Rear heater elimination options for coolant hoses |
A) Remove heater and just block all the lines. |
18% |
[ 7 ] |
B) Connect coolant hoses together under the bench seat with a straight barb fitting |
15% |
[ 6 ] |
C) Remove T fittings under the Van and connect hoses together with straight barb fittings. |
65% |
[ 25 ] |
Total Votes : 38 |
Bruce Wayne Samba Member
Posted: Fri Sep 14, 2012 6:46 am Post subject: |
remove it. first camping trip we took,it made a mess. yanked it out in the campground. never have passengers in the back,plus it doesn't get that cold in western Oregon anyway. front heater keeps it plenty warm for me. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9775 Location: Mt Lemmon, AZ
Posted: Fri Sep 14, 2012 7:11 am Post subject: |
goffoz wrote: |
...Crack one of those valves open, and take a look inside
...you'll see they flow ,even when "closed"
Approx a 3mm. hole...I just figger thar may be a reason for that |
Possibly to make it easier to successfully bleed the cooling system?
In any case, coolant bleeding / trapped air should be considered in whatever alternative you design. |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Fri Sep 14, 2012 7:16 am Post subject: |
goffoz wrote: |
Are you sure this flow restrictor bypasses the valve? Bentley section 19.10 also says '83-85 "remove flow restrictor from inlet fitting of heater valve". With my Subaru conversion I needed to open the rear valve to provide this bypass function. Perhaps different years had a different valve setup.
jrobewesty wrote: |
Yep, take a good look at a system before you assume anything on it.
Little things add up and can make a difference. |
Yes, I agree. Looking at the coolant flow diagram on 19.10, only the right head goes to the heater. If the bypass were required for correct operation of the engine, why would it only be on one head? So then, can you explain how this restrictor will make a difference?
What about the vans/trucks that don't even come with a rear heater from the factory?
Please, this response is pointless enough, but three posts? At least consolidate all your "X2"s into one post. Sometimes I wish the post counts were not shown like on some other forums; I think it would eliminate some frivolous posts. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
insyncro Banned
Posted: Fri Sep 14, 2012 7:33 am Post subject: |
Feel free to block my posts.
X and a number is like an .
Many use it here.
If you don't like my post count use a / and divide by whatever number you are comfortable with. |
Windig89 Samba Member
Joined: September 22, 2011 Posts: 184 Location: Montreal
Posted: Fri Sep 14, 2012 7:41 am Post subject: |
Post whore!
Oops, I am one too now.
Thanks guys, lets keep this to the best method of removal, not a debate if one should remove it or not, or how many posts inSync has lol
Just pretend the decision is made to remove the heater, now which is the best method to execute.
Cheers, _________________ 1989 Vanagon GL Westfalia - 2.1L waterboxer |
Posted: Fri Sep 14, 2012 7:42 am Post subject: |
insyncro wrote: |
Many use it here.
All I ask is that if you have an "X2" type of post, is that you please share some additional valuable information from your experience, so as to increase the signal to noise ratio; also if you have consecutive posts please consolidate them into one post. _________________ 1986 Vanagon Westfalia EJ25
insyncro Banned
Posted: Fri Sep 14, 2012 7:51 am Post subject: |
Search the original Vanagon.com email list for valuable info that Dennis Haines posted in the 90s as to why you should remove the plastic Ts and not leave dead end coolant lines in your system when getting rid of the rear heater.
A hint as too why is that they fail about as ofter as the the gasoline bulkhead fitting in the engine compartment.
Get rid of 20+ year old plastic parts that have seen countless heat cycles
RMW has nice upgraded Ts, reducers and straight connectors.
There is a direct correlation between having issues bleeding your system and having dead end coolant lines.
As it states clearly in Bentley, for the bleeding process all heater valves need to be OPEN.
Many use the rear heater loop in there conversion bypass.
If you have a conversion, a reversed coolant distributor and or don't actually know how your cooling system is plumbed...before removing anything, I would get up to speed on the layout. |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Mon Apr 01, 2013 3:39 am Post subject: |
If anyone has removed their rear heater and has a spare trim from the rectangular hole free... I'm looking for one.. or two!
Part no:255070235
Black rectangular trim that surrounds the hole that the heater comes through like this...
Thanks
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
