Steering coupler flange on right?
Greg74
Greg74 is offline
PostPosted: Mon Oct 01, 2012 6:10 pm    Post subject: Steering coupler flange on right? Reply with quote
Hi- After installing a new rubber steering coupler, I also decided to replace the leaky steering gearbox (I did reinstall horn gound wire). After putting things back together, I noticed that the bolt that holds the bottom flange to the gearbox shaft was on the left side, bolt head up. Before disassembly, that bolt was on the right, nut side up. Does this matter? The tires are in a straight, centered position and so is the steering wheel. Any advice is appreciated!
P.S. The two flanges on either side of the coupler are perpendicular to each other, two bolts facing one way, two the other way... so I got that right.[img][/img]
Greg74
Greg74 is offline
PostPosted: Mon Oct 01, 2012 6:25 pm    Post subject: Reply with quote
Here is the picture that should have been in my post! -Greg
Bashr52
Bashr52 is offline
PostPosted: Tue Oct 02, 2012 4:20 am    Post subject: Reply with quote
That will make no difference.
cecil
cecil is offline
PostPosted: Tue Oct 02, 2012 9:41 am    Post subject: Reply with quote
Q: What's wrong with this picture?
A: No dirt on finger or under fingrnail. A professional model was used to point at bolt!
I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus."
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Oct 02, 2012 10:07 am    Post subject: Reply with quote
Don't forget the lack of blood either
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
brooklyn thing
brooklyn thing is offline
PostPosted: Tue Oct 02, 2012 11:55 am    Post subject: Reply with quote
Not to mention the metal splinters after having to cut those 40 year old bolts with a motor tool. Just my 2 cents......
Hot Rod Harp
Hot Rod Harp is offline
PostPosted: Sat May 12, 2018 2:48 pm    Post subject: Re: Steering coupler flange on right? Reply with quote
Cracking the nuts loose was the worst part, soaked in PB Blaster for a week, then use hammer and impact socket, finally breaker bar.
Replaced the steering coupler with Febi brand German made.
74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
hobie16
hobie16 is offline
PostPosted: Sat May 12, 2018 5:25 pm    Post subject: Re: Steering coupler flange on right? Reply with quote
Replaced mine a few months ago. Used new stainless bolts and nuts and greased the threads for next time.
Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron
