68ohiobug Samba Member
Joined: October 26, 2012 Posts: 150 Location: Southeast Ohio
Posted: Thu May 01, 2014 7:54 am Post subject: |
Herc,
Thanks for the advise,
I will most likely have to pull the carpet to check the seals...
The bad part about the seals is that they are new ones... and once I get a good day I will be crawling all through the bug to find and fix issues that I have slowly found... _________________ Mind The Spelling Errors
"I hAve aN AppItlatiOn EDumidCAtion"
http://www.thesamba.com/vw/forum/viewtopic.php?p=6374489&highlight=#6374489 |
HERC Samba Member
Posted: Thu May 01, 2014 8:51 am Post subject: |
no probs bro, hope you get it sorted. mine turns into a bathtub in a good storm but I dont have as much metal as you do to deflect shit. _________________ Herc |
Brian Samba Moderator
Posted: Thu May 01, 2014 11:06 am Post subject: |
Yea I would just run the brakes without changing the cylinders and see if it works. I have discs up front and changed nothing, works without a problem. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Mon May 05, 2014 8:39 am Post subject: |
Here is some pics...
And once I got the back on I bleed them.... But one of my switches went out...
And to top it off, my front kit didn't come with mounting brackets, which was not stated in the description...
I guess I will have to make a call.... damn. _________________ Mind The Spelling Errors
Posted: Mon May 19, 2014 10:55 am Post subject: |
Well I got the disc brakes and brake switch finished...
I drove it around Saturday after I finished them and they worked really well...
But it was not joyous for me like it should have... due to my 19 year old cat that pasted away on Thursday. R.I.P Oreo... He will be missed. _________________ Mind The Spelling Errors
Posted: Fri Jun 27, 2014 12:46 pm Post subject: |
It has been a while, so a little update....
Over Memorial day I did some driving.... 4 hours and 200 miles worth...
Brakes are awesome....
And some exciting news.. I have a new niece...
Lastly, I had a glimpse of a rainbow on the way home in he bug...
Man I Love My Bug.. And I CAN'T wait to see my new niece.....
Keep on bugging! _________________ Mind The Spelling Errors
Posted: Tue Jul 01, 2014 12:35 pm Post subject: |
Another Update... More like a heads up for grinder users...
We have been reworking our building to make it easier to work in and to organize it. Especially since the bug is not taking up restate...
And in the process I had a little slip-up with the grinder....
It was a good reminder to wear gloves and to watch the way I cut....
Here is some pics of the building if your interested...
before...
in the process...
A centered 10' Slit Sliding door, new beams, rewired, new insulation, straight/plum walls, two man doors, and bright new lights... I may have to start on the next bug sooner... _________________ Mind The Spelling Errors
Posted: Tue Aug 05, 2014 12:43 pm Post subject: |
Well, I decided to replace my CV boots due to some dry rot, but found some issues....
The car started to shutter when taking off, then it started to stick in second unless moving, all before the boot replacement. But after.. I found the CV joints were worn all around, the driver side IRS flange had some side to side and up and down movement, and the passenger side boot on the trans was FULL of gear oil...
First thought was bad seals and loose bearings, then I remembered the shifting issues...
I believe the transmission needs replaced, and if I replace the trans I think I want to go up in horse power.... maybe 1900 to 2100 cc..
Any thoughts/advice and/or great trans and engine shops/places to buy?
I am lost at the moment!! _________________ Mind The Spelling Errors
dweiss76 Samba Member
Joined: July 13, 2014 Posts: 17 Location: Toledo, Ohio
Posted: Thu Aug 07, 2014 10:51 pm Post subject: |
I have a question. How do the coil overs actually ride? Do you like them? |
Posted: Mon Nov 10, 2014 7:11 am Post subject: |
Hey All,
So a little update since my last post...
After a "Life Change", new job in a different town, and etc.
I didn't do much to the car till recently... and here is what has happened..
I rebuilt a spair transmission, swopped out the one in the car.
After the first go around.. the clutch was staying engaged...
Then hauled the car to my new home and removed the engine again to address the clutch. Took apart the clutch, checked the parts, and reassembled, it somehow is fixed.... Now the car will die if the throttle is "Massed", or hard acceration, and I have done a retime, carb adjustment, etc. and no change...
So my next step is to swop out the new carb with the old and see if that takes care of it.... fingers crossed...
I feel like I opened a "Can of Worms"... _________________ Mind The Spelling Errors
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Sat Aug 11, 2018 11:58 am Post subject: Re: Baja/Class 11 Project |
So hows it going? get the new drive train ? _________________ "Albatross"! |
Posted: Sat Aug 11, 2018 12:16 pm Post subject: Re: Baja/Class 11 Project |
I guess I kind of forgot about the Samba...
So things are good! I did repair the transaxle and the carb issue. The carb I had it fixed by Volkzbitz, and it runs great! I have been enjoyed my car since! I ended up swapping out my trans with a spare, and tore down the bad one. It ended up being a broken shifting fork... but I didn't know until I took it apart. I also added a view port to the opposite side of the fill pug to help with adjudting the fork and to know the trans fluid level/color at a glance. Here are some of the photos I have of transaxle repair.
Posted: Sat Aug 11, 2018 12:31 pm Post subject: Re: Baja/Class 11 Project |
Here are some photos of me enjoying my Class11 Look-a-like!
Some driving around local area.
Went camping out of the old girl, and it was a blast!
I even got in a car show at the camp ground, and meet a few fun old car guys.
