DIY flywheel hub refinishing...
Terry Kay
Banned
Terry Kay is offline
PostPosted: Mon Sep 24, 2012 5:37 pm    Post subject: Reply with quote
I don't know who is supposed to be wondering here, but I do know that grove was a deep one--forget it--your digging a big hole you won't be able to seal--& JB weld is NOT a good wear surface for any seal.
Where do you guys come up with this stuff?
The Krakow school of Engineering?
I think this process for a real shallow grove might work--
However, in this case the grove was too deep in that hub to expect the seal to seal after it was spun outa there & clean.
JB Weld--Common'---
I can't believe this actually was printed--Live.
What the heck is wrong with a simple wear ring, which is at the most a 2 minute resurfacing job?
I'd say this was an honerable effort, But--until you figure out how much you took off of that wear surface--and to get a seal to fit properly , you were just playing around polishing out that gaff mark & making dead batteries on that drill.
It's the blind agreeing with Jose Feliciano on this one--
T.K.
James 93SLC
James 93SLC is offline
PostPosted: Mon Sep 24, 2012 7:22 pm    Post subject: Reply with quote
That picture wasn't the original posters flywheel. His was not that bad.
Caption above the picture:
"Sorry - I forgot to take a "before" picture, but if you've been there, you know what I mean...
(Mine wasn't this bad, but here's an example from the gallery...with credit to deprivation...): "
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka"
Christopher Schimke
PostPosted: Mon Sep 24, 2012 7:35 pm    Post subject: Reply with quote
As they say, necessity is the mother of invention. Nice job!
dobryan
dobryan is offline
PostPosted: Mon Sep 24, 2012 7:36 pm    Post subject: Reply with quote
dhaavers wrote:
In my last pic you can see just the slightest indication of where the groove used to be.
It wasn't deep enough to catch a fingernail, but you could feel it.
It was probably a couple thousandths, no more.
TK, You need to read better man.....
Dave O
The Western Syncro build
dhaavers
dhaavers is offline
PostPosted: Mon Sep 24, 2012 7:47 pm    Post subject: Reply with quote
^^^ x2...
Rolling Eyes
Lets just say, with Loogy, 10c & others on my side I feel
pretty comfortable right now.
FYI, I called GW today...they are expediting my new FW o-ring
& I should be putting this all back together this weekend.
Updates from the road will be forthcoming...
"The WonderVan"
tencentlife
tencentlife is offline
PostPosted: Mon Sep 24, 2012 9:03 pm    Post subject: Reply with quote
Lets just say, with Loogy, 10c & others on my side...
I got 40 engines on your side.
Shop for unique Vanagon accessories at the Vanistan shop:
Experience is kryptonite to doctrine.
Terry Kay
Banned
PostPosted: Mon Sep 24, 2012 9:19 pm    Post subject: Reply with quote
I wasn't digging any holes here you guys.
Just saying---
If you had a Micrometer in the picture with some sound "before" and then "after" figures--I'd have to say Rube Goldberg doesn't have anything on you guys on turning apparatus---
However, seeing as your not in with & along a Smokey Yunik,Fireball Roberts, or Dyno Don Nickelson's eye balling machinest capacity, I am pretty confident your going to have some post nasal drip on that seal.
You took some off--what's going to take up the slack in the clearance?
The stock seal??
Next Episode's;
"How to DIY crank journel's with a Dremel Tool."
"How to DYI front rotors rear drums with nothing more than a 4.5" Milwaukee grinder, and a potter's wheel.
"How to DIY valves & seats with a 8" bench, & die grinder, & a vice"
I can see this stuff on the way---plus;
"No measuring devices required"
"Eye ball it & hope for the best"---
Amen.
I did not see the quote that was just a representative photo only--
I was overcome by the tenacity of the act---
Big Kahuna's,Gulluinnes,Gonads.
Dime--I wouldn't let on to all of your secrets----- that your boring bar is a La Machine with emery paper on the blades.
you can hold onto that as a trade secret.
T.K.
PocketRocket
PocketRocket is offline
PostPosted: Mon Sep 24, 2012 9:31 pm    Post subject: Reply with quote
Terry Shut the _uck UP!!!!!!
Terry Kay
Banned
PostPosted: Mon Sep 24, 2012 9:35 pm    Post subject: Reply with quote
You know Bob?
T.K.
RicoS
RicoS is offline
PostPosted: Mon Sep 24, 2012 11:36 pm    Post subject: Re: DIY flywheel hub refinishing... Reply with quote
If this wasn't your flywheel, then why the hell show it? There's the real risk that one of the Great Unwashed is going to think that this hunky-fucked approach to polishing the seal surface is going to be able to buff out a groove similar to the one in the photo.
