notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Sat Jul 15, 2017 9:22 pm Post subject: Re: "homemade" tools??...photo results |
Robbie - I talked to Stuart and he said you are the coolest person you know _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Sun Jul 16, 2017 5:29 pm Post subject: Re: "homemade" tools??...photo results |
Tcash wrote: |
Is it a t2a or t2b rubber band? |
9.5x905 Continental, Made in Germany. Also, my Colorado New Belt is starting to crack like the old one. Right around 15,000 like the last one… And I'll be running it into the ground like the last one.
www.airschooled.com |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3040 Location: Portland, Oregon
Posted: Sun Jul 16, 2017 7:43 pm Post subject: Re: "homemade" tools??...photo results |
I have this: http://www.aircoolednut.com/erkson/ttt/VW_Manuals/
I think it's only Type III stuff but I'm sure there's some things that cross-over. For those who need help making their own tools _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Tcash Samba Member
Posted: Sat Aug 05, 2017 8:12 am Post subject: Temperature Sensor II Testing |
telford dorr wrote: |
I made up an aluminum block to hold the sensor:
This block allows easy connection to itself (note 1/4" blade terminal bolted to it, up at the top edge). The block has enough thermal mass such that you can heat it up, and it will hold its temperature long enough to take a reading at a stable temperature. The block is drilled to hold two sensors so that you can compare an unknown sensor to a known good sensor, having them both at the same temperature. There is a "well" drilled between the two sensor holes where you can insert a temperature probe of some kind in a drop of oil to accurately measure the temperature of the block. |
Tcash Samba Member
Posted: Thu Sep 14, 2017 11:54 am Post subject: Wheel removal and install tool |
Tcash |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Sep 14, 2017 6:23 pm Post subject: Re: "homemade" tools??...photo results |
Not homemade but repurposed a late model water pumper lugnut cover removal tool to use as a generator brush spring tool.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tcash Samba Member
Tcash Samba Member
Posted: Wed Sep 20, 2017 2:13 pm Post subject: Injector tester |
Injector tester
aeromech wrote: |
I made my own injector tester. It's been in my drawer for a couple years since I've used it but basically I used a 2 inch diameter pipe that's about 18 inches long to hold fuel and installed an air fitting on one end. The compressed air provides to fuel pressure for the injector so I don't need an electric pump. I use a 6 volt battery like your kid has in his toy ride around jeep to power the injector. I hook up a clear tygon tube from the fuel reservoir other end and connect that to the injector. Once the pressure is applied and everything connected I touch the injector wires to the battery. This energizes the injector and the fuel sprays into a glass jar with a hole in the lid just big enough for the end of the injector to fit. I can check the spray pattern and flow just by looking through the jar. I bought an injector electrical connector and it has long wires which are what I touch to the battery. A word of caution is needed. Sparks and fuel vapor can be bad. Please don't blow yourself up.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Sep 20, 2017 2:39 pm Post subject: Re: "homemade" tools??...photo results |
That repurposed hub cap tool is awesome _________________ .ssS! |
Tcash Samba Member
Posted: Thu Oct 05, 2017 8:44 am Post subject: Tire dunk tank |
Tire Dunk Tank, flip the tire cover over and fill it with water.
Tcash Samba Member
Posted: Thu Oct 05, 2017 8:46 am Post subject: Brake drum puller |
Brake drum puller
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Tue Oct 10, 2017 9:52 pm Post subject: Re: "homemade" tools??...photo results |
Years back when i was doing a lot of dual Dellorto and Weber work I made this stand to mount the carbs on when calibrating the accelerator pump volume and it worked fine, I also made an adapter plate for PICT- 34 carbs. The bottle hanging on the rod with hose attached was the fuel supply when calibrating the accelerator pump. now it just takes up space until I find another use.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Tcash Samba Member
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Thu Nov 02, 2017 8:23 pm Post subject: Steering Box Adapter for Steering Worm 758/1 |
I picked up a very nice steering box some years back at a swap meet. It's been one of those "meaning to get to" things for awhile now. I'm gearing up to do the ball joints on my camper so I figured it's a good time to do the steering box too.
As long as I've had this spare steering box I have wanted to make a VW 758/1 tool to service it with. I got around to that too.
