vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Oct 01, 2013 5:56 pm Post subject: |
djkeev wrote: |
Okay, you've all seen this item......
Right Rear Fender next to the engine......
Hose from the Engine Air Filter........
What's behind that? Hmmmmmmm.......
Snap off four (4) speed nuts and Viola'!
Mouse nest, leaves and crap!
Rust waiting to happen.......errrrr already happening!
Who designs stuff like this? "I know, let's make a dark inaccessible wet spot where rodents can come in and live."
And what's this relay control?
YEP! Found the same on my van. This summer during screaming hot weather and with a bad back, I put the van under a tree and cleaned these spots and the engine compartment with Simple Green. Very therapeutic. On that relay, Rubba chicken told me
Quote: |
"if it's a 2.1 behind the right side light cluster there is a relay box for the idle control for the power steering, ... most people do not know of their existance, as you need to take out the light cluster to see it. " |
_________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Wed Oct 02, 2013 11:47 am Post subject: |
Depends on how you want to do it but that two part adhesive can be used without the special gun. BTDT. You can push the plunger for each side of the tube (cap off the top of course) by 'hand' to dispense an equal portion from each onto a paper plate and then mix with a stick and apply as you wish. It is messy and not as elegant as using the gun and special nozzle, but heck, it is just a two part epoxy.... _________________ Dave O
The Western Syncro build
Posted: Wed Oct 02, 2013 12:15 pm Post subject: |
dobryan wrote: |
Depends on how you want to do it but that two part adhesive can be used without the special gun. BTDT. You can push the plunger for each side of the tube (cap off the top of course) by 'hand' to dispense an equal portion from each onto a paper plate and then mix with a stick and apply as you wish. It is messy and not as elegant as using the gun and special nozzle, but heck, it is just a two part epoxy.... |
Thanks but I need a very neat and controlled application system. It is very visible right there on the exterior of the van.......appearances are everything!
The panel adhesive I viewed as the best....... Option #1
The seam sealer is second best. The first seam sealer lasted 20 years....... If this last that long, it will be my children's problem the next time! I'm sure they will have taken Dad's keys away by then!
Ghia
Vanagon
Beetle
Posted: Wed Oct 02, 2013 3:36 pm Post subject: |
Last week I had removed the Intake Air pipe from the Right Rear "D" Pillar. It feeds air into the Air Filter for combustion.........
Upon removing the Assembly it became clear that I was being short changed on Air!
The flexible pipe is made from a paper/aluminum/plastic product. The exterior has a thin plastic layer but the inside is old school paper air hose as was used on Air Cooled Engines for Decades.
Anyway, it was badly crimped where it made the 90 degree turn at the bottom of the Pillar.........
As you can see the pipe is an oval shape.
Desiring a better alternative I held it into a circle and measured the diameter, it showed a nominal 3". Next I located a plastic universal air intake pipe made by Spectre Performance #8741..........
I installed the new Spectre hose with Zero issues. I taped the end that fastens to the intake scoop using electrical tape....... As the factory had done originally.......
The 3" round hose will NOT fit down the "D" Pillar so it had to become Oval.......no problem, simple, cheap, effective and a tad brutal....... I laid the pipe on the floor and gently stepped on it until it was oval! ........
I slid the hose into the Pillar guiding it down until I was able to clip the scoop onto the provided tabs to hold it in place.......
BEWARE!!!!!! There are many sharp items in the "D" Pillar!!!!! One of several "leaks" I developed!...........
A view looking down the "D" Pillar with the Pipe installed........
A view looking at the bottom of the "D" Pillar where the pipe comes out on its journey to the air filter......
Ghia
Vanagon
Beetle
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Wed Oct 02, 2013 4:58 pm Post subject: |
I think it's perfect _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Posted: Thu Oct 03, 2013 3:48 pm Post subject: |
So I've been TALKING a lot about my cracked seams but haven't been DOING anything about them!
Decided, now is the time.
My original plan was to sand blast out the old sealer......but that was when I was planning on using Panel Adhesive.
Now I'm going to use Seam Sealer so primer is actually desireable.
How to get the old Seam Sealer out? It is hard and dry.
I could dig it out with picks and a utility knife..........
Or.....
I could use my FEIN MULTIMASTER!!!!
Yes! I LOVE this tool! For those of you who do not own a Multimaster....... You honestly haven't a clue what you are missing out on! (Yes, I've used the new "knockoffs", they pale in comparison)..........
