cmarino929 Samba Member
Joined: August 16, 2009 Posts: 257 Location: Central NJ
Posted: Mon Sep 17, 2012 5:45 pm Post subject: westy seat rails/mk2 base? |
Does anyone know if the seat rails on a westy (1982) are the same as an mk2? (found nothing in the search). Im not sure if the vans have special seat rails because of the swivel.
Reason im asking is i have mk2 bases that would be nice to use recaros in the van with if they fit. |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
hauptmann Samba Member
Posted: Mon Sep 17, 2012 6:17 pm Post subject: |
Nope. I was just working on installing mk2 recaros in my van, but the seat rails are totally different.
At least on the mk2 recaros the bases unbolt. The width of the mk2 Recaros bolt holes are about 16", which is wider than the (non-swivel) tracks in my Weekender. I'm rigging something up with steel cross pieces that bolt across the bottom of the recaros and then reusing the rails from disassembling my existing vanagon seats.
I can provide more details if you'd like, but I think others have done the same before me. Go Westy (used to?) sells recaro bases that will bolt right but I believe they are spendy. _________________ 86 Vanagon Wolfsburg/Weekender |
r39o Samba Polizei
Posted: Mon Sep 17, 2012 6:55 pm Post subject: |
Remember the FAQ *IS* your friend!
From section 72:
http://www.thesamba.com/vw/forum/viewtopic.php?t=257868
Plus there are other seat threads too..... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Sep 17, 2012 7:28 pm Post subject: |
All great info, thanks for the replys! Hauptmann - i would love to see what you come out with.
I will check out the threads and if not maybe i can find something online that would work. Thanks again. |
