vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sun Dec 04, 2016 7:32 pm Post subject: Re: My BA6 gas heater install (pic heavy) |
Quoting myself in another thread so that searchers that find this thread will have the info too. (Especially since I and others asked the question in this thread!)
vwwestyman wrote: |
We have ignition!
For anyone else who wants to bench test one, here's how I hooked it up to the battery:
12v to:
Female connector with two red wires going to it.
Female connector with a black wire and a blue/white wire.
Ground to:
Recirculation fan ring terminal
Safety switch brown wire ring terminal
Brown with white stripe from timer switch
Ring terminal near coil with a brown wire and a red wire attached
I do have some troubleshooting to do.
After it runs for a few minutes, it seems that the safety switch wants to trip. I'm need to figure out what is causing that.
Also the combustion fan is a little buzzy. I've got two others but was having a hard time getting one of them apart. So I may swap to just see if any of the others work without opening it up. Or run this one for a while and work on the other later. |
_________________ Dave Cook
1973 Wild Westerner
My Thing |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Tue Jul 03, 2018 8:06 am Post subject: Re: My BA6 gas heater install (pic heavy) |
cmonSTART wrote: |
I refurbished my BA6 and run it stand along - like yours, a PO hacked and removed all of the stock heat components except the Eberspacher. After going through it I had to change around a bunch of the ducting to eliminate where it intersected with the old system. I also insulated the ducting going forward from the heater. It does work, but you will need to make darn sure you have enough air flow - install a booster fan - otherwise it will overheat. |
I'm thinking of refurbing my BA6 in my 77 Westy and running it as a stand alone without the stock heat components to the rear - ie: heater boxes etc.
Does anyone have some visual aids / photos as to the set up required to make this mod? _________________ 1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382 |
pb24ss Samba Member
Joined: June 30, 2005 Posts: 1665 Location: sitting around the fire with the bluegrass band - colorado
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 03, 2018 9:13 am Post subject: Re: My BA6 gas heater install (pic heavy) |
Yes, that's how it works when the engine isn't running (and all the non return flaps are functional). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airkooledchris Samba Member
Posted: Tue Jul 03, 2018 9:26 am Post subject: Re: My BA6 gas heater install (pic heavy) |
I believe the pic is actually from a Vanagon setup
That picture is missing (i believe) the bay window's under bench air intake for the heater, so you are taking in cabin air and heating that instead of always pulling in outside cold air to work with. |
Posted: Tue Jul 03, 2018 9:46 am Post subject: Re: My BA6 gas heater install (pic heavy) |
Looks like bay to me, Vanagon doesn't have the air going to the heat exchangers via the lower shroud ports. The cabin air intake is a hollow black arrow and a funnel at the intake of the fan between the words "flap housing" and "bowden cable". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
