ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Fri Sep 28, 2012 1:01 pm Post subject: Has anyone put 'Torkers' on a type 3? |
I'm really tempted to sell my Rockets and get some Torkers.
Pics would be good if anyone's got any.
_________________ I never learned that much at school, but i've taught ladies plenty!! |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
PDX db Samba Member
Posted: Sun Mar 20, 2022 6:38 pm Post subject: Re: Has anyone put 'Torkers' on a type 3? |
Reviving a decade old post. Went thru the link and gallery and still only have found one type 3 with these wheels on them, and that car looks like it might be short axles and narrow front. Does anyone else have pics or info to share on these wheels on a type 3?
Thanks!!! |
jaransonT3 Samba Member
Joined: January 01, 2005 Posts: 1262 Location: Dearborn, MI
Posted: Mon Mar 21, 2022 10:18 am Post subject: Re: Has anyone put 'Torkers' on a type 3? |
These are wide 5 wheels so would only fit the 65 and early Type 3s without adapters or other conversion kits that generally add width to the track. These wheels also only have a 12mm offset and the stock Type 3 offset is 46 mm which means the outer lip of the wheel will be an additional 34mm (1-3/8") further outboard. Adding the extra width of these wheels adds an additional 1/2" movement outboard.
Trying to get these wheels to fit on a lowered Type 3 is going to be a challenge based on the numbers. Not impossible, but hardly a simply bolt-on. _________________ Later,
John Jaranson
'66 Square
'69 Square
'70-1 Fasty
https://www.carartbyjohn.com
https://www.carartbyjohn.com/2024Invasion/ |
PDX db Samba Member
Posted: Mon Mar 21, 2022 10:34 am Post subject: Re: Has anyone put 'Torkers' on a type 3? |
Thanks for the reply John! I should’ve added they would be on a 65 five lug car with long axles… |