I put in the very thin 3 1/8" Diameter segment Saw Blade. It is only .0021 thick so goes easily into the seam between the panels..........
http://feintools-online.com/fein-accessories/fein-...-2pcs.html
Wherever I encounter rust in the seam I will still be sandblasting that area.
I found with the tool on a medium speed that it was easy to control and ate that sealer out within seconds!.........
Lower part done....
I also used it above the rusted wheel lip to prepare it for repair. The blade will cut sheet metal and spot welds. I'll be grafting in pieces rather than a full panel replacement. Just take care of the rust.....
The blade has a flat side cut on it, like the capital letter "D". Using the point I was able to follow the curvature of the rear wheel seam with no problems.........
Ghia
Vanagon
Beetle
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Thu Oct 03, 2013 5:05 pm Post subject: |
That is a smart use of that tool. Mine is parked with my woodworking tools, but I will have to rethink seam repair and other potential uses in the garage.
Thanks for that tip. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Fri Oct 04, 2013 10:19 am Post subject: |
I plan to repair the cracked seams now, before Winter sets in and do the rest of them before I repaint in a year or so.
For now it's simply..........
STOP THE RUST!!!
The seams below and on either side of the windshield down to the grille are both cracked. To get to them I had to remove the front grille..........
I also removed the front bumper for I have early seam rust behind it and below the lower grille...........
Found my EDIT: COOLING Fan Resistor! ....... Wondered where that was!.......behind the left headlight!........ Of course! ...........
I will pull those headlamp mounting panels and deal with the rust at the mounting tabs while I'm this far disassembled.........
The mice (or is it birds?) have moved in behind the Right Headlight!..........
Also EVERY SINGLE HEADLIGHT MOUNT IS BROKEN!!!!! Any cheap fixes that last?.........
When I was exploring behind my glove box I had pulled a dash vent hose off of the heater box, I peeked inside and saw a mouse nest just outside the lower flap! I wondered how they got in, I'm guessing that they use this gap in the intake screen that VW left around the grille mount tab?............
I also pulled the rear bumper to gain access to the two lower seams that go behind the bumper end caps.............
My garage is filling up with pieces!
Ghia
Vanagon
Beetle
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Fri Oct 04, 2013 10:31 am Post subject: |
Syncro Pilot wrote: |
Thanks for that tip. |
I just had the same "aha!" moment, thanks _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
teej Samba Member
Posted: Fri Oct 04, 2013 11:47 am Post subject: |
I think you guessed right on (one of) the chiselers entry points. I sealed that with some bits of galv 1/4" hardware cloth, also at the sides of that vent they can get in. I will try to find a pic of mine. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
yycwesty Samba Member
Posted: Fri Oct 04, 2013 12:42 pm Post subject: |
Sorry to hijack
That FEIN MULTIMASTER looks like a great tool for the job. Unfortunately I can't afford $299 or so. Can anyone tell me if they have used any similar device that they were happy with. I'd much rather use something like this than a pick.
Al |
teej Samba Member
Posted: Fri Oct 04, 2013 12:52 pm Post subject: |
yycwesty wrote: |
Sorry to hijack
Al |
As far as I know, I think Fein might have been the first to make this type of tool. Their stuff is suitable for professional all day use. Lately I have seen many competing versions at lower price points that would probably be great for occasional use, hopefully someone who has one will comment. Also the Fein blades are stupid expensive but there are now aftermarket blades that work well too. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
Posted: Fri Oct 04, 2013 1:45 pm Post subject: |
So, the front grill is off, checking out the mice infiltration. As mentioned, I know they've been in the Fresh air system, I saw their nesting when I had the dash vent pipe off.
Here is a photo of the intake scoop with the screen removed......
A closer view of the scoop, the air is forced up and over the top of the dam...... Notice the ingenious water deflection lip. The rear of the scoop is folded back forward upon itself leaving a collection place for water to drain off while traveling at speed! .............
I held my camera phone up in the slot and blindly took photos to see what joys await me!........
The Drivers Side......... I do NOT like the rust I see at the base of that seam!!!....
The Passengers Side............ ..............
Heavy sigh........ Off comes the dash and a much better mouse screen MUST be made!!
Ghia
Vanagon
Beetle
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Oct 04, 2013 4:00 pm Post subject: |
djkeev wrote: |
Found my Heater Blower Fan Resistor!
Nope.
That's the RADIATOR fan resistor.
The heater blower fan resistor is still inside your dash blower box, waiting to be discovered...
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
