67 T3 SQB body on a 69 SQB frame
RATTRP
RATTRP is offline
PostPosted: Thu Sep 20, 2012 9:45 am    Post subject: 67 T3 SQB body on a 69 SQB frame Reply with quote
I am in the process of trying to make my 67 SQB body work on my 69 frame. Anyone done this, have any advice, pics etc...
Thanks to all!
You laugh cause I'm different...
I laugh cause I just farted!!!
69/67 SQB's... That's all I got.
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 21, 2012 5:41 am    Post subject: Re: 67 T3 SQB body on a 69 SQB frame Reply with quote
Thanks to all!
Are you going to keep the Swing Axle set up? Or do you want to convert to IRS?
If you want to convert, then you can either modify the SA rear subframe (bolts on) to IRS by cutting and welding in IRS trailing arms and mounts, and changing to the IRS spring plates. See Brent's Fastback build thread on here, or the other thread showing how to convert one.
Or you can cut and weld in the IRS rear engine hanger mounts to the body. I've found this way to be easier, as I converted my 65 Notch to IRS using this method. You can also keep the very rear mount (stock 67) in place too, as this will help align the engine when you do the body mounts. I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
RATTRP
RATTRP is offline
PostPosted: Fri Sep 21, 2012 6:11 am    Post subject: Reply with quote
Thanks for the info... I had no idea what I was going to do, I have cut the IRS rear engine hanger mounts out of the 69' body in hopes that I could weld them in on the 67' body.
My main concern in doing this is getting everything aligned properly in the process of welding in the hanger mounts. With no real reference as to where they should go on the 67 body, that was my ultimate hang up! LOL
I very much appreciate the info, maybe I will see if I can get a shop to weld these in for me. The only AirCooled VW shop I know of in my area is Lyle Cherry's, but I would assume any experienced welder could handle up on this...
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 21, 2012 7:56 am    Post subject: Reply with quote
What I did was mock everything up on mine. I had the body mounted to the chassis, engine AND trans in place, and used a floor jack to set the engine height (made sure the stock dual carb air cleaner could come off) and I also used the rear mount to help center the engine. I also already had the engine hanger bar in place, and just worked out where the mounts would go. I then tack welded them in place, and removed the engine for welding and painting. I found that I had to trim a couple of pieces of body side engine surround tin, to get the mounts in place. But then, I used Squareback mounts in my Notch. Shocked I flipped them over, and side for side to get them to fit though. I also ended up adding 2 spacers under each engine hanger mount (the bolt on part), so I could change the mounts IF I ever needed to. This was all done in my garage. Sorry, but no photos of the process, as I was too busy just doing the job. Wink
Tram wrote:
Tram wrote:
