 200 |
MURZI Samba Member
Posted: Thu Aug 16, 2012 8:33 pm Post subject: |
Those jets should be really, really close. How many turns from seat are you on the idle jets? And have you set the floats to 10.5-11mm?? If you have not set the floats you will be chasing your tail.
Fuel pressure correction should have helped a lot. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Aug 16, 2012 8:43 pm Post subject: |
When I bought my 40's from CBPerf they had mains stamped 115 but the actual measurment was 130-135, confirm what you have, bet they have been drilled _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Aug 20, 2012 10:53 am Post subject: |
rickpereira wrote: |
There's why you were running rich...7psi fuel pressure. Dumping fuel down the throats. Weber carbs are pretty much like Solex carbs and will not tolerate more than 4psi max. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Aug 22, 2012 4:06 am Post subject: |
Sorry I haven reported back guys, I have had the flu for the las couple of days and it really took it out of me this time, I am a lot better now and almost ready to tackle the carb situation, I may get a fuel regulator before doing anything else, although i already have 50 idle jets in my hands and will throw these in after cleaning the plugs, cleaning the carbs, checking the floats and then see how it goes.
I will report back. Hopefully with good news |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Wed Aug 22, 2012 10:40 am Post subject: |
if you shimmed your pump to get 3.5, you dont need a regulator do you? _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Wed Aug 22, 2012 12:56 pm Post subject: |
Probably not, but I would like to be able to dial it in more precisely. I have found that having the pump idle at 3.5 means that when I rev the engine hard the pressure drops dramatically, hoping that with the regulator it won't be the case |
Posted: Sat Aug 25, 2012 2:48 am Post subject: |
ok so today i pulled the carbs apart and cleaned them out, they were a little dirtyn nothing to drastic (probably happened because i forgot to clean out the fuel line ).
checked the bowls and they were set at 15mm and a drop of 28mm so i set them both to 10mm float level and 32mm drop, replaced the idle jets to the new 50's cleaned out all the main jets, emulsion tubes ect..ect..
so i didnt get to fix the manifolds and carburetor"s back but may do so this week sometime.
i am going to double check my valve clearances and change the oil which is contaminated with fuel, and set the timing so i can get a fresh start on tuning these carbs
i was also told that 98 octane fuel tends to foul plugs on older carburetored cars and to stick to 95 octane, so i may syphon the tank and put some fresh 95octane fuel in there.
Posted: Sat Aug 25, 2012 3:58 am Post subject: |
1, if you get a fuel pressure regulator , dont get the cheap ones with the dial, they dont work.
2, unless you have high compression, dont bother with high octane gas its will give less power and burn less completely.
3, check you spark is powerful, so you dont get false rich look from unburnt fuel due to weak spark. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Sat Aug 25, 2012 4:11 am Post subject: |
How do I check how powerful the spark is? I have a new petronix flame thrower distributor, coil and Bosch leads and spark plugs |
Posted: Thu Aug 30, 2012 3:38 pm Post subject: |
ok so i changed my oil, cleaned my plugs, cleaned the carburetors, checked my valve clearences, set my static timing.
i will try to tune the carbies today. wish me luck |
Posted: Thu Aug 30, 2012 7:16 pm Post subject: |
got the car started and then and through the best lean procedure to find that the 1and 2 cylinder carburettors are not responsive to screwing the idle mixture screw all the way in, so in effect i can never get a reaction from cylinders 1 and 2
cylinders 3 and 4 however i get a strong reaction and get the cylinder stumbling and hunting, so then i back the screw off 1/4 turn.
i suspected a air leak in the manifold of cylinders 1 and 2 but sprayed wd40 all around and had no reaction.
another thing .. if i screw in cylinder 4 to where it is stumbling and then turn it in some more to kill that cylinder off the engine will die, which leads me to believe cylinders 1 and 2 aren't pulling their weight,
what to do? |
Posted: Thu Aug 30, 2012 8:16 pm Post subject: |
Ok do on these two problematic carbs I can completely cover the velocity stacks and nothing happens, the motor doesn't stumble or stall when with cylinders 3&4 will stall the motor, so it is apparent that I have a leak somewhere. Sigh pull carbies off again |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Thu Aug 30, 2012 9:05 pm Post subject: |
A couple of thoughts......first, take heed of what 66brm said. Did you actually measure your main jets to see if they are what is stamped on them? Second, in reading what you've posted, you never mentioned that you synchronized your carbs. Did you? With the linkage disconnected from both carbs? _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Thu Aug 30, 2012 9:57 pm Post subject: |
I bought brand new jets from a reputable carburettor specialist who checked over my other jets as well so I know I am running the correct jets. Also I did synchronism the carbies and they are both set at 4 on the snail synchronizer Before I tried to lean the carbies out. It seems pulling the plugs on cylinders 1 and two has no effect on the engine either |
Posted: Fri Aug 31, 2012 12:52 am Post subject: |
well decided to swap carburettors over from left to right to rule our problematic carburetor.
the carbies decided to start behaving themselves and i was able to tune them at idle.
problem is that while driving they backfired quite a bit through the carbies
knowing that this is a lean condition , i enriched the mixture 1/8 turn on all jets and this minimised the popping ,but it is still there and now i have rich running conditions again.
Back to square one |
