Clutch pedal mod
MURZI
MURZI is offline
PostPosted: Mon Oct 22, 2012 6:22 pm    Post subject: Clutch pedal mod Reply with quote
So...if you are thinking of doing the clutch pedal mod you have seen in the classifieds you should do it. I used a simple shoulder bolt 5/16" with a nyloc nut, but a 8mm works as well. EASYYYYY no cutting, no grinding
16 1/2 seconds of welding and done!!! Maybe 17 seconds...
in the end I double nutted the nyloc nut for just in case
62 vert
2276
Timís welded heads
45 Dells
A1 sidewinder
Fk44 cam
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Oct 22, 2012 6:29 pm    Post subject: Reply with quote
Why? What problems does it solve?
I've never had problem with the stock setup.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
MURZI
MURZI is offline
PostPosted: Mon Oct 22, 2012 6:35 pm    Post subject: Reply with quote
Glenn, it took less time to weld the bolt than it would to reattach a clutch cable that came of the hook. We have all done that chore three or four times. I had the tranny out and needed to change the clutch cable so why not. Looks like all the cool kids are doing it.
Its done. Easy and the clutch cable went in like I was shoving a cake in the oven. I even did an extra pedal set I had for Kicks and Giggles. Just made me all happy inside. Laughing Laughing Laughing Laughing
62 vert
2276
Timís welded heads
45 Dells
A1 sidewinder
Fk44 cam
Mr. 010
Glenn is offline
PostPosted: Mon Oct 22, 2012 6:39 pm    Post subject: Reply with quote
I just use a zip tie to hold the cable onto the hook. It breaks off the first time you step on the pedal.
By shifting the cable a few millimeters over the cable will rub on the steel guide.
If it works for you.. .fine. But I don't see it as a problem.
Glenn
mr_bill
mr_bill is offline
PostPosted: Tue Oct 23, 2012 1:54 pm    Post subject: Reply with quote
WHAT Glenn said X2
see ya' on the trail........
"Mr Bill" "OldManx"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org
Dale M.
Dale M. is offline
PostPosted: Tue Oct 23, 2012 3:12 pm    Post subject: Reply with quote
Mod may be good if "hook" has failed and you need to have beast running by tomorrow....
Dale
ďFear The Government That Wants To Take Your Guns" - Thomas Jefferson.
