satori Samba Member
Posted: Tue Aug 28, 2012 4:55 am Post subject: Best Lowering setup for comfort |
Hi all. Im wanting to lower my DC T3 (Vanagon) but still want to have a comfortable ride. The roads are pretty shit where I live so dont want a harsh sporty feel just something that can handle the bumps. Any ideas |
insyncro Banned
Posted: Tue Aug 28, 2012 6:52 am Post subject: |
No such combo is available.
Lowering will allow for better handling, but the ride will feel a bit harsh at times and with certain conditions. |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Tue Aug 28, 2012 7:03 am Post subject: |
If you don't already have them, you could fit the factory Carat lowering springs. These lower the van about 1.25" and they still have enough travel that they ride well. Combine these with some Koni shocks and you will get a pretty decent ride. This is my favorite combo. But if you want to go lower, there really is no combo that rides well. The suspension travel just gets too short and there will be considerable harshness over big bumps.
D |
r39o Samba Polizei
Posted: Tue Aug 28, 2012 7:49 am Post subject: |
D Clymer wrote: |
If you don't already have them, you could fit the factory Carat lowering springs. These lower the van about 1.25" and they still have enough travel that they ride well. Combine these with some Koni shocks and you will get a pretty decent ride. |
I have this same combination in my 1990 poptop Multivan.
My family does not consider this an overly comfy ride.....they keep comparing it to our mushy Chyrsler Routan. Compared to the Chyrsler the VW is stiff. Sigh...... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
insyncro Banned
Posted: Tue Aug 28, 2012 7:52 am Post subject: |
Carat springs are stock, I assumed the OP was talking about lower than stock...like H&R, Weitec and others.
Yes, Carat springs and Konis is a good combo. |
Kopasz Samba Member
Joined: August 15, 2008 Posts: 241 Location: Portland, OR
Posted: Tue Aug 28, 2012 9:18 am Post subject: Carat to H&R Sport and Koni's |
I have a 1987 Wolfsburg Weekender hardtop which came with Carat springs stock. The ride was not low enough for me with my 17" wheels.
My stock height, measured from center of hub to bottom of fender lip was 15.5 - 15.75" all around. I don't know what sjhocks I had, but when I went over tracks, a bump in the road, or some sort of dramatic and sudden elevation change in the road, the front of the van bounced quite a bit for a few times after the bump.
When I started doing my research, I was concerned about ride comfort as well, but knew that I would deal with it if I got the desired ride height (visually). Also, nobody could give me an accurate answer as to what final ride height I would achieve with any of the springs out there (Weitec, CIP1, H&R, etc.). I bit the bullet and went with the H&Rs and I am very happy.
I had the shop put in H&R sport springs and adjustable Koni's when they were upgrading the brakes last week. I love it. Definitely an improvement, but also definitely a more firm ride. Unfortunately, I do not know what the shop tech dialed the koni adjuster to, but they did whatever was recommended. _________________ adam
'87 Wolfsburg Weekender, Bostig Zetec
The rehabilitation of my Van can be found here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5949024#5949024 |
Posted: Tue Aug 28, 2012 9:45 am Post subject: |
insyncro wrote: |
Which is exactly why I said, "If you don't already have them." The OP didn't state what year van he had, and I don't know enough about the Australian spec vans to know if his van came factory equipped with the factory lowering springs. They weren't stock on all models in all markets - even in the later years.
D |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Tue Aug 28, 2012 9:52 am Post subject: |
if the roads really are shit there I wouldn't lower the van, just get yourself some quality shocks. _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
insyncro Banned
Posted: Tue Aug 28, 2012 10:17 am Post subject: |
D Clymer wrote: |
insyncro wrote: |
D |
My bad....didn't read enough.
I have lowered a few vans.
Its fun for awhile, but gets old when the roads are rough.
If you go LOW, all the same issues presented with lifting to the max need to be taking into consideration and changes made.
