Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Wed Mar 08, 2023 1:11 pm Post subject: correct throttle body for my 85 1.9? |
so i'm looking at a used TB and it's advertised as fitting a 76-84... Looks identical, albeit in far better shape than what i've got on my 85 1.9.
I can't find any information that makes sense of 76-84 fitment. does this look proper for the 85 1.9 and is the ad incorrect?
_________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
Posted: Wed Mar 08, 2023 1:37 pm Post subject: Re: correct throttle body for my 85 1.9? |
I used the throttle body off a a '91 on my 83 1/2. Required minor rewiring of the throttle position switch. |
wcfvw69 Samba Purist
Posted: Wed Mar 08, 2023 2:52 pm Post subject: Re: correct throttle body for my 85 1.9? |
I just finished this one-
https://www.thesamba.com/vw/classifieds/detail.php?id=2605619
Ready to go. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Mar 08, 2023 3:23 pm Post subject: Re: correct throttle body for my 85 1.9? |
Wildthings wrote: |
right on. right on. what did the rewiring entail? _________________ so many roads i know
Posted: Wed Mar 08, 2023 3:59 pm Post subject: Re: correct throttle body for my 85 1.9? |
Mckinleyvillian wrote: |
Wildthings wrote: |
right on. right on. what did the rewiring entail? |
Both units use two wires so you just need to figure out what it takes to hook up the early harness to the later unit. Don't remember what I did, but it didn't take much at all to do, just not quite a plug and play, IIRC. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Wed Mar 08, 2023 4:16 pm Post subject: Re: correct throttle body for my 85 1.9? |
Both units can be swapped out.
Early WBX is dual switch and dual vacuum nipple.
Later models ( late 85 and on) had a single switch that does both functions at once. One vacuum nipple.
Wires on the dual switch are just one pair off the main harness and split in 2 pairs.
The single nipple requires a Tee to solve the vacuum routing issue.
I wanna say the 2.1L connection to the intake boot is bigger diameter, but I don't remember for sure.
GoWesty has clear instructions on their TB listing. It's just common sense once you look at it, very simple stuff. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Wed Mar 08, 2023 5:27 pm Post subject: Re: correct throttle body for my 85 1.9? |
ALIKA T3 wrote: |
GoWesty has clear instructions on their TB listing. It's just common sense once you look at it, very simple stuff. |
Doesn't one nipple have manifold vacuum and the other ported vacuum on a 1.9L? That would be required to get the vacuum retard function to work properly. I know I have bolted both the 1.9L and the late 2.1L throttle bodies to the same plenum, but can't say what year plenum it is as my engine is a hodge podge of stuff from both a 1.9L and a 2.1L. |
Posted: Wed Mar 08, 2023 5:45 pm Post subject: Re: correct throttle body for my 85 1.9? |
Wildthings wrote: |
ALIKA T3 wrote: |
Yes, that throttle body also has the hole in the throttle plate for the bypass so it idles correctly when the plate is closed and the canister retards the timing. _________________ Contact me at [email protected]
Posted: Wed Mar 08, 2023 6:04 pm Post subject: Re: correct throttle body for my 85 1.9? |
Wildthings wrote: |
ALIKA T3 wrote: |
You get the other one from the plenum nipple close to the brake booster connection. Then both have a tee.
Again, GW has clear instructions. Here's the link https://gowesty.com/products/gowesty-throttle-valve-housing _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Andymon Samba Member
Joined: February 24, 2015 Posts: 314 Location: Medford, OR
Posted: Wed Mar 08, 2023 6:07 pm Post subject: Re: correct throttle body for my 85 1.9? |
Got mine for our 85 from buslab.com https://www.buslab.com/product-p/gvw-tb-df-n.htm _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Mar 09, 2023 6:44 am Post subject: Re: correct throttle body for my 85 1.9? |
I'll bite... Is there any advantage (other than availability) to using a Digifant TB on a 1.9 engine?
The Digijet unit certainly makes it easy to adjust the throttle position switches. |
jlrftype7 Samba Member
Posted: Thu Mar 09, 2023 7:26 am Post subject: Re: correct throttle body for my 85 1.9? |
Here's our rebuilt '84 1.9 throttle body with the earlier double switch set-up for comparison. The only issue with that one for sell that you pictured, is you don't know throttle shaft play, and how worn the bore is in relation to the plate either. It's been glass beaded or media blasted, so it's clean at least...
Is yours is the '85 single switch, and not the double switch like the one in that AD?
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
84 Tin Top - Hilga....Auto |
Posted: Thu Mar 09, 2023 10:37 am Post subject: Re: correct throttle body for my 85 1.9? |
jlrftype7 wrote: |
Is yours is the '85 single switch, and not the double switch like the one in that AD? |
Im thinking similarly, but at a low low price and a working claim from a used parts vendor with excellent feedback, i may give it a go.
My van has the double switch as is featured in the photo.
I would ideally buy a remanned TB but 3-400 bucks isnt in my pocket to be spent at this time. _________________ so many roads i know
Posted: Thu Mar 09, 2023 11:19 am Post subject: Re: correct throttle body for my 85 1.9? |
I would ideally buy a remanned TB but 3-400 bucks isnt in my pocket to be spent at this time. |
Understand about the money- Once you buy that one, check the switches with a Meter to make sure they work, and there isn't high resistance in the switches either- hopefully media grit didn't get slammed into the switches when the throttle body was blasted.
A new seal for the connection to the intake plenum is a must if yours is really old. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Sun Mar 12, 2023 4:45 pm Post subject: Re: correct throttle body for my 85 1.9? |
I can't find any information that makes sense of 76-84 fitment. does this look proper for the 85 1.9 and is the ad incorrect? |
IIRC, 85 had both the single and dual switch TB which is why you are not making sense of the figment years. If yours has the double switch like the one pictured then its plug and play. I suspect the early 85s has the leftover TBs from the 84 production year. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
Posted: Sun Mar 12, 2023 8:50 pm Post subject: Re: correct throttle body for my 85 1.9? |
Pascal wrote: |
IIRC, 85 had both the single and dual switch TB which is why you are not making sense of the figment years. If yours has the double switch like the one pictured then its plug and play. I suspect the early 85s has the leftover TBs from the 84 production year. |
That's what I mentioned earlier in this thread. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
