gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Tue Oct 30, 2012 5:24 pm Post subject: Mechanical fuel pump ? |
Does any one make a mechanical fuel pump that has screw in fittings instead of the slip on ??? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
58Blue Samba Member
Joined: June 30, 2010 Posts: 114 Location: Ontario, Canada
Posted: Tue Oct 30, 2012 6:17 pm Post subject: |
You could always opt for an original that's been restored to better than new condition.
I got one from Ed Fall of Vintage Werks, a member here on the forum, and it's a thing of beauty.
http://www.vintagewerks.com/Fuel%20Pumps/fp_4sale.html |
Posted: Tue Oct 30, 2012 7:10 pm Post subject: |
Indeed a thing of beauty!!!
I'll be runnin' a 1955 with an alternator, and I don't see any of those working for that. Makes me want to build a 36, however.... _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Tue Oct 30, 2012 9:11 pm Post subject: |
If you're looking for a pump for the 40HP and newer engines with both inlet and outlets threaded, you won't find it. The 40HP (and mid-late 60s Bus) style pump does have a threaded INlet, but the outlet is a push-on fitting. |
Posted: Tue Oct 30, 2012 9:43 pm Post subject: |
Looking for a pump with both threaded so I can run hard lines to dual carbs. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Posted: Tue Oct 30, 2012 9:55 pm Post subject: |
Yeah, I suspected as much. It would be easier if VW had made them that way, but they never did after the change from 36HP to 40HP. |
Culito 11010101
Joined: December 07, 2006 Posts: 5865 Location: Columbia Missourah
Posted: Wed Oct 31, 2012 11:12 am Post subject: |
I'm sure someone has used compression fittings on the hard lines from the pump before. Is that doable? _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Oct 31, 2012 6:20 pm Post subject: |
VW had a steel outlet line for awhile on later pumps but even that had the cloth wound lines at each end. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
