mark tucker Samba Member
Posted: Thu Apr 13, 2017 5:52 pm Post subject: Re: Case Thrust Cutting Tips / Porta-tool |
like morolock say's, it's kinda simpole if you think about it ..and always bore a dead case with a unknown tool.. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Fri Apr 14, 2017 6:47 am Post subject: Re: Case Thrust Cutting Tips / Porta-tool |
ACO
Welcome to The Samba.
I don't have anything to add to your dilemma but I would like you to consider posting your pictures on the samba. Sites like photobucket are know to change links and simply drop off the face of the earth and then what we have is a nearly useless post for posterity to learn from. I am currently behind a firewall so I can't see them even today. If I could, I may be of some help. Anyone else reading this please consider the same.
Thank you _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
SHAKERHILLVW Samba Member
Joined: January 13, 2017 Posts: 6 Location: Enfield, NH.
Posted: Wed Feb 01, 2023 7:38 pm Post subject: Re: Case Thrust Cutting Tips / Porta-tool |
I know this is an old thread, but this is what I do to thrust-cut a VW Block with a ML-99 Mainliner. I line bore the block first, then I take all cutters off the bar except for the one at the flywheel bearing. I then install the thrust cutter bit and maneuver the bar so the thrust cutter is INSIDE the block. Then I mount the centering ring as usual to center up the bar in the block. Then I just barely machine the inside thrust surface until it cleans up, usually about .003/.005 is removed. Then I remove the centering ring and remount the bar on the OUTSIDE of the block to finish to the thrust dimension.If the flanged main bearing has gotten quite loose, it will pound the inside thrust surface as well as the outside thrust surface. This works like a charm. BTW, I would NEVER use the bar feed when doing this, BAD things might happen.
MJI-1198 |
