scottssoccer Samba Member
Posted: Fri Sep 21, 2012 8:37 pm Post subject: steering wheel and turn signal switch |
why is there a 3/4 inch gap between my switch and the steering wheel once the steering wheel is bolted on?this is a 66 bug fyi |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Fri Sep 21, 2012 9:05 pm Post subject: |
you should be able to adjust the gap by loosen the set screw on the side of the blinker assembly and moving it closer to the wheel.
you may also check distance the steering tube is exiting under the fuel tank.
you can loosen the 2 mounting screws and twist the column tube thus closingthe gap between the blinker assembly and wheel. |
Posted: Fri Sep 21, 2012 9:33 pm Post subject: |
thank you for the help! |
meach Samba Member
Joined: August 19, 2006 Posts: 210 Location: SEast N. Carolina
Posted: Sat Sep 22, 2012 5:09 pm Post subject: Tightening screw |
What would happen other than loosening the unit up if I remove screw? Mine has a stripped head and want to replace it. _________________ Past Aircool Inventory
Beetles - '57, '58, '60, '64, '67, '74
Bus - '64
Thing - '74
Squareback - '64
Porsche Speedster - '55
HD DWG - '98
"IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE." |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sat Sep 22, 2012 6:30 pm Post subject: |
You mean the set screw? It's not removable... or it's not supposed to be. On the other side it is crimped onto a contact plate:
meach Samba Member
Posted: Sat Sep 22, 2012 7:51 pm Post subject: |
....I see now, thanx. I guess I'll just pull the wheel and see what is needed to repair. _________________ Past Aircool Inventory
Bus - '64
Thing - '74
Squareback - '64
HD DWG - '98
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Sep 23, 2012 5:41 am Post subject: |
FYI - If you cant adjust it enough - the steering shaft length can be adjusted at the steering coupler - that T that slides into the steering shaft at the coupler and be slid in and out, but a lot of times the clamp is rusted pretty well. Also the outer colmn and be slid back and forth. You loosen the 2 bolts on the support under the dash and then you need to slide the rubber bushing back or forth (keep in mind that there is a seal at the firewal as well. _________________ D-Dubya Manx clone - 63 Short pan,1914.
meach Samba Member
Posted: Sun Sep 23, 2012 6:37 am Post subject: |
....thanx for the info, good to know. My main problem is the cross point screw head is stripped. Hoping to take my 'dremel' and slotting head for common screw driver. _________________ Past Aircool Inventory
Bus - '64
Thing - '74
Squareback - '64
HD DWG - '98
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Apr 10, 2014 9:37 pm Post subject: |
Just wanted to say thanks for this thread. It saved me hours of headache. I had the same 1" gap between my turn signal switch and steering wheel. I thought I had a weird steering wheel or mismatched parts. I loosened the two steering column bolts as sugessed and pulled the tube toward the steering wheel closing the gap. I just rebuilt the turn signal switch and now with the gap closed, the self canceling works. Thx all! |
Posted: Fri Apr 11, 2014 3:42 am Post subject: |
Just mail a check......... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Apr 11, 2014 6:23 pm Post subject: |
I could, but you might not want to cash it.. |