My experience is with Weitecs and H&Rs mounted with Burley upper arms and camber correction plates between the rear trailing arm and bearing housings.
Drove straight as an arrow and cornered extremely well on 18" Porsche Twists.
I also had a few different 17s mounted, but liked the look of the 18s best.
If you want the "go kart" feel and handling, go for it |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Tue Aug 28, 2012 4:37 pm Post subject: |
I always wondered if you flipped those camber correction shims
the opposite way if it would help aligns a lifted van? _________________ Bill M
87 Westy |
insyncro Banned
Posted: Tue Aug 28, 2012 6:45 pm Post subject: |
Haven't needed them in the rear of any lifted van...yet. |
dspieg Samba Member
Joined: March 12, 2011 Posts: 111 Location: Northern Virginia
Posted: Wed Aug 29, 2012 7:36 am Post subject: Factory Carat springs? |
And where does one obtain OEM Carat springs these days? I'd like to get a set (and Koni shocks) for my '86 tintop one of these days. |
Kopasz Samba Member
Posted: Wed Aug 29, 2012 7:47 am Post subject: |
I can see if the shop that did my install still has my carat springs, though I doubt it. Check The Samba classifieds.
I think Peter at VC told me that weitecs are similar in height to the oe carats. New springs would be better anyway I think. _________________ adam
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed Aug 29, 2012 8:01 am Post subject: Re: Factory Carat springs? |
dspieg wrote: |
Maybe talk to Peter at Van Cafe? If they're installing different springs in Carats they should have some take-offs. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
SouthOlive Samba Member
Joined: October 31, 2009 Posts: 133 Location: The Nexus of Crisis
Posted: Sat Oct 20, 2012 6:20 am Post subject: |
I lowered my camper with a Weitec/Koni combo and I love the ride. It would be nice to fix the rear camber though. Any ideas for camber correction plates? Brickwerks say they won't ship to the US and I don't even see them on their website anymore. _________________ 1985 Westy
2011 GTI |
insyncro Banned
Posted: Sat Oct 20, 2012 6:25 am Post subject: |
SouthOlive wrote: |
I lowered my camper with a Weitec/Koni combo and I love the ride. It would be nice to fix the rear camber though. Any ideas for camber correction plates? Brickwerks say they won't ship to the US and I don't even see them on their website anymore. |
Not hard to make them. |
Posted: Sat Oct 20, 2012 7:50 am Post subject: |
I'm up for making them! I assume a proper diameter round stock cut on an angle would be a start. Any pics, drawings, measurements, and/or material suggestions would be appreciated. _________________ 1985 Westy
2011 GTI |
insyncro Banned
Posted: Sat Oct 20, 2012 8:36 am Post subject: |
Mine are billet aluminum and are installed so not much help.
Essentially they are a spacer between the trailing arm and wheel bearing housing.
Off the top of my head...they are offset by 7mm. |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Sat Oct 20, 2012 8:44 am Post subject: |
Your thread title "lowering for comfort" uses mutually exclusive terms.
Consider that you're sitting over the suspension, and it's already pretty firm stock...and your roads aren't good. If you want low (and I love the look btw) expect a harsher ride as you give up wheel travel. Properly dampened springs are not harsh..but reduced wheel travel is.
So if you want lower, be prepared for a stiffer ride. Your tires have a spring rate too so you can compensate by lowering pressure with those inherent risks.
After many years of autocrossing a pimped 84 scirocco, I have zero interest in lowering my Westy, installing urethane bushings, or adding larger sway bars. If I want lateral G's I get my fix elsewhere The car is a visceral blast to drive but the words "buckboard, filling loosener" etc. are often uttered with passengers. That said, a lowered Carat with fat wheels and power is pretty cool _________________ Cheers,
Dennis Wood
The Grape |
Posted: Sat Oct 20, 2012 9:12 am Post subject: |
Good info, thanks! _________________ 1985 Westy
2011 GTI |
