volkswouter Samba Member
Joined: March 25, 2003 Posts: 450 Location: The Netherlands
Posted: Sun Apr 04, 2021 12:05 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Found a pair of these grilles on EBay and took the change if they'll fit.
The fit the Hella's perfectly! The grilles need some modification to fit the rear corners before the bus goes to paint.
D-train Samba Member
Posted: Sun Apr 04, 2021 12:36 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
They look trick. What are they from? _________________ shiny paint doesnt make it worth any more |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sun Apr 04, 2021 6:35 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
D-train wrote: |
They look trick. What are they from? |
356A horn grills _________________ .
Wanted:
John Ghia Samba Member
Posted: Sun Apr 04, 2021 6:47 pm Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Let’s see how they look vertical. _________________ BUS BOYZ |
Posted: Mon Apr 05, 2021 3:08 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
I like them more horizontally.
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
aa390392 Samba Member
Posted: Mon Apr 05, 2021 3:33 pm Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Id do without...to glitzy _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Mon Apr 05, 2021 5:14 pm Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
problem is I immediately see/think they belong on something else and that just spoils it. If it was a custom piece it wouldn't so quickly call another vehicle to mind.
PG also looks so good on a curvy corner all buffed out Id find it hard to go past that. _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
Posted: Sun Sep 26, 2021 11:34 pm Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Back with some action!
I got myself a much better engine lid. The PGSG one is totally busted on the inside. I saved it and last week i donated it to another PGSG bus here in the NL.
The owner used paintstripper and found out that his lid was a painted Dove blue one.
Posted: Mon Sep 27, 2021 1:24 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Wouter, funny u say it was db. I’ve seen parts that havnt been taken off that are db painted pgsg. _________________ shiny paint doesnt make it worth any more |
Posted: Tue Sep 28, 2021 10:56 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
The outer belly pans will be welded. The middle section can be screwed loose and is bolted.
The middle plate is reinforced with L shaped steel.
Posted: Fri Oct 01, 2021 1:49 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
The bus got a new side panel and the rear corner is dent free
Two Glove Boxes Samba Member
Posted: Sat Oct 02, 2021 1:29 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Marc van der Most also built me a Bekowa style roof rack for a sunroof bus.
These racks are a little bit higher than the normal ones and have an extra bow.
Picked the rack up with my small little Audi and immediately dropped it off at the powder coaters place.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5506 Location: 1st Coast
Posted: Sat Oct 02, 2021 4:24 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
I know nothing about belly pan buses. Can you confirm how the factory installed them? Outer pans get welded in and center are bolted in to access the brake lines and heater liner? Am I correct and or anything else I left out? Please school me. _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sat Oct 02, 2021 8:23 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
LAGrunthaner wrote: |
I know nothing about belly pan buses. Can you confirm how the factory installed them? Outer pans get welded in and center are bolted in to access the brake lines and heater liner? Am I correct and or anything else I left out? Please school me. |
No on the Split buses all the pans are welded. On the later Transporter T2A VW started to make the middle section a bolt on.
EverettB wrote: |
Nice rack. Did he make the clamps too? |
Yes, he makes them in-house. |
Posted: Thu Oct 14, 2021 3:38 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
Slowly getting where i want to be! Cleaned up a lot of welts, looked at some gaps and seams and am almost ready for the sandblaster.
Posted: Fri Oct 29, 2021 1:21 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
All the parts are being sandblasted and coated with epoxy primer.
The bus will be done by next week.
Posted: Mon Nov 08, 2021 12:36 am Post subject: Re: My 1957 PGSG swivelseat sunroof microbus... |
The bus is completely blasted and sprayed with epoxy primer.
