Malokin Martin Samba Member
Posted: Wed Oct 10, 2012 8:36 pm Post subject: Transmission questions as I put it back in... |
62 bus in USA
I've checked both WCM and WW for these boots and can't find them.
One fits over the shift coupler end and one fits over the end of the transmission shaft rod...
Anyone know where to find them?
Thanks in advance
p.s. bonus round for anyone who can point me to where I can get the boots for where the e-brake/heater lines go into the tubes
Last edited by Malokin Martin on Fri Oct 12, 2012 5:46 pm; edited 3 times in total |
Posted: Wed Oct 10, 2012 8:39 pm Post subject: |
EDIT: These...
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Wed Oct 10, 2012 8:50 pm Post subject: |
looks about right. Thank you! |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Fri Oct 12, 2012 5:45 pm Post subject: |
Another tranny question so I figure I'd just bump this one if you all don't mind (instead of a new one)
The front transmission mount I got from WW is a bit different than what I had... Bolts are a bit bigger than the old one. Like going from 13 to 15 mm different.
Should I just rasp out the holes in the transmission or do I have the wrong mount. Other than the bolt diameter it looks pretty much the same and is labeled "59-67 bus"
Just wanted to make sure it's kosher before I do it
Thanks in advance |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Sat Oct 13, 2012 6:27 am Post subject: |
WW shows the small stud mount fits early beetles to 59 and busses to 59- 62. The larger stud mount for busses 63-67. They no longer stock the small stud mount. That being said, I see a few options. Ream out the nosecone holes, as long as there is clearance for the larger nuts on the backside. Find another vender for the small stud mount. Or swap out for the later nosecone.
I'd be getting out the drill. _________________ Tim |
