thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Wed Sep 12, 2012 4:59 pm Post subject: Considering Switching to Rack & Pinion Steering |
I've been thinking of converting my Baja Bug to rack and pinion steering lately.
At one time I ran a Porsche 356 steering box. After that was damaged, I switched to an early Type 1 steering box.
I've been reading good things about rack and pinion steering in a Baja Bug for years, but never wanted to spend the money or deal with the fabrication.
I have a stock width link pin beam with stock height shock towers. It has Porsche 356B spindles and Ford tie rod ends with chromoly tie rods.
I'm wondering who might have advice as to what the best r&p unit to use would be. Saco? Maybe something from a production car?
I like the idea of using a r&p unit from a production car as replacement parts should be easier to find for future repairs.
Is there any bolt on kit or is welding required for any conversion? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Thu Sep 13, 2012 8:51 am Post subject: |
I went off half-cocked to change my '63 woods buggy to rack and pinion. I used a rack from a mid-70's Ford - possibly a '76 Capri I bought once for parts. I removed and sold all the VW steering stuff and started to fabricate mounts for the Ford unit from 3/16" thick 1 1/2" angle iron. I got it centered and mounted.
THEN - I figured out that the rack was intended for use on spindles with front guide arms; not the rear guide arms like the VW has. That means that when I turn the steering wheel right, the wheels turn left! I'm sorta' stubborn, so now I have cobbled up a countershaft using an old oil pump, some lathe work and blistered my fingers from crossing them for luck. When I turn the input shaft CW, the output shaft turns CCW, which in turns the wheels the correct way. The countershaft unit is not quite complete yet, but I'll post some pictures when it's finished.
This post is intended to tell you that you need to go to a reputable site such as www.appletreeauto.com and buy the rack, mount, u-joints, etc. all as a package deal. I'd get the 14" unit which comes with the tie rods but not ends. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5417 Location: Holland, MI
Posted: Thu Sep 13, 2012 9:25 am Post subject: |
I also considered a rack for my otherwise stock link pin beam. After way to much thought I decided it wasn't worth it. The stock bug steering boxes are plenty strong if you address their biggest week point. Also, bump stop is not really a big deal with the stock front ends with the stock steering set up.
You know what I like best about steering boxes? They are easier on the hands! Racks have a ton of feedback...feedback is good, but it's more than what I like. The worm gear in the stock boxes takes a lot of that shock off and transmits it as side thrust to the tough cast iron case.
Now if you were ever going to modify your front end for long travel...that would be a different story. Racks win hands down for that sorta thing. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
oukno Samba Member
shred625 Samba Member
Joined: October 10, 2007 Posts: 1328 Location: Huntington Beach Ca
Posted: Thu Sep 13, 2012 4:14 pm Post subject: |
I would use a saco rack. Make sure you get a center load rack as the end load racks are for a-arm cars. You will need to do some fabrication and make sure you get the bump steer as low as you can before you weld in the mount. _________________ “It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey |
Posted: Thu Sep 13, 2012 4:16 pm Post subject: |
shred625 wrote: |
I would use a saco rack. Make sure you get a center load rack as the end load racks are for a-arm cars. You will need to do some fabrication and make sure you get the bump steer as low as you can before you weld in the mount. |
Are steering dampeners used with these racks? _________________ 1957 Vintage Baja Bug.
WrRider Samba Member
Joined: November 17, 2011 Posts: 114 Location: Hemet Ca.
Posted: Thu Sep 13, 2012 4:24 pm Post subject: |
With a stock front end I would keep the box a frend of mine has a nice saco rack and a big steering wheel and driving it is a workout. You can buy a stering quickener but it will be pricey with the shaft and u joints. _________________ My build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=508856&highlight=wrrider |
Posted: Fri Sep 14, 2012 8:48 am Post subject: |
thefladge wrote: |
shred625 wrote: |
Are steering dampeners used with these racks? |
I used to have a fox shock with no nitrogen charge hooked up to my rack on my 9 car. Not running it anymore but for something on the street I would use one. _________________ “It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey |
Gary Massin-Ball Samba Member
Posted: Fri Sep 14, 2012 9:48 am Post subject: |
I went thru the same thoughts with muy rail and finally came up wit this set up. I call it the "poor man's rack and pinion".
I used to have all sorts of bent parts and broken pieces before this and I too was not willing to spend the cash on the whole rack system.
This set up actually gives you longer tie rods than even the rack system which takes even more bump steer out of the articulation. I have not has any bent parts or breakage or peeled tires off rims since this mod. _________________ Warrior sand rail:
2276cc 82x94
Engle FK-41 with 1.25:1 street style rockers
40x35.5 stock cast single port heads
Single 40mm Kadron w/32vent
Equalizer 5lb pulley
Stock lifters
Stock aluminum pushrods
26mm aluminum oil pump full flow
*Poor mans rack and pinion up front*
The Ugly Bug is on the road! |