Look, overhanging 15 lbs. of flywheel on a 1/4 inch shank chucked into a battery-powered drill is not the way to go. The poster's claim that he removed a couple thousands of material is dubious at best. Even with a workpiece solidly mounted in a lathe, it takes some real pressure to file in a 1/2 thousand so I doubt that this shoe shine job did much more than polish off some built-up varnish. If somehow he did manage to remove that much meat with this method, he also ruined the flywheel
There's no need for this "craftsmanship of risk" approach - if you have a grooved seal surface, take it to an auto machinist and then pull out your Chicago Rawhide catalog to make sure you can get an oversized seal to fit or else tell the machinist to press on a Redi-Sleeve.
Richie
RicoS
RicoS is offline
PostPosted: Mon Sep 24, 2012 11:47 pm    Post subject: Reply with quote
Hey Rocko, my man, this is a FORUM - you can find out what that means here: http://www.ahdictionary.com
Richie
dhaavers
dhaavers is offline
PostPosted: Tue Sep 25, 2012 3:58 am    Post subject: Reply with quote
Sorry for the trouble, boys - I'll edit out the photo if it'll get you off each others backs. Rolling Eyes
I just put it up as a reference for the other flywheel noobs out there (like me).
If I can, I'll replace it with more specific specifics - but like I said, I didn't get a picture
and I don't own a micro-anything, other than a set of feeler gauges and a good sense
of what I can and cannot do. From 10c's description, I decided this is something I can do.
Bottom line, TK: 10c HAS posted on this process a number of times over the years.
Nothing hidden, no secrets...a piece of advice; a suggestion.
I just picked it up & ran with it., so forgive me (but thanks for mentioning my cojones).
Cool
BOTTOM bottom line - how's my flywheel look? Can you tell it's missing 0.002?
Time to lock this thread...??? Too bad, because I thought it might help someone else someday.
Evil or Very Mad
"The WonderVan"
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Sep 25, 2012 6:52 am    Post subject: Reply with quote
You did great. Ignore the pointless chatter
Casey--
'01 Weekender --> full camper
y u rune klassik?
tencentlife
PostPosted: Tue Sep 25, 2012 7:07 am    Post subject: Reply with quote
Trolls will be trolls, you can't claim they don't come by their loathsomeness honestly.
T3 Pilot
T3 Pilot is offline
PostPosted: Tue Sep 25, 2012 8:12 am    Post subject: Reply with quote
I'm going to do mine on my wife's pottery wheel when she is away next week.... Laughing Laughing Laughing
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
Terry Kay
Banned
PostPosted: Tue Sep 25, 2012 9:33 am    Post subject: Reply with quote
If being a Troll equates to doing the job right ---so be it, and the title taken with a deep bow.
I have never seen heard, or experience a group of folks who seem to be in a tailspin most of their lives on a mission to hack up and complicate a relativly simple task.
I can see just polishing the hub up--but resizing it without getting some measurements first?
No way.
And if the Dime is a proponent and instigator of this plumber's taped down drill lathe techinque--Well---this just sez a bunch to me how he is the allegid Master of engine builder's.
Shoe maker--Maybe---
And all for the sake of the price of a wear ring and the proper seal installed.
I can't imagine being that destitude over a 30 buck part.
You gotta be kidding me.
If ths was an easy task to replace the seal a couple of times once it got chewed up & leaked, I'd say go for it.
But it sure isn't, and I sure don't know why in the hell you guys choose to take the low road again, & again.
Cob away Vanagon Tribe.
Cutting that hub on the pottery wheel is great idea--plenty of pumice attached & slung on it to it to use to burnish it all up nice & shiney once you've taken too much off.
T.K.
Christopher Schimke
PostPosted: Tue Sep 25, 2012 9:47 am    Post subject: Reply with quote
"Pay no attention to that man behind the curtain."
dhaavers
dhaavers is offline
PostPosted: Tue Sep 25, 2012 5:49 pm    Post subject: Reply with quote
I'll be along to help, but WHATEVER YOU DO, DON'T POST ABOUT IT HERE!
Laughing Evil or Very Mad Rolling Eyes Wink
"The WonderVan"
Terry Kay
Banned
PostPosted: Wed Sep 26, 2012 11:45 am    Post subject: Reply with quote
No, I wouldn't either.
Perhaps a new addition to the Sticky Arena should be added;
Hacks, Mondo Canne' non approved by VW or anybody repair's, and other Farm Fresh Repair Technique's.
Short cuts to Hell method's, & madness.
How to fix your Van, & have more headaches---
Should be a real interesting posting area.
T.K.
wynnep
wynnep is offline
PostPosted: Wed Sep 26, 2012 12:10 pm    Post subject: Reply with quote
Way to go T.K. Thought you had mellowed out over the past few months. Your messages have been mild and informative. Glad the old T.K. is back with a lot of good information, sarcasm, and ribbing of others. I hope everybody understands that you are just being you and you mean no harm to others. You just have a different way of presenting information for the good of all. I enjoy your rants and raves. Keep up the good work.
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
Page 2 of 4