With an old errant 3\8 drive 1\2 inch impact socket that has been rattling around in my toolbox since forever. And a drilled piece of flat stock steel, I got this together. I found a steering flange to go with it too.
I have always wanted to go through one of these early Baywindow steering boxes. I also now have a proper inch pound torque wench too, so the homemade 758/1 should be very handy. |
Tcash Samba Member
Posted: Sat Jun 16, 2018 12:44 pm Post subject: Cylinder Haead Exhaust Stud Drill Jig |
1975 Kombi wrote: |
I have made a guide/sleeve to place inside the exhaust flange to aid in drilling the new hole to be tapped and a new std M8 X 1.25 X 51.5mm stud installed. The drill bit size for a std M8 X 1.25 tap is 17/64.
The only thing I have noticed is that the #3 exhaust flange does not look like it is aligned perfect with the exhaust port. It is hard to see in the pic but it looks like I need to separate the #3 and #4 flanges slightly to align the pipes with the port opening better.
What's the best way to separate the pipes??
WildIdea Samba Member
Joined: September 17, 2016 Posts: 928 Location: Black Hills, South Dakota
Posted: Sat Jun 16, 2018 5:21 pm Post subject: Single port intake manifold 10mm obstruction wrench |
Great ideas in this thread, thanks everybody. I’ll add one.
Nothing mind blowing but one night I dedicated an hour to craft this single port intake manifold nut wrench. I just didn’t have anything I could get in there with so I cut my wrench’s closed end off and thinned it out on my bench grinder and welded it back on a little offset. Works so good I have to be careful now not to pull out the stud in the head.
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Mon Jun 18, 2018 2:22 pm Post subject: Pilot bearing puller Type 4 flywheel main seal press |
A couple of home made type 4 engine specific tools.
1. A pilot needle bearing removal tool, I made it out of a 6" length of cheap 7/16" bar stock. Some grinding with bench grinder and angle grinder....a little drilling and a set screw and a bolt. It screws onto my slide hammer Works really well.
The tool
Taken apart. I used two lengths of rod and split both with the angle grinder and then ground them smooth
This is how it grabs the bearing
Just tighten the set screw to spread the tool until its tight...then hook it to the slide hammer. Two quick, light bumps and it popped right out.
2. A flywheel seal installation tool. I used a couple of pieces of 4" wide 1/4" thick plate from home depot. It is three parts...the seal driver plate with the cage of bolts around it to give room from the crank when the seal pushed in....the backing/bolt holder plate that bolts to the end of the crank.....and the driver plate that uses those five bolt heads as a back stop.
Between the steel plates, a bi-metal hole saw, the 8mm cage bolts and the big 14mm thread driver bolt...and a drill and tap I did not have...I think I have about $30 in it.
The driver connected and in place...just a stack up for the picture
The main driver plate back stopped by the five bolt heads installed to the same depth in the crank. The only threaded hole in this drivere plate is the center hole for thew 14mm bolt that drives the pusher plate against the seal.
Close up of seal pushed in
The part on the left fits against the seal...like this
The backing plate fits into that and the bolts screw into the crank
Just another close up.
It works very well. A little fiddly holding it all up to get the bolts threaded in. It weights about 5 lbs... I get the seal up there loosely, fit the bolts and screw them all in with the pusher bolt out....then stick the seal in flat and screw in teh center bolt until you feel tension...make sure its centered...it has a slight amount of play...then crank it home.
Ray |
Tcash Samba Member
Posted: Mon Jun 18, 2018 7:09 pm Post subject: Re: "homemade" tools??...photo results FAQ |
The main seal flies straight into the hole when it sees this coming!
That is a work of ingenuity Ray. Good job.
Tcash |
Posted: Mon Jun 18, 2018 7:20 pm Post subject: Re: "homemade" tools??...photo results FAQ |
Thanks! Surprising easy to build. I only welded that top plate on to have deeper thread. I did not have any 1/2" plate.
That hole saw was about,$12 and on a drill press will cut 1/2" plate. If you want I csn post the simple plans for it.
Ray |
Tcash Samba Member
Posted: Mon Jun 18, 2018 8:40 pm Post subject: Re: "homemade" tools??...photo results FAQ |
raygreenwood wrote: |
Ray |
If you would like to that would be great.
Thank you
Tcash |
