Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Fri Oct 26, 2012 3:13 pm Post subject: Removing overspray (rattlecan) off chrome? |
Have a set of chrome raders. Kid sprayed his toy race car in the garage, now I have moderate to light over spray on all four. Whats the easiest way to remove the over spray from the chrome (wheels not on a car, lyin on the floor) and not damage the wheel?
Thanks in advance. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
Fab4Fan Samba Member
Joined: June 17, 2005 Posts: 703 Location: Claremont, So-Cal
Posted: Fri Oct 26, 2012 4:34 pm Post subject: |
I use a soft rag dampened with acetone. then clean with chrome polish. |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Wed Oct 31, 2012 7:05 am Post subject: |
wire wool is the easiest way to clean chrome _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
dubllyou Samba Member
Joined: May 24, 2012 Posts: 1251 Location: Jack & Cee Motors
Posted: Thu Nov 01, 2012 10:24 am Post subject: |
EverettB wrote: |
Yes, I have used #0000 steel wool in the past. |
Even #00 won't scratch glass or good chrome but the finer the better, it just takes a little longer. Use it with some car wax or chrome polish for added insurance. _________________ Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote: |
You cannot polish a turd, but you can roll it in glitter. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Nov 02, 2012 10:07 pm Post subject: |
Steel wool is ok to clean chrome once it has gotten a haze of rust or corrosion. If it isn't, and you're just taking paint off, Don't use it! Get some lacquer thinner, or a scotchbrite pad. The steel wool leaves little scratches, and will cause the chrome to dull and rust faster. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Nov 23, 2012 7:42 pm Post subject: |
Negative, esde!
Scotch Brite is worse than "0000" steel wool. The rating on wool denotes consistency! "00" is too coarse. Brass works really well.
There's no two scotch-brite pads alike- and you mostly certainly can scratch chrome with these. What do you have against the original poster? _________________
EverettB wrote: |
FU#5 |
esde Samba Member
Posted: Sun Nov 25, 2012 8:28 am Post subject: |
hitest wrote: |
Negative, esde!
There's no two scotch-brite pads alike- and you mostly certainly can scratch chrome with these. What do you have against the original poster? |
Not all scotch brite pads are coarser than 0000 steel wool, my mistake for not specifying which one I would use. I have some grey and light grey ones that are very fine and made for finish polishing. Personally I would choose them over 0000 steel wool any day. Especially when using a thinner to loosen whatever you are scrubbing off. Brass wool? Sure, but you don't mention anything about what grade.. the coarse ones could do more damage..
Whatever makes you believe I have some issue "against the original poster?" I have no idea.. |
