Tezza Samba Member
Posted: Mon Sep 22, 2003 5:02 am Post subject: Dashpot, Autochokes, 1700 standard |
Could someone explain to me what the dashpot's function is ( on the carburetor ) ?
Also, do the auto chokes need to be adjusted depending on the season (eg winter versus summer) ?
Trying to understand what all the bits of the carb do.
Thanks |
fahrfromsinnin Samba Member
Posted: Mon Sep 22, 2003 6:37 am Post subject: |
Diito on the dashpot dilemma. _________________ 1974 Campmobile
My daily driver just wasn't enough |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Mon Sep 22, 2003 6:53 pm Post subject: |
The dashpot on a dual carb bus is there for two reasons.
1) It keeps the engine from stalling if you close the throttle too quickly.
2) It stops you from polluting the air during overrich conditions when you are decelerating. When you downshift and use the engine as a brake to slow you down i.e. a traffic light; the throttle will be fully closed, manifold vacuum will be very high, the engine will be sucking raw fuel thru the idle circuit, but you will have no clean going into the intake to complete the burn. The dashpot is there to keep the throttle open slightly to allow clean air in. The throttle will slowly close, hopefully by the time you have reached idle speed. |
Tezza Samba Member
Posted: Wed Sep 24, 2003 9:30 pm Post subject: |
Thanks, Karl
So the dashpot is some kind of damper or shock absorber?
Do you have any ideas on the autochoke question?
Terry _________________ Life with a VW wasn't meant to be easy !
1976, 1600 Beetle ; 1973, 1700 Kombi |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Sep 28, 2003 8:47 pm Post subject: |
Tezza wrote: |
Thanks, Karl
Terry |
On the '72-4 dual carb buses, the dashpot (a "pneumatic door closer", by the way) only comes into play for a couple of seconds when the accelerator is released suddenly. It does not relate to off-throttle over-run conditions, because the OEM egr and air pump systems ensure properly lean conditions. The dashpot was actually only to reduce emissions from accelerator pump injections that had no time to burn with what-should-have-been open throttle plates because of the driver changing his mind and shutting them.
The dashpot has very little effect on driveability with a correctly adjusted engine. If you ever have stalling or surging from snapping the throttles, you most certainly have mixture/speed/timing issues to hunt down.
The chokes do not need seasonal adjustments, and I can guarantee you this anyway, they will always be slightly annoying. The most usual symptom of these chokes is a fast idle greeting you after a quick trip into the store on a cool day. The engine internals will be still warm, the ambient engine compartment temperature will be cool, the chokes start closing, and presto, an idiotic fast idle for no good reason. If you adjust the chokes to get rid of this symptom, you will lose that beautiful *cold* start performance. When I have a warm engine on a cold day, I just turn on the ignition for a couple of minutes before I start the car when I get back from my little dash into the store. This gives the choke heaters a head start, I might have a fast idle while trolling in the parking lot, but it'll settle down by the time I get to the first light or stop sign.
Colin |
