piston / head dings from foreign object - questions
early
early is offline
PostPosted: Sun Oct 14, 2012 4:08 pm    Post subject: piston / head dings from foreign object - questions Reply with quote
I pulled my engine a few months ago to find a missing Solex dump tube and to start the body work on the car.
I found the dump tube located in the intake manifold on # 4 it was slightly bent.
months later i have completed the body work and decided to pull the heads since I had engine out and have a look and maybe do a valve job.
what I find is Dents in #4 piston and small dents in the Head .
1600cc dual port, stock mahle 85.5 pistons , mexican 043 heads.
I dont know the complete history of the engine as it was supposedly rebuilt a few years back.
while on the floor, i hooked up starter jig and did a compression test on cold engine #1 -120 #2 - 130, #3- 118 , #4 -135
added a squirt of oil to each cylinder and went another round
#1 - 130, #2 140 , #3 - 135, #4 145
anyway after pulling the heads I have noticed dents in #4
Im wondering if I should replace the pistons & cylinders or if they would be safe to run after cleaning them up a bit.
thanks in advance for your opinions!..
here's some pics:
early-
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
03 BMW R1150RT
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sun Oct 14, 2012 5:49 pm    Post subject: Reply with quote
Compression test was good, why not just buff out the dings and run it?
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
slalombuggy
slalombuggy is offline
PostPosted: Sun Oct 14, 2012 6:02 pm    Post subject: Reply with quote
I've had this on a couple of engines. I simply check for cracks in the piston top, make sure the ring moves freely. then I draw file the piston top smooth and use a carbide scraper to remove the rough area from the cylinder head.
As long as there is no sharp edges cause detonation you'll be fine.
brad
Parts for sale: https://www.thesamba.com/vw/classifieds/search.php?username=slalombuggy
Lucky Monkey Landspeed Racing
1962 Canadian Buggy 121.253mph - Bonneville 2012
1957 Beetle 118.642mph - Bonneville 2014
1957 LSR Buggy 130.583mph - Bonneville 2018
early
early is offline
PostPosted: Sun Oct 14, 2012 6:13 pm    Post subject: dings Reply with quote
miniman. I can clean up the head combustion chamber, but for the piston, i think i will have to remove the piston from the cylinder to avoid causing any damage to cylinder and then I guess I would have to re ring it at that point ? thoughts?
early-
Current Projects :
73 Sport Bug - L13M
94 Harley Flstn
03 BMW R1150RT
miniman82
Samba Swamp Donkey
PostPosted: Sun Oct 14, 2012 7:00 pm    Post subject: Reply with quote
Why would you re-ring it, it's going back into the same cylinder isn't it?
JoeD
JoeD is offline
PostPosted: Sun Oct 14, 2012 7:33 pm    Post subject: Reply with quote
Some years ago My wife drove my bug and came back saying that it made a terrible noise but it went away after a while.
Next time I went to do a tuneup I noticed the bolt for the air cleaner was missing. I looked everywhere and just couldnt find it. I completly forgot about what she had said to me about the noise.
About 60,000 miles later I pulled the engine with my daughter during the summer to rebuild the engine.
When I took the head off I noticed the bolt embeded into the head and both the combustion chamber and the top of the piston were completly abraded. Looked like someone took a box of shotgun shells and blew away at them.
But still the bug ran fine for 60,000 miles.
damicotile
damicotile is offline
PostPosted: Tue Oct 16, 2012 12:14 pm    Post subject: Reply with quote
brad
I had this happen to me to. Turned out to be a washer from the intake manifold. I had to replace and balance the piston cause it pinched the top ring groove.
It looks like yours might be pinched too.
Check also that the valves aren't bent.
'73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________
early
early is offline
PostPosted: Thu Oct 18, 2012 6:04 am    Post subject: Update Reply with quote
I pulled #4 cylinder and Piston.
Top Compression Ring Land was pretty tight near the damaged area. it measured out at < .05 MM when the spec is > .07 MM. that might explain the Higher compression reading on #4.
anyway I sent the heads to the shop for a 3 angle valve Job and Ordered New Pistons and Cylinders.
Dont want to risk it so I'm gong with new parts.
cheers.. thanks all.
early-
Current Projects :
73 Sport Bug - L13M
94 Harley Flstn
03 BMW R1150RT
