Weezyissuperfast Samba Member
Posted: Thu Nov 29, 2018 10:39 pm Post subject: Re: Syncro 7 Passenger Interior to Weekender |
Yeah, I got my table and side panel installed:
The bend that I showed in my previous picture was sufficient. I am going with the Carat/Multivan layout (pop top addition to come this spring), which has a different bench system than the weekender bench with the plastic kick panel. My arrangement looks like this:
I need to finish the jump seat install next. |
SlalomVan Samba Member
Joined: March 28, 2006 Posts: 127 Location: Seattle, WA
Posted: Mon Apr 27, 2020 5:01 pm Post subject: |
Thanks to everyone who has posted photos and detailed information on making this transformation from 7-seater to a Weekender interior. Especially Greggearhead!
I am currently restoring/updating a 1989 Vanagon that has a very plain interior. Before I acquired it, was used for six years as a delivery van for local dry cleaner and then parked in a barn. Rumor has it (substantiated by some the records I received when I bought it) that it was originally intended to be used as a shop parts runner at Campbell Nelson VW north of Seattle before being sold to the owner of the dry cleaning business. It had the barest interior I have ever seen - gray tweed seats up front without armrests, rubber flooring up front, no tachometer, no headliner - basically a tin can. I am building out the interior and installing a Weekender bench seat that I have had in storage. Yes, it is about 4" narrower than the standard 7-passenger bench seat and I need these spacers.
greggearhead wrote: |
Here is teh factory piece:
Ths screws into the factory mount on the body, then the seat bracket screws into it, in the 4 mounting locations. I had some square steel tubing that was clost to the right size, but not near thick enough for a stressed mounting location.
Drill a couple holes, add the grade 8 fasteners, and voila - close enough to factory, and hopefully stronger, even with *my* welds.
The spacers are relatively hard to find so I am going to fabricate them instead. Good excuse to buy some more tools! Instead of welding a nut and a bolt to the newly fabricated spacers, couldn't you just use a single longer bolt that goes all the way through the square tube spacer block? Really weird that these are not metric bolts! Since I don't weld, that seems way easier. It might be harder to line everything up with the plastic panels in place and get the bolt and spacer secured to the body. Other than that, what would be the downside to this approach? _________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo" - Sold)
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997 |
Posted: Mon Apr 27, 2020 7:52 pm Post subject: Re: Syncro 7 Passenger Interior to Weekender |
So, there are a couple of issues w/ using a longer bolt through a bracket like that in this application. First issue is that those brackets are behind the plastic wall panels when you are installing the seat, so it would be near impossible to hold them in position while getting the seat lined up and the long bolt through. Second, if you tighten a bolt on an open square bracket like that it will just deform. You could use a solid block with a hole in it, but then you would still have the first problem.
Welding these brackets up is quite easy. If you cut the steel and get the hardware anyone w/ a welder should be able to weld them up for you. You could take them to a local mechanic and get them welded fairly cheaply.
You will also need to weld on the bracket spacers for the rear seat. |
dumptdeluxe Samba Member
Posted: Wed Jul 08, 2020 2:41 pm Post subject: |
SlalomVan wrote: |
Yes, it is about 4" narrower than the standard 7-passenger bench |
Does anyone know the actual length of one or the other, Weekender vs. standard bench? If I was to go buy a loose seat, how would I know? I need a rear seat and cargo cushion for my '85 passenger van, but don't know how to tell the difference without reference. I bet there's an easy way to tell that someone could share... _________________ '65 Notch S
'85 Vanagon GL
'16 Tiguan TSi |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Wed Jul 08, 2020 3:26 pm Post subject: Re: Syncro 7 Passenger Interior to Weekender |
The metal frame hinges measure about 64” apart on the passenger seat and about 60” on the carat interior seat. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Wed Jul 08, 2020 5:38 pm Post subject: Re: Syncro 7 Passenger Interior to Weekender |
Good to know, thanks! So as long as I find 64" seat, no matter the year Vanagon, it should work with the securing pins? _________________ '65 Notch S
'85 Vanagon GL
'16 Tiguan TSi |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6361 Location: Honolulu,Hawaii and France
Posted: Thu Jul 09, 2020 12:17 am Post subject: |
dumptdeluxe wrote: |
SlalomVan wrote: |
Does anyone know the actual length of one or the other, Weekender vs. standard bench? If I was to go buy a loose seat, how would I know? I need a rear seat and cargo cushion for my '85 passenger van, but don't know how to tell the difference without reference. I bet there's an easy way to tell that someone could share... |
The square tubing is 40mm I recall, so that would be a more narrow set up by 80mm. I hope this helps. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
