xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Thu Sep 06, 2012 4:06 am Post subject: Westfalia poptop tent measurements |
I need the rough dimensions for the westy poptop canvas for an early and late bay bus.
I am working with the Country Homes Campers roofs for Vanagons. I am changing the way they pop from straight up to tilt up like the westy roofs. The Vanagon Westfalia canvas will be slightly too big and I am thinking the bay tents may be a closer fit.
What I need is the lenght and width and the height when open of the tall end and short end.
Thanks for your help guys!
Andrew Flint
Flint European Automotive LLC. |
LeeE Samba Member
Posted: Thu Sep 06, 2012 2:37 pm Post subject: |
I just replaced my rotted canvas with screen about a month ago, and it looks good with no stretches or sags. 1978 Westfalia.
The measurements that I used were -
Poptop inside dimensions are 47 1/2" x 96 1/4".
The bottom of the material, measured using the aluminum hold-down strip outside dimensions, is longer at 98". The width is is the same, 47 1/2".
The front height is 46 1/2", and the rear is 16".
I wasn't sure why the measurements were in fractions, so I checked and re-checked and that's what I got each time. I tried converting into metric but that didn't come to whole numbers either.
The material does not hang exactly 90 degrees/perpendicular from the top, it's slanted toward the back about 10 degrees. So the back inside angle is 100 degrees and the front inside angle is 80 degrees. _________________ 1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp |
Posted: Thu Sep 06, 2012 3:58 pm Post subject: |
Thanks LeeE! That's exactly the info I needed.
Anyone with an early Westy Bay? |
Posted: Fri Sep 07, 2012 4:29 pm Post subject: |
The late bay canvas will also be slightly large for my roofs. Does anyone know if the early bay canvas is smaller? |
Orangebuslover Samba Member
Joined: December 09, 2008 Posts: 7 Location: Oceanside,Ca
Posted: Fri Mar 08, 2013 10:44 pm Post subject: 72 tent canvas dimension |
Does anyone have the measurement of the canvas on a '72 westfalia pop top?
If I was being cheap, could I fit a late bay poptop canvas on a '72. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Fri Mar 08, 2013 11:02 pm Post subject: Re: 72 tent canvas dimension |
Orangebuslover wrote: |
No, a late Bay canvas is much larger than an early Bay. The hole in the roof of the Bus is bigger. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
poptop Samba Member
Joined: February 27, 2003 Posts: 607 Location: jersey
Posted: Tue Mar 19, 2013 6:08 am Post subject: |
Can a Vanagon Westy tent be used for A 72 bay tent? I did buy a spare and hate to spend again _________________ So what I drive the short bus! |
Posted: Fri Jun 07, 2013 9:57 am Post subject: |
Turns out you can use a late bay canvas on an earlier pop top. You just have to be willing to cut and sew the whole thing back together. I bought a used canvas off TS cheap. There were some rips along the bottom where it was mounted. Using the one off my '73 as a pattern I was able to remove the torn material and use it for patches. A few hours and less than $100 for a usable decent looking canvas top. I don't recommend doing this though. Kind of a pain.
OBL _________________ '73 Westy Daily Driver
'72 Helsinki...project |
