Beetsport Samba Member
Joined: January 08, 2005 Posts: 475 Location: Sacramento, CA
Posted: Sat Nov 24, 2012 7:10 pm Post subject: |
Just finished another 1.8T Syncro conversion. Takes me about 2 days with everything on a rack ready to go! Were kicking out about 2-3 a month in house.
The Synfalia just turned over 70k miles on this 1.8T engine. No exhaust problems, no engine problems, no coolant hose problems, no electrical wiring problems.
I did have an ignition coil give out. Install a new on in about 2 minutes and on my way..
_________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
http://H2oVanagon.com
http://www.thesamba.com/vw/forum/viewtopic.php?t=217285 |
dredward Samba Member
Posted: Sat Nov 24, 2012 11:17 pm Post subject: |
tight! _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
kgold708 Samba Member
Posted: Sun Nov 25, 2012 2:26 pm Post subject: |
It looks like your using an adaptor plate and the WBX bellhousing, is that correct? Also do you sell just the engine support/mounts, and bellhousing/adaptor plates for people wanting other VW engine options? _________________ ASE Master Tech.
ASE L1 Advanced engine performance specialist.
ASE L2 Advanced electronic diesel engine specialist. |
Posted: Sun Nov 25, 2012 3:01 pm Post subject: |
Stephan at 70k yer due for a timing belt! _________________ Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32.... |
goffoz Samba Member
Posted: Sun Nov 25, 2012 9:05 pm Post subject: |
Beetsport wrote: |
Wow...mine took a month .....and no 1.8T badge.
...I guess I really am the "Red headed stepchild" of SAH. |
Posted: Mon Nov 26, 2012 1:29 am Post subject: |
goffoz wrote: |
Beetsport wrote: |
No badge? Still? I'll send one up to you!
We now have a system that enables me to complete the conversion efficiently
Yes. Synfalia's first timing belt job just around the corner _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
danfromsyr Samba Member
Posted: Mon Nov 26, 2012 11:30 am Post subject: |
WOW where do you find (and dissassemble) that many donor cars?
that alone is 1/2 a full time job sometimes. _________________
Abscate wrote: |
Posted: Mon Nov 26, 2012 1:06 pm Post subject: |
danfromsyr wrote: |
that alone is 1/2 a full time job sometimes. |
We have several sources now getting us all the components we need. That's the easy part... _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
Posted: Mon Dec 10, 2012 1:01 am Post subject: |
Another 1.8T hits the road
Converted from Automatic to Manual tranny with the 1.8T engine conversion.
A few upgrades that get installed along the converted way..
Coolant hose
Plug me in and lets play
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Mon Dec 10, 2012 7:37 am Post subject: |
These engines and fitting kits look great! I nearly arranged a swap deal with my van heading your way and another coming back to me. I was thinking of getting one of your kits shipped over with it _________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.” |
flyboy705 Samba Member
Joined: April 10, 2012 Posts: 40 Location: Ontario, Canada
Posted: Thu Jan 10, 2013 8:51 am Post subject: |
Great kit ! Wow !
Does it matter what donor as long as it's AWP ? What about other engines like the TTs or A4 etc ? What is the difference between those engine codes ? Are they all the same block ?
Does it matter if it's manual or auto ? |
Posted: Thu Jan 10, 2013 9:58 am Post subject: |
flyboy705 wrote: |
Great kit ! Wow !
Thanks !
Our kit is developed on the AWP engine code. Most of the Audi TT engines are AWP. The Audi A4 are not. Any Jetta, GTI, Golf, Beetle Turbo S, Audi TT with that code will work.
The blocks are the same with other transverse engine codes 2000-2006 years. The electrical system is not.
It does not matter if you find an Auto or Manual car. You will need to find an engine computer system for a Manual car. We build wiring harnesses with either auto or manual system. _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
gotboost? Samba Member
Joined: May 14, 2012 Posts: 43 Location: United States
Posted: Thu Jan 10, 2013 1:48 pm Post subject: |
How much $ does your source on Donor engines run? I know they can be all over the map, but I am trying to budget this the best way possible. I am down in Campbell, CA and have a truck so picking up the engine would be a breeze....
Thanks! |
karush Samba Member
Joined: November 29, 2011 Posts: 168 Location: west virginia
Posted: Thu Jan 10, 2013 4:15 pm Post subject: |
Looks great! What kind of intercooler do you use? Thanks, Paolo |
Posted: Thu Jan 10, 2013 7:11 pm Post subject: |
gotboost? wrote: |
Thanks! |
Around 2-3k. The 1.8T engine comes complete with everything needed to finish the conversion. The price is shipped to your door _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
Posted: Thu Jan 10, 2013 7:12 pm Post subject: |
karush wrote: |
The Intercooler used is the stock system from the donor 1.8T vehicle. CA smog laws require us to use original components.. _________________ '90 Syncro Westy 1.8T with 180hp 174 torque, CA safe!
zeohsix Samba Member
Joined: August 31, 2012 Posts: 501 Location: United States
Posted: Fri Jan 11, 2013 2:34 am Post subject: |
How is my self install kit coming along? Waiting for the call that its ready to ship........ |
Posted: Fri Jan 11, 2013 6:12 am Post subject: |
gotboost? wrote: |
Thanks! |
That's what I'm trying to figure out too |
Posted: Fri Jan 11, 2013 8:53 am Post subject: |
d-oh ... Your price is right there on your website, of course.
Well, I was trying to figure out how much I need to spend for a complete engine and where I would one get it ? I've been checking eBay, local ads and Kijij. They seem to go for more than $3500 and +++ for a donor car. Shouldn't a complete and running car be better then an engine ripped out by a saws-all ?!
You mentioned the 2.0T. I drive one in my A3 and I love driving that car, especially with the APR ECU upgrade.
How different are the 1.8 and the 2.0 ? Seems to me that this could be a good candidate for transplanting. Those engines seem to become more plentiful by now too. |
