6 volt to 12 volt bushing converision
scottssoccer
scottssoccer is offline
PostPosted: Sun Aug 26, 2012 12:23 pm    Post subject: 6 volt to 12 volt bushing converision Reply with quote
how do i change out this bushing?
Hugo Stiglitz
Hugo Stiglitz is offline
PostPosted: Sun Aug 26, 2012 12:29 pm    Post subject: Reply with quote
How-To: Swap Starter Bushing
'63 slow n low build thread...
Jay Leno's Garage
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o]
BluzBug
BluzBug is offline
PostPosted: Sun Aug 26, 2012 1:14 pm    Post subject: Reply with quote
9/16 Tap ... go thru the Bushing and let it bottom out ...as it bottoms out it will push the Bushing towards you Smile ..... simple operation
BluzBug
BluzBug is offline
PostPosted: Sun Aug 26, 2012 1:17 pm    Post subject: Reply with quote
to install a 12volt Bushing, find a long Bolt that just fits inside Bushing, and build it up with Electrical Tape so it's snug ..... and tap it in
OLD VW NUT
OLD VW NUT is offline
PostPosted: Sun Aug 26, 2012 1:27 pm    Post subject: Reply with quote
Save yourself a lot of work and get an auto-stick starter which has it's own self supported bushing. Pretty much the same price as the manual trans starters - they also have a bit more torque IIRC.
http://vwparts.aircooled.net/Bosch-SR-17-Starter-Rebuilt-12-Volt-SR17-p/sr-17x.htm
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
scottssoccer
PostPosted: Sun Aug 26, 2012 1:45 pm    Post subject: Reply with quote
I don't get it!
scottssoccer
PostPosted: Sun Aug 26, 2012 1:59 pm    Post subject: Reply with quote
How do i get the 6 volt bushing off the shaft?
dan97019
dan97019 is offline
PostPosted: Sun Aug 26, 2012 6:01 pm    Post subject: Reply with quote
The bushing is not on the starter shaft its in the bellhousing bit if it were me and I had the funds I would do what old vw nut suggested and get an auto stick starter and never have to worry about it again.
scottssoccer
PostPosted: Sun Aug 26, 2012 8:13 pm    Post subject: Reply with quote
thanks for the info.I have an old bosch 6 volt starter and seemed kinda inexpensive to go this route.
