New to me westy, AAZ? MTDI?
Page: Previous  1, 2
Syncroincity
Syncroincity is offline
PostPosted: Thu Aug 30, 2012 10:21 pm    Post subject: Reply with quote
The crank pulley is an easy mod. Get a 1Z or AHU TDI crank sprocket (with the D) and simply file a flat spot anywhere on the crank to that profile.
It needs to be press-fit, so go down just enough where it wants to fit, but doesn't slide on; the crank bolt will press it on.
I did mine at home (with the crank out of the block) with a dremel to get close then a flat file to finish it. Go slow, and check the fit often; if you go too big you'll have to weld it and re-shape.
Make sure you have the free-wheel clutch (TDI) pulley on the alternator, too, that's where all the stress comes from that eats up the AAZ sprocket notch; that alternator has got some momentum in it, and the way the diesel motor decelerates to idle rapidly causes big forces on the sprocket.
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
Rallyedude
Rallyedude is offline
PostPosted: Fri Aug 31, 2012 5:16 am    Post subject: Reply with quote
Pics of last night's work [img]
[/img]
Step one of many on the mechanical is done!
Rallyedude
PostPosted: Fri Aug 31, 2012 5:49 am    Post subject: Reply with quote
Where's my tranny code? Maybe I'm blind but I can't find it. Thx
?Waldo?
?Waldo? is offline
PostPosted: Fri Aug 31, 2012 9:23 am    Post subject: Reply with quote
Stock diesel transmissions codes are named for blondes - DZ and DM.
You will want taller gearing for either engine, but the TDI will require custom gears. AAZ is happy with stock WBX or air-cooled trans gearing. I think your $1000 estimate for the added cost of a TDI install is low unless you are comfortable personally re-gearing the trans and building the mTDI pump or doing the wiring and don't give any value to your labor.
Rallyedude
PostPosted: Fri Aug 31, 2012 9:43 am    Post subject: Reply with quote
Dizzy and dumb ?
svenakela
svenakela is offline
PostPosted: Fri Aug 31, 2012 12:05 pm    Post subject: Reply with quote
I have an AAP box and a 1Z TDI and it's still too much rev. I agree with Andrew, regearing is preferred.
86syncrowesty
86syncrowesty is offline
PostPosted: Fri Aug 31, 2012 12:22 pm    Post subject: Reply with quote
BrownBertha wrote:
if your mice were like mine be sure to rip out the dash and check the heater box. tricky mice.
Yep, I got a lap full of sunflower seed casings on a nice hot day when I forced open the vent on the driver side. I guess the PO never opened them.
1986 Vanagon -- Syncro, Westy
2.5L Subaru
?Waldo?
?Waldo? is offline
PostPosted: Fri Aug 31, 2012 12:40 pm    Post subject: Reply with quote
Rallyedude wrote:
Anyone need 1.6 na parts ? Cheap cheap ! Evidently not the bars , pan , tranny . But intake ,pulleys , alternator , etc . Lmk
Unless you are adding A/C, you might want to consider keeping the v-belt drive. It is less stress on the crank sprocket.
Rallyedude
PostPosted: Fri Aug 31, 2012 3:17 pm    Post subject: Reply with quote
Right now the van has no ac or ps . I'd like to add both eventually . I agree with you that v belts can cause less stress . But serpentine belt set ups are super reliable . I'll be running serpentine belt as an added bonus you get a more modern reliable alternator . Tore the trans off today , more cleaning . Found the code , dm . Also pulled off specific swap parts needed of the motor .
Rallyedude
PostPosted: Fri Aug 31, 2012 3:26 pm    Post subject: Reply with quote
If I were to put on of my AAZ's in it would be done as a full rebuild . I'd have @ 1K in it plus my time . My AHU is good to go except a t-belt. I'd outsource the pump work . So that offsets money saving of the ahu not needing a rebuild . Ahu will save on rebuild time . Either way I think I'd regear. Anyhow , I've got the choice of either motor . Theyre sitting at my shop . So , tdi it is . I will be building my own trans .
Rallyedude
PostPosted: Fri Aug 31, 2012 4:24 pm    Post subject: Reply with quote
Reading on gear ratios the dm code has a 5.43 r&p is that correct? It seems to be the numerically highest ratio you can get . I have trans from an 85 doka . I believe it should be a 4. 57 or 4.86 ? The case is shot . Any reason why that r&p wouldn't work for me ? I still have to see about 3&4 gears . But usually bringing down the r&p when you up power works well and helps cruising speeds .
What would be ideal r&p ratio and 3&4 to match ? That is running an ahu .
jackbombay
jackbombay is offline
PostPosted: Fri Aug 31, 2012 4:35 pm    Post subject: Reply with quote
My AHU westy had a 4.57 R&P and a .77 4th, 3rd was 1.17 IIRC, and I had 27.5" tall tires (10% more distance per rotation than stock tire size) and I though that combination was just about perfect, 2750 RPM at 67 MPH. (vag-com for RPM And GPS for speed)
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Rallyedude
PostPosted: Fri Aug 31, 2012 4:43 pm    Post subject: Reply with quote
Cool thanks for the info .
Ring and Pinions switchable between different cases? That is diesel to gas cases . Different number of case ribs .
Who do you buy gears from ? Thought AA was the go to guy but apparently he wants to build transmissions not just sell parts . That's cool , and I get it . Just looking for another solution . Don't really want to ship my tranny to the other side and back when I'm comfortable taking care of it in house .
Page: Previous  1, 2
Page 2 of 2
